CChris
(Christoph)
February 8, 2023, 7:10am
316
it seems that your sensor.thermostat_buro_program
is receiving a state exceeding the limit of 255 characters.
This is probably causing the integration to crash.
I found this on the forum:
Hi There,
I’m trying to add a sensor where the output is an invalid json, so I have to manipulate it before use.
I was able to manipulate the data using the Template on Developer Tools, but doesn’t matter how many characters I’m filtering using regex_replace, however when I try to configure the sensor, I’m receiving the below message from the logs:
2022-07-14 13:03:18 ERROR (MainThread) [homeassistant.util.logging] Exception in message_received when handling msg on 'lollipop/cameraStatus/retu…
I want to use text strings that are longer than 256 characters. I thought I could publish them to MQTT (I can) and then be able to do something with them in HA (I can’t).
The only way I can think of to get them into HA is using an MQTT Sensor but I have now found that that also has a size limit of 256 characters
Is there any way to ‘read’ a long payload? It doesn’t need to be stored, I can use it dynamically while it is in memory.
that might help ?
