2023.2: How can I Assist?
My sensor template entities with device_class timestamp stopped working after upgrade to 2023.2.2.
Following entity has no value, but value_template shows correct datetime value when tested via Template editor. Not sure what is wrong with the definition now.
    baldr3_last_updated:
      friendly_name: "Baldr3 Last Updated"
      device_class: timestamp
      unit_of_measurement: "datetime"
      value_template: "{{ as_datetime(states('sensor.baldr3_update_time')) }}"
remove the unit of measurement…
Well it is obvious that voice input is important for a lot of the users of the Nabu Casa cloud service. I think it is one of the reasons people use the service. So they decided to pay the guy full time who has developed one of the best open source solutions as a hobby for the last few years. Lots of people are using voice input with Home Assistant. If you talk with ā€œnormalā€ people when they hear smart home they think ā€œvoice controlā€, from that point of view it seems also to make sense.
Sure in most cases true automation for example for lighting is better than voice control. But the reality is: To fully automate lighting or something you have to make a huge investment.
And I think there are valid uses cases for voice control even when you have most things automated or have buttons. I mean you always have your voice with you and nearly everbody can use it.
And: They aim to support as many languages as possible. Rhasspy does it and they allow everyone to contribute to support as many languagse as possible.
Seems there’s a rough plan for this! :smiley:
Had a look at the log file now just before it gets unresponsive:
Here is the MQTT error I get every 80ms
2023-02-07 04:31:14.330 ERROR (MainThread) [homeassistant] Error doing job: Exception in callback MQTT._mqtt_handle_message(<paho.mqtt.cl...xffff800d3b50>)
  File "/usr/local/lib/python3.10/asyncio/events.py", line 80, in _run
    self._context.run(self._callback, *self._args)
  File "/usr/src/homeassistant/homeassistant/components/mqtt/client.py", line 693, in _mqtt_handle_message
    self._mqtt_data.state_write_requests.process_write_state_requests()
  File "/usr/src/homeassistant/homeassistant/components/mqtt/models.py", line 267, in process_write_state_requests
    entity.async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 566, in async_write_ha_state
    self._async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 683, in _async_write_ha_state
    self.hass.states.async_set(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1512, in async_set
    state = State(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1144, in __init__
    raise InvalidStateError(
homeassistant.exceptions.InvalidStateError: Invalid state encountered for entity ID: sensor.thermostat_musikzimmer_program. State max length is 255 characters.
This one I have posted in the integrations thread already.
But after a couple of hours this happens and then the log ends
2023-02-07 04:54:20.385 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server homeassistant.local:1883 (16)
2023-02-07 04:58:32.615 WARNING (KNX Interface) [xknx.log] Received DisconnectRequest from tunnelling server.
2023-02-07 05:50:14.620 WARNING (KNX Interface) [xknx.log] Received DisconnectRequest from tunnelling server.
2023-02-07 06:03:31.525 WARNING (MainThread) [xknx.cemi] Could not send CEMI frame: Sending telegram failed. No active communication channel. for <CEMIFrame code="L_DATA_REQ" src_addr="IndividualAddress("15.15.12")" dst_addr="GroupAddress("0/0/4")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />
2023-02-07 06:03:31.632 WARNING (MainThread) [xknx.log] Sending telegram failed. No active communication channel.
2023-02-07 06:03:31.724 WARNING (MainThread) [xknx.cemi] Could not send CEMI frame: Sending telegram failed. No active communication channel. for <CEMIFrame code="L_DATA_REQ" src_addr="IndividualAddress("15.15.12")" dst_addr="GroupAddress("0/0/10")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />
2023-02-07 06:03:31.732 WARNING (MainThread) [xknx.log] Sending telegram failed. No active communication channel.
2023-02-07 06:03:32.361 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 0/0/4
2023-02-07 06:03:32.450 WARNING (MainThread) [xknx.log] Could not sync group address '0/0/4' (Esszimmer nord-ost - Position)
2023-02-07 06:03:32.452 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 0/0/10
2023-02-07 06:03:32.453 WARNING (MainThread) [xknx.log] Could not sync group address '0/0/10' (Esszimmer ost - Position)
2023-02-07 06:03:42.299 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2023-02-07 06:03:42.617 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_mosquitto:
2023-02-07 06:03:42.635 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/45df7312_zigbee2mqtt/stats request
2023-02-07 06:03:42.638 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 45df7312_zigbee2mqtt:
2023-02-07 06:03:42.640 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_vscode/stats request
2023-02-07 06:03:42.642 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_vscode:
2023-02-07 06:04:56.192 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 06:05:47.391 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.fritz_box_7590_wi_fi_osre_2_4ghz is taking over 10 seconds
2023-02-07 06:05:47.456 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.fritz_box_7590_wi_fi_osre_5ghz is taking over 10 seconds
2023-02-07 06:05:47.457 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.fritz_box_7590_wi_fi_osre_gast is taking over 10 seconds
2023-02-07 06:05:47.458 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 06:05:47.459 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating fritz binary_sensor took longer than the scheduled update interval 0:00:30
2023-02-07 06:05:47.460 WARNING (MainThread) [homeassistant.components.switch] Updating fritz switch took longer than the scheduled update interval 0:00:30
2023-02-07 06:05:47.462 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 06:06:31.893 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 06:23:48.846 WARNING (KNX Interface) [xknx.log] Received DisconnectRequest from tunnelling server.
2023-02-07 06:57:01.180 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.fritz_box_7590_link_upload_noise_margin is taking over 10 seconds
2023-02-07 06:57:20.091 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.fritz_box_7590_wi_fi_osre_2_4ghz is taking over 10 seconds
2023-02-07 06:57:32.041 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.fritz_box_7590_wi_fi_osre_5ghz is taking over 10 seconds
2023-02-07 06:57:45.024 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.fritz_box_7590_wi_fi_osre_gast is taking over 10 seconds
2023-02-07 06:58:27.649 WARNING (MainThread) [homeassistant.components.switch] Updating fritz switch took longer than the scheduled update interval 0:00:30
2023-02-07 06:58:38.628 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 06:59:26.534 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.fritz_box_7590_link_upload_noise_margin (<class 'homeassistant.components.fritz.sensor.FritzBoxSensor'>) took 2.008 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+fritz%22
2023-02-07 07:00:14.317 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 07:00:14.895 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating fritz binary_sensor took longer than the scheduled update interval 0:00:30
2023-02-07 07:00:15.256 WARNING (MainThread) [homeassistant.components.switch] Updating fritz switch took longer than the scheduled update interval 0:00:30
2023-02-07 07:00:15.438 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 07:00:18.986 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from supervisor (172.30.32.2). Requested URL: '/api/config'. (HomeAssistantSupervisor/2023.01.1 aiohttp/3.8.3 Python/3.10)
2023-02-07 07:00:19.455 ERROR (MainThread) [homeassistant.components.homeassistant_alerts] Timeout fetching homeassistant_alerts data
2023-02-07 07:00:19.699 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 0/0/4
2023-02-07 07:00:19.719 WARNING (MainThread) [xknx.log] Could not sync group address '0/0/4' (Esszimmer nord-ost - Position)
2023-02-07 07:00:19.722 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 0/0/10
2023-02-07 07:00:19.725 WARNING (MainThread) [xknx.log] Could not sync group address '0/0/10' (Esszimmer ost - Position)
2023-02-07 07:00:33.768 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_vscode/stats request
2023-02-07 07:00:36.002 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_vscode:
2023-02-07 07:00:36.822 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2023-02-07 07:00:37.301 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_mosquitto:
2023-02-07 07:00:37.774 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/45df7312_zigbee2mqtt/stats request
2023-02-07 07:00:38.107 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 45df7312_zigbee2mqtt:
2023-02-07 07:00:39.233 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 0/0/16
2023-02-07 07:00:39.870 WARNING (MainThread) [xknx.log] Could not sync group address '0/0/16' (Esszimmer süd-ost - Position)
2023-02-07 07:00:40.601 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 0/0/22
2023-02-07 07:00:41.287 WARNING (MainThread) [xknx.log] Could not sync group address '0/0/22' (Esszimmer süd - Position)
2023-02-07 07:00:43.955 ERROR (MainThread) [homeassistant.components.hassio.handler] /addons/45df7312_zigbee2mqtt/changelog return code 500
2023-02-07 07:00:44.257 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch changelog for 45df7312_zigbee2mqtt:
2023-02-07 07:00:55.287 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/changelog request
2023-02-07 07:00:55.859 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch changelog for core_mosquitto:
2023-02-07 07:01:07.991 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 3/0/9
2023-02-07 07:01:08.585 WARNING (MainThread) [xknx.log] Could not sync group address '3/0/9' (Bad süd-ost - Position)
2023-02-07 07:01:13.938 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 07:01:17.625 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 3/0/15
2023-02-07 07:01:18.183 WARNING (MainThread) [xknx.log] Could not sync group address '3/0/15' (Bad süd - Position)
2023-02-07 07:01:18.544 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 3/0/21
2023-02-07 07:01:18.936 WARNING (MainThread) [xknx.log] Could not sync group address '3/0/21' (Bad süd-west - Position)
2023-02-07 07:03:20.580 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 07:03:52.861 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 07:04:38.198 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.fritz_box_7590_wi_fi_osre_5ghz is taking over 10 seconds
2023-02-07 07:04:39.208 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.fritz_box_7590_wi_fi_osre_gast is taking over 10 seconds
2023-02-07 07:05:36.909 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating fritz binary_sensor took longer than the scheduled update interval 0:00:30
2023-02-07 07:05:37.035 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 07:05:37.058 ERROR (MainThread) [homeassistant.components.fritz.common] Unexpected error fetching fritz-192.168.178.1-coordinator data: Unable to perform operation. 401 Unauthorized (ERR_NONE)401 UnauthorizedERR_NONEWebserver Tue, 07 Feb 2023 06:05:30 GMT
  File "/usr/local/lib/python3.10/site-packages/fritzconnection/core/soaper.py", line 140, in raise_fritzconnection_error
    root = etree.fromstring(response.content)
  File "/usr/local/lib/python3.10/xml/etree/ElementTree.py", line 1342, in XML
    parser.feed(text)
xml.etree.ElementTree.ParseError: mismatched tag: line 1, column 156
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 239, in _async_refresh
    self.data = await self._async_update_data()
  File "/usr/src/homeassistant/homeassistant/components/fritz/common.py", line 243, in _async_update_data
    await self.async_scan_devices()
  File "/usr/src/homeassistant/homeassistant/components/fritz/common.py", line 470, in async_scan_devices
    dev_info.wan_access = await self._async_get_wan_access(
  File "/usr/src/homeassistant/homeassistant/components/fritz/common.py", line 330, in _async_get_wan_access
    wan_access = await self.hass.async_add_executor_job(
  File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
  File "/usr/local/lib/python3.10/site-packages/fritzconnection/core/fritzconnection.py", line 378, in call_action
    return self.soaper.execute(service, action_name, arguments)
  File "/usr/local/lib/python3.10/site-packages/fritzconnection/core/soaper.py", line 259, in execute
    return handle_response(response)
  File "/usr/local/lib/python3.10/site-packages/fritzconnection/core/soaper.py", line 241, in handle_response
    raise_fritzconnection_error(response)
  File "/usr/local/lib/python3.10/site-packages/fritzconnection/core/soaper.py", line 150, in raise_fritzconnection_error
    raise FritzConnectionException(msg)
fritzconnection.core.exceptions.FritzConnectionException: Unable to perform operation. 401 Unauthorized (ERR_NONE)401 UnauthorizedERR_NONEWebserver Tue, 07 Feb 2023 06:05:30 GMT
2023-02-07 07:07:22.281 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 07:07:58.289 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 07:08:00.217 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating fritz binary_sensor took longer than the scheduled update interval 0:00:30
2023-02-07 07:08:04.719 WARNING (MainThread) [homeassistant.components.switch] Updating fritz switch took longer than the scheduled update interval 0:00:30
2023-02-07 07:08:05.386 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 07:08:21.411 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2023-02-07 07:08:22.991 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2023-02-07 07:08:24.027 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2023-02-07 07:08:26.227 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2023-02-07 07:08:29.885 ERROR (MainThread) [homeassistant.components.hassio] Error fetching hassio data: Error on Supervisor API:
2023-02-07 07:08:35.041 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating fritz binary_sensor took longer than the scheduled update interval 0:00:30
2023-02-07 07:09:04.039 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 07:09:59.225 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 07:10:05.300 WARNING (MainThread) [homeassistant.components.switch] Updating fritz switch took longer than the scheduled update interval 0:00:30
2023-02-07 07:10:09.475 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 07:12:38.517 WARNING (KNX Interface) [xknx.log] Received DisconnectRequest from tunnelling server.
2023-02-07 07:13:18.405 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.fritz_box_7590_wi_fi_osre_2_4ghz is taking over 10 seconds
2023-02-07 07:13:23.404 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.fritz_box_7590_wi_fi_osre_5ghz is taking over 10 seconds
2023-02-07 07:13:29.042 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.fritz_box_7590_wi_fi_osre_gast is taking over 10 seconds
Looks to me like everything is failing and running into timeouts until it stops eventually.
The total runtime from restart to end of logfile is about 10 hours.
And it happend again, after 11 hours runtime
here are its last minutes:
2023-02-07 18:03:51.368 ERROR (MainThread) [homeassistant] Error doing job: Exception in callback MQTT._mqtt_handle_message(<paho.mqtt.cl...xffff78fa2420>)
    state = State(
homeassistant.exceptions.InvalidStateError: Invalid state encountered for entity ID: sensor.thermostat_buro_program. State max length is 255 characters.
2023-02-07 18:03:55.402 ERROR (MainThread) [homeassistant] Error doing job: Exception in callback MQTT._mqtt_handle_message(<paho.mqtt.cl...xffff79f7da10>)
    state = State(
2023-02-07 18:22:59.241 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating fritz binary_sensor took longer than the scheduled update interval 0:00:30
2023-02-07 18:23:00.870 WARNING (MainThread) [homeassistant.components.switch] Updating fritz switch took longer than the scheduled update interval 0:00:30
2023-02-07 18:23:02.617 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 18:23:04.731 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.fritz_box_7590_wi_fi_osre_2_4ghz is taking over 10 seconds
2023-02-07 18:23:06.210 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.fritz_box_7590_wi_fi_osre_5ghz is taking over 10 seconds
2023-02-07 18:23:06.934 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.fritz_box_7590_wi_fi_osre_gast is taking over 10 seconds
2023-02-07 18:23:16.263 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 18:23:28.865 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server homeassistant.local:1883 (16)
2023-02-07 18:23:36.268 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server homeassistant.local:1883 (16)
2023-02-07 18:24:33.409 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for climate.temp_eg_bathroom (<class 'homeassistant.components.mqtt.climate.MqttClimate'>) took 1.298 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
2023-02-07 18:24:51.023 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for climate.temp_eg_kitchen (<class 'homeassistant.components.mqtt.climate.MqttClimate'>) took 0.424 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
2023-02-07 18:25:04.842 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for climate.temp_eg_dining (<class 'homeassistant.components.mqtt.climate.MqttClimate'>) took 1.191 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
2023-02-07 18:25:35.749 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for climate.temp_eg_child (<class 'homeassistant.components.mqtt.climate.MqttClimate'>) took 6.078 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
2023-02-07 18:26:07.213 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for climate.temp_eg_livingroom (<class 'homeassistant.components.mqtt.climate.MqttClimate'>) took 4.412 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
2023-02-07 18:26:53.752 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for climate.temp_ug_roomwest (<class 'homeassistant.components.mqtt.climate.MqttClimate'>) took 4.271 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
2023-02-07 18:27:28.994 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for climate.temp_ug_bedroom (<class 'homeassistant.components.mqtt.climate.MqttClimate'>) took 3.887 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
2023-02-07 18:27:52.477 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for climate.temp_ug_bathroom (<class 'homeassistant.components.mqtt.climate.MqttClimate'>) took 1.963 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
2023-02-07 18:28:16.680 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for climate.temp_ug_child (<class 'homeassistant.components.mqtt.climate.MqttClimate'>) took 1.250 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
2023-02-07 18:28:40.127 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for climate.temp_ug_washroom (<class 'homeassistant.components.mqtt.climate.MqttClimate'>) took 1.021 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
2023-02-07 18:30:15.711 WARNING (MainThread) [homeassistant.components.sensor] Updating fritz sensor took longer than the scheduled update interval 0:00:30
2023-02-07 18:40:05.077 WARNING (KNX Interface) [xknx.log] Received DisconnectRequest from tunnelling server.
I see if i can find the log level and set it to critical. Then we see if it’s the large number of logs written that causes the issue
Thank you for help, it’s working again.
Is anyone else still having issues with this release of HA and the Conbee2 stick. It sees it in the device page but will not load. I tried passing through the entire usb controller instead of the stick and that still did not work. Everything works perfect in 2023.1 but as soon as I update my whole ZigBee network is dead, changing ports, trying to reconfigure the radio, nothing works. I have again restored a backup to get back up and working but I find it hard to believe this issue is limited to me.
Some specifics to my current setup. I am running unraid and passing the entire usb controller through to the VM. The conbee2 stick is being detected and working great in 2023.1 but in 2023.2 ZHA wont start up.
I ordered a skyconnect with the hope that might be a better long term solution then the conbee2 but it bothers me this update broke it.
Seems you are not the only one having issues:
it seems that your sensor.thermostat_buro_program is receiving a state exceeding the limit of 255 characters.
This is probably causing the integration to crash.
I found this on the forum:
that might help ?
broke my ZHA too… thanks for the tip
Update 2023.2.3 broke my HA, some integrations seem to be stuck during the start. Lost bluetooth comms (RuuviTag, Xiaomi), Panasonic Comfort Cloud, Emporia energy integrations. Tried to downgrade back to 2023.2.2 but it got even worse. Restore from backup did not work. After restore tried to reboot but configuration.yaml (and others) are not found anymore. Hope I can reinstall the old version and restore the backup. Running HA OS in mini computer. Had many updates before without major issues.
you should check your log files.
From the description you provided (with configuration.yaml and others are not found) I think, that there are other reasons why your system broke…
Also, please provide some information about your Hardware Setup - like available disk space, what ā€œmini computerā€ you are using, and so on.
Phrasing it as ā€˜If you have switched from the default sqlite DB to MariaDB then…’ would have avoided the confusion for us tiny-bit-above-average users who do read release notes…
Thanks, sounds a bit different then my issue but will hope fixing it resolves mine too. Will have to try this latest update and check what errors I am getting again and compare.
I had this thought as well.
The question is: why is the message so much longer since one of these updates?
I Rember the messages for my thermostats being much shorter when I installed them.
I have set the log level to critical.
But even with only 1 message in the log (somehow 1 info message got logged right after startup) , HA still got unresponsive after about the same amount of time.
So I assume it is not the writing of the logs to file.
I don’t really know - it can’t be the update, since the message comes from the sensor - or at least, it is the MQTT payload…
You could probably check with MQTT Explorer what the payload of the message is… Maybe, there’s the root cause of this?
As far as I understand from the linked topics, the limitation in size does not came just with this update
I think the issue is the latest Zigbee2MQTT update, that for some reason packs way mor things into the message for this sensor now. Hopefully they fix that soon, Or can I go back to an older version of an addon?
hm… I don’t know, since I am not using Zigbee2Mqtt - but as far as I know, Z2Mqtt is a custom_component, or?
Did they update the integration at the same time?
If it is a custom component, you could roll back to a previous release within HACS…
There, you can select which version you want to download.
BUT:
I would expect:
If they have increased the information the sensor provides, you should probably consider to break the payload into sensor values + attributes…
I think, that should be the better option… ?!
