Edit: You have to enable the conversation agent in the “Google Assistant SDK” integration settings. Maybe that should be explained in the Assist documentation
It Seems like the “listening” dialog, don’t work in this pop-up, or the “function/app-js” doesn’t get through … something is “missing” in FF, whether that do to the “enclosure” in the pop-up or what/why it’s “missing” im not that familiar with …
So i guess your not “missing” anything, and soon this will most likely also be solved
soon enough this might come in “handy” when/if we get so far so we start to build up our own locale/private commands, it a Tool, not a Dialog Window you can use to “talk to your self”
I’m in the same boat as perjury1 above. The Synology has only one version of MariaDB available. My question is this: Will this update degrade the performance I currently have in 10.3.29, or am I already effected by the problem? (I’m trying to decide if I can upgrade HA Core or not, my total DB size is ~250MB)
FWIW: The MariaDB bug only says 10.5.9, 10.5.13 are affected (and presumably newer). I’m not sure that I trust completely, because it only mentions the 10.5.9, 10.5.13 versions whereas the release notes specify several new versions that fix it. https://jira.mariadb.org/browse/MDEV-25020
Any version below 10.6.9 has known reported performance problems (not a single issue but the issue you mention above is the likely the worst one for most installs). It’s not a new problem but the MariaDB add on was only updated yesterday to resolve it which is reason for the increased awareness.
250MB should be fine though as it’s likely not enough data to trigger any of the known issues.
Question regarding hassil after trying it.
I wanna be able to ask “Is my water heater on?” and have it respond without doing anything.
Would asking about the state of something be classified as an intent or conversation?
