It’s not a step back. The group entities (i.e. group.abc) still show the entity list.
The new groups, light.group_xyz, etc, do not have the ability to show the entity list (and never have had this ability). That does not mean this will not come in the future. Just realize that the functionality was not taken away, it still exists. It just hasn’t been added to the new groups.
I don’t believe you can get both in the same view outside of old school groups. To be honest, I’m very surprised there was even a light control for old school groups. I’ve never made an old school group comprised of just lights.
I tried to find changelog entry that could explain behavior I’m noticing after upgrading from 2023.3.5 to 2023.3.6.
I receive sensor values over MQTT from Tasmota device. HA is acting as MQTT broker with mosquitto integration.
Sensor values are received with 10 second interval and I can confirm this with MQTT explorer on broker.
Until version 2023.3.5 sensor values were stored in HA database every 10 seconds, even value didn’t change.
After upgrading to 2023.3.6 sensor value is stored in database only if it changes.
What change caused this behavior and could this be fixed so that all values received would be stored in database?
This can be seen also on HA sensor view. It now says for example “1 minute ago” rather than refreshing every 10 seconds as before.
Hi, is there a way how to revert “dialogs” to previous version? I find them totally confusing and counterproductive. For example when I want to change light color temperature I have to open the light and then click on the color palette and then I can change the color. It is much slower approach then with previous versions.
The same with history - I liked seein the history of the switch right on the page when I opened it. Now I have to open the switch and search tiny button “history” and here it is.
Slower and less transparent.
I would understand this to be available as na option primary for wear (watches) but it makes no sense for desktop or mobile. I don’t think I am the only one that would appreciate a switch between old and new style. Pretty please?
I find the new dialog really awful.
The text based tabs were perfect as they were and easy to navigate from one to another, now i have to click back to go from one to the other.
Also why would i need that big of a slider? I really liked the old thin horizontal slider.
Also if having an RGB lamp i have to go into a separate menu to change color… what a god-awful decision to make
Also for my new ikea air cleaner i cant select the builtin presets as i could before, which just completely throws me off. now theres a standby icon, what does that do? i really dislike having icons as a complete substitute for text.
sure icons are nice to have… as a compliment for the text for easier recognition, but icons dont tell you exactly what the do.
So please give us, that want the old UI back, the option to actually use it
yes, the new more-info seems like regression. You press a switch in an entity card only to show the same switch larger. Now there is a second click involved to get the actual useful information, namely the history. I can’t seem to find an easy way to make the history view the default one.
Has anyone found a way to revert back to the old, more useful light dialogues? Really sick of the bad usability, additional clicks with the new light dialogs
Well, that would not be a sustainable solution, as it would mean you can never update HA again. I was rather hoping there would be something more along the line of a mod, plugin, integration etc.
Samaba add-on will allow you to access the backup directory to offload backups. You can add notations to the file descriptor then. It is what I use. Just in case the EMAC or the SSD start having issues.
