Hello there… I’ve stumpled over a modbus tcp issue, all ideas and tipps appreciated !
Setup: HA 2023.7.3 (docker), a Alpha-ESS Smile T10 solar inverter/battery and a openwb wallbox.
the openwb connects via modbus/tcp to the Alpha-ESS to check for available PV power etc. works fine, and I can still see port 502 on the Alpha-ESS as “open” and do a manual “mbpoll” to read data.
I started to monitor the Alpha-ESS with HA (using snitzelweck92 / homeassistant_alphaess_modbus_tcp ). This works great, but as soon as HA is using this modbus setup, the openwb can not access data from the Alpha-ESS anymore, and a nmap shows that port 502 on the Alpha-ESS is closed…
As soon as HA is stopped, the port 502 is again “open” and openwb picks up readings again.
My guess is that HA does not close the modbus connection in between polls (every 20 sec). Are there any timings/settings that can be used to close the modbus connection directly after a poll ?
my modbus config is:
modbus:
- name: modbuspvsystem
type: tcp
host: !secret alphaess_modbus_host_ip
port: !secret alphaess_modbus_host_port
message_wait_milliseconds: 0 # waittime between 2 messages
timeout: 1 # timeout in seconds before connection is closed
retry_on_empty: true
delay: 0 # delay in seconds at startup
#definition of sensors
sensors:
# BATTERY
#SOC
- name: Alpha ESS SOC Battery
unique_id: PV_SOC_Battery
slave: !secret alphaess_modbus_slaveId
address: 258
input_type: holding
count: 1
data_type: int16
unit_of_measurement: "%"
device_class: battery
state_class: measurement
scan_interval: 20
scale: 0.1
precision: 2
