Not sure why it’s being characterized as “trickery”.
What petro suggested leverages the strengths of a Trigger-based Template Sensor, namely the ability to set its state, and/or attributes, to whatever you want via any kind of trigger. In other words, the example is using a Trigger-based Template Sensor the way it’s meant to be used.
The example ‘publishes’ the data via a custom event:
The Trigger-based Template Sensor uses the received data to set the value of one of its attributes. Easy-peasy (and that value survives a restart).
FWIW, what petro suggested is something I first discovered from these examples by CentralCommand and TheFes:
It’s a pattern I have also employed to fulfill other applications that require storing a value in a sensor’s attribute (with and without the use of custom events). Examples:
Message Queue
Last Ten Motion Detectors
Bad Shutdown Sensor
Song History
It’s a useful design pattern and far from being ‘trickery’.
Your proposed new service call, input_text.set_attribute, would probably need to be called multiple times, once for each attribute you wanted to set … unless it supported setting multiple attributes at once. Here’s a mockup of what the service call could look like:
The main difference is that creating an Input Text is admittedly easier than a Trigger-based Template Sensor. Unless there’s an existing Feature Request, feel free to post a request for this new service call.
