I am operating Home Assistant on a raspi 4 - 64 bit, I recently update my Home Assistant Core instance. As soon as it restarted I was greeted with error after error regarding my configuration file and I am unable to locate where the config file is having the issue. I tried recovering from a full backup, however when I do my HA instance just hangs and never fully reboots, I have to unplug power and start back from square one. I have either disabled or deleted all instances of custom integrations from HA just to make sure that it’s not something regarding an incompatibility issue. I have attempted ‘Repair’ but it tells me that there is nothing wrong, however I cannot Restart HA due to a config file error, I can however Reboot.
Line 2 is the error that is popping up, discovery integration error.
Here are my log files, hopefully someone will be able to point me in the right direction. Thank you.
2023-08-04 05:51:51.074 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-08-04 05:52:15.189 ERROR (MainThread) [homeassistant.setup] Setup failed for discovery: Integration not found.
2023-08-04 05:52:18.292 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Z-Wave JS' for zwave_js integration not ready yet: None; Retrying in background
2023-08-04 05:52:30.628 ERROR (MainThread) [homeassistant.components.mqtt.client] Failed to connect to MQTT server due to exception: [Errno -5] Name has no usable address
2023-08-04 05:52:32.093 WARNING (MainThread) [homeassistant.components.vizio.media_player] Lost connection to 10.0.20.108:7345
2023-08-04 05:52:36.633 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Piper' for wyoming integration not ready yet: Unable to connect; Retrying in background
2023-08-04 05:52:38.544 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform dlna_dmr is taking over 10 seconds.
2023-08-04 05:52:42.190 WARNING (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0x3E38:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>')]
2023-08-04 05:52:42.433 WARNING (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0x6627:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>')]
2023-08-04 05:52:42.493 WARNING (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0x3E38:1:0x0008]: async_initialize: all attempts have failed: [DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>')]
2023-08-04 05:52:42.681 WARNING (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0x3E38:1:0x0702]: async_initialize: all attempts have failed: [DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>')]
2023-08-04 05:52:43.785 WARNING (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0x3E38:1:0x0500]: async_initialize: all attempts have failed: [DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>')]
2023-08-04 05:52:48.094 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.cellar_sensor_1_air_temperature with value unavailable excluded from calculation
2023-08-04 05:52:48.104 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.cellar_sensor_2_air_temperature with value unavailable excluded from calculation
2023-08-04 05:52:48.106 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.cellar_sensor_3_air_temperature with value unavailable excluded from calculation
2023-08-04 05:52:48.108 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.cellar_sensor_2_humidity with value unavailable excluded from calculation
2023-08-04 05:52:48.110 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.cellar_sensor_3_humidity with value unavailable excluded from calculation
2023-08-04 06:00:59.692 ERROR (MainThread) [homeassistant.components.github] An error occurred while processing new events - Request exception for 'https://api.github.com/repos/esphome/esphome/events' with - Cannot connect to host api.github.com:443 ssl:default [Try again]
2023-08-04 06:00:59.704 ERROR (MainThread) [homeassistant.components.github] An error occurred while processing new events - Request exception for 'https://api.github.com/repos/home-assistant/core/events' with - Cannot connect to host api.github.com:443 ssl:default [Try again]
