After upgrading I noticed that supervisor is really slow on starting on my Odroid N2+. Does anyone else here have that?
Yes you understand correctly.
You also need to create a manifest. Core cards do not have this. Custom cards require it.
EDIT: You have to create a version number in the manifest.
I tried to install the 2023.9.0 update (using HAOS Intel PC) but it did not work. It didn’t restart or make any changes. I tried again, same thing. Then I restarted HA and now I get error in Supervisor “failed to set up”. I restored fullback but still the same problem, restored another full backup from last night and still the same. The system was working fine and HA restarted without issues yesterday. So what now? How can I fix this?
Supervisor debug log shows this:
2023-09-07 10:37:23.285 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ssh_command which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-07 10:37:23.285 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration browser_mod which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-07 10:37:23.286 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration smartir which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-07 10:37:23.286 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nodered which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-07 10:38:23.735 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: hassio
2023-09-07 10:39:23.801 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: hassio
2023-09-07 10:39:24.078 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Supervisor for hassio
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 388, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 651, in async_setup_entry
await coordinator.async_config_entry_first_refresh()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 251, in async_config_entry_first_refresh
await self._async_refresh(
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 959, in _async_refresh
await self.hassio.refresh_updates()
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 36, in _wrapper
data = await funct(*argv, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 534, in send_command
request = await self.websession.request(
File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 560, in _request
await resp.start(conn)
File "/usr/local/lib/python3.11/site-packages/aiohttp/client_reqrep.py", line 899, in start
message, payload = await protocol.read() # type: ignore[union-attr]
File "/usr/local/lib/python3.11/site-packages/aiohttp/streams.py", line 616, in read
await self._waiter
asyncio.exceptions.CancelledError: Global task timeout
2023-09-07 10:39:24.085 WARNING (MainThread) [homeassistant.bootstrap] Setup timed out for stage 1 - moving forward
Cheers…every day a school day
Actually I remembered incorrectly, you need to add a version number to the manifest file, see: No 'version' key in the manifest file for custom integration 'environment_canada - #7 by tom_l
just to decide whether this is a bug or not:
As Buienradar integration only supports a daily forecast, shouldnt the options for Hourly and twice daily be hidden?
Currently it returns the red error, would be nice if these simply wouldn’t be presented.
btw, note the Dagelijks (daily) is translated, and the other 2 aren’t. Might be an indication already for their availability?
Preview - may be done by Dev tools - Templates in most cases (exceptions - using secrets and anchors, using “this” variable - but it may be easily sorted out).
And you do not need to restart - just reload templates.
Can you use yaml anchors in UI for repeating code? No.
Can you use secrets? Not sure.
Can you keep a set of 10 sensors in a package along with helpers and automations and easily exclude it from HA ? No.
So, - this is not as advanced as yaml.
Can anybody confirm that File editor add-on is broken? I get an “500 Internal Server Error” inside UI and a bunch of exceptions in the supervisor log:
23-09-07 10:17:49 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.11/site-packages/sentry_sdk/integrations/aiohttp.py", line 139, in sentry_app_handle
reraise(*_capture_exception(hub))
File "/usr/local/lib/python3.11/site-packages/sentry_sdk/_compat.py", line 60, in reraise
raise value
File "/usr/local/lib/python3.11/site-packages/sentry_sdk/integrations/aiohttp.py", line 129, in sentry_app_handle
response = await old_handle(self, request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 185, in block_bad_requests
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 201, in system_validation
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 220, in token_validation
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 280, in core_proxy
File "/usr/src/supervisor/supervisor/api/ingress.py", line 141, in handler
return await self._handle_request(request, addon, path, session_data)
File "/usr/src/supervisor/supervisor/api/ingress.py", line 217, in _handle_request
async with self.sys_websession.request(
File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 1141, in __aenter__
self._resp = await self._coro
File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 558, in _request
resp = await req.send(conn)
File "/usr/local/lib/python3.11/site-packages/aiohttp/client_reqrep.py", line 670, in send
await writer.write_headers(status_line, self.headers)
File "/usr/local/lib/python3.11/site-packages/aiohttp/http_writer.py", line 129, in write_headers
buf = _serialize_headers(status_line, headers)
File "aiohttp/_http_writer.pyx", line 132, in aiohttp._http_writer._serialize_headers
_safe_header(to_str(val))
File "aiohttp/_http_writer.pyx", line 109, in aiohttp._http_writer.to_str
raise TypeError("Cannot serialize non-str key {!r}".format(s))
TypeError: Cannot serialize non-str key None
Templates cannot be created without programming. Maybe in future UI you will have possibilities for operations like “calc a sum for a list of entities” (like it is available for groups).
Ofc, a trend to “simplify” should not cause “remove a functionality “.
I just went and tried and yes I can now change the source entity via the GUI. My mind might be going but I am sure that when I set up some utility meters a few months ago - and then changed the naming conventions on source sensors, I had to dig into the core.config file.
I have learned something new today! Thank you.
Agree. Had to go back to previous version. Seems like modbus terminates after a few minutes.
It is python, no compiling needed.
I can confirm it is NOT broken for me.
All you have to do is copy the repository to your custom component folder, preserving any sub-folder structure, add any version number to the manifest file (see my post above) then restart HA.
Are you on 3.17.3 or 3.1.7? Have you upgraded and it no longer works, or just looking at the breaking changes at this point?
Can you curl http://envoy.local/api/v1/production
from the command line?
For me it returns the same data as the integration, so I am assuming that 3.17.3 is still supported as 17 > 9 i.e. it is 17 and not 1 and 7. They cited needing to use web scraping for versions below 3.9 as the reason for withdrawing support, so I suspect that this will still work after upgrading, although I haven’t upgraded yet and if it doesn’t it should be possible to create some RESTful sensors to return the same data as the integration, which I am actually quite tempted to do anyway, as it is then not reliant on the integration.
You can check your firmware version by going to http://envoy.local
Right, thanks for clarifying. For me, it works fine. Hopefully it’ll work for you too maybe with a few iterations.
This depends on a particular setup and a user’s needs and skills.
See a list of “no” in my post before.
So, a UI-based template sensors is a good ADDITIONAL feature (mainly for beginners), not a full replacement.
Regarding the Weather Forecast Service how do get forecast in the template weather now? If the forecast attribute will not be present, then it turns out that I will not be able to use it in the template weather, and the service cannot be called there. Or will I have to make crutches, get forecast in other entities and then substitute it into the template?
