It definitely does.
Sorry if not the right place for this but Iāve narrowed down my problem to only be happening on 2023.9 as per this thread
After reverting to 2023.8.4 the problem goes away. Any idea on this anyone?
2023.9.3 broke several things for me even after several complete reboots:
Lost Switchbot entities as āunavailableā that were working, BlueTooth scanner failure
Lost Settings / System / Backups as āTroubleshootingā
Lost Settings / Add-Ons as āTroubleshootingā
Lost Node Red, Terminal, File Editor, eWeLink Smart Home, ESPHome, etc. as āUnable to load the panel source: /api/hassio/app/entrypoint.jsā
Iām just a rookie so Iāll have to read up on issues and how to resolve them.
The best backup is a copy of the āconfigā folder at least in the container installation.
The new climate widget is a problematic UX. It took approximately 10 seconds after updating to the new version before my swipe to scroll the page to accidentally changed the temperature setting from 71 F to 65 F (the minimum cooling temperature).
Do we have the option to use a non-graphical option so that we can avoid this undesirable user experience?
Try a plain entity card (note the singular).
Upgrading from 2023.9.2 ā 2023.9.3 greatly increased CPU usage. Iāve tried rebooting with no change. Anyone else experiencing the same?
I do not run any heavy load addons. I have all my zwave and zigbee and mqtt running on separate server so my CPU usage is mainly just Home Assistant itself.
My CPU on a Home Assistant Blue hardware runs at a 2-5% CPU load. Always did. Restarting HA only restarts the HA container but other Addons keep running. Either reboot the host or try to stop and start each Addon one by one while monitoring the CPU load. That will also give you a datapoint for later debug. A high load for hours can happen when the database has to be reformatted. That normally does not happen at a patch release.
Also note that in a terminal session with HA you have htop available which can show if specific task is insane
Thanks for the info. My HA normally runs about 5-7% CPU. I have done a restart of the host with no change. Iāll start disabling add-ons to see what I can find there.
Update: I just noticed that as of about 15 minutes ago, the CPU has returned to a normal level (5-7%). I havenāt changed anything.
No change in CPU utilisation here.
Try disabling your 3rd party integrations one by one and see if that identifies the culprit.
So all the things that needed to be done have now finished. Thatās the problem with these restarts - you constantly break the tasks running, and HA needs to start a new run every time⦠I know, I know, this is kind of a chicken egg problem, because how would you know to let your install run for hours with a high loadā¦
I had this a few times, and for now, Iāll just let me install/update run, even with higher loads and wait for at least one week. If nothing changes, itās early enough to ask, if the load goes down, even mariadb seems to be updated.
Since updating 2 nodes to 2023.9.3 from 2023.8.4 Iāve lost the sidebar. Itās set to auto-collapse and when I clip on cake, I get a blank sidebar. Itās Safari on a Mac if this helps.
Have you tried clearing your web browser cache?
Iām hesitant to do that as I have so many sites in the cache. However, I guess Iāll have to - unless somebody knows how to clear a single siteās caches.
UPDATE: Clearing the cache made no difference. A private window gives the same result
FWIW: Itās OK on Firefox
For next time: you can open the browserās dev tools and disable the cache for that page. Then reload, re-enable and close the dev window.
If itās a cookie-related issue you can selectively clear cookies too. Google for your specific browserās instructions.
Just to close this off. I found that there was a content blocker preventing the display of the sidebar. No idea where it came from though.
In addition to clearing the browser cache, I needed (in Safari) to reload the page without content blockers. Itās an option on the View menu if there is a blocker in place.
Yes when 2023.12 is released (first Wednesday of the month).
Yeah! Lovinā it!
Question,
HA as a line-animation in the background of the login screen.
I have tried searching for the name of the animation, I must not be using the correct queries because I havenāt been able to find anything.
Thank you very much in advance!
