I use a custom font that is displayed everywhere and in all cards. However, the font of the new heading cards is hard-coded to "Roboto“. It would be great if this could be changed so that there is a consistent typography again.
Hi, Is anyone else getting an error as follows. Setup failed for ‘brother’: Unable to import component: No module named ‘pysnmp.hlapi.varbinds’.
Relates it seems to a module for Brother printers. Was working fine in previous September release. Running venv on ubuntu, python3.12. Thanks gb
Never mind - problem already tagged here. Brother Printer - No module named 'pysnmp.hlapi.varbinds' · Issue #125286 · home-assistant/core · GitHub.
I had to run the three steps in my venv, uninstall, then install two components at specific versions.
Case closed.
Hi all,
Another new issue post update to Oct release. I think my dingaling is broken. type object ‘RingCapability’ has no attribute ‘DING’
Would best plan be to remove then re-attach the Ring device.
UPDATE: remove/reattached failed. Then found a new issue raised an hour ago which seems to match.
Unexpected exception importing platform homeassistant.components.ring.binary_sensor
File "/srv/homeassistant/lib/python3.12/site-packages/homeassistant/loader.py", line 1264, in _load_platform
cache[full_name] = self._import_platform(platform_name)
File "/srv/homeassistant/lib/python3.12/site-packages/homeassistant/loader.py", line 1296, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File "/srv/homeassistant/lib/python3.12/site-packages/homeassistant/util/loop.py", line 200, in protected_loop_func
return func(*args, **kwargs)
File "/usr/lib/python3.12/importlib/__init__.py", line 90, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 995, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/srv/homeassistant/lib/python3.12/site-packages/homeassistant/components/ring/binary_sensor.py", line 48, in <module>
capability=RingCapability.DING,
AttributeError: type object 'RingCapability' has no attribute 'DING'
I will give this a try once i upgrade again
while i get that for you the issue is present without HA
for me it is working again since i downgraded HA to 2024.9
and my nodered is at the latest version
The yaml editor has been updated, certainly bringing the advantages of folding and alignment margins, but…
Why was the “search/search and replace” functionality removed? Can it be restored?
Why does the editor no longer signal errors in red at the bottom left as it did in the previous version? Can this functionality also be restored?
EDIT:
I just realized that what I described above happens at the URLs:
Instead the editor continues to work as before using the URL:
Is there a valid reason for this or is it a problem with my PC?
Thank you
Sounds like you need to clear your browser cache for the non- working URLs?
Also, you should edit your post to disguise your duckdns address if that is your actual URL.
2024.10 Broke my Bluesound integration, after restore to 2024.9.3 all works again
in 2024.10 no status from Bluesound players in HA and Automation to Bluesound from HA, do noting
I did a rollback to 2024.08.3 (Windows Virtualbox) as I discovered that the Tibber integration still wasn’t fixed, but it screwed everything up for me. In configuration.yaml scenes.yaml was called but the file didn’t exist. I removed the line and everything seemed to start up again. Unfortunately, HACS was gone and I restalled it and several integrations connected. Most of them works but not all.
Nordpool was gone and now reinstalled. I can read the sensors in Developers tool, but no automations or template sensors can read it.
Google backups is stuck in a loop since several days and I cannot backup from System, no matter if goolge is removed or not.
No statistic graphs reads any values.
It seems that I need to start with a clean install which will take a lot of hours. All integrations and helpers needs to start all over. Is there any way I can find an image suitable for 2024.08 as I imagine this is the reason it was screwed up in the first place?
Logs? Github issue?
Where are your logs?
Anyone else being told there’s an update but that there’s no update popup at the bottom when clicking install?
You have already updated (or it was done automatically for you).
However the update page has become rather sluggish. After installing updates I have to wait minutes for the notifications to disappear.
Thank you @noahhusby so much for the Cambridge Audio integration! I have unsuccessfully dabbled with HDMI-CEC, IR blasters and serial control to integrate our CXR-200, but this update discovered the Amp and your integration is working flawlessly.
Zigbee2MQTT + HA 2024.10.1
My zigbee action buttons also started go unknown. Press it and it sends the action then the value is blank. I believe this is because z2m sends the action text and then sends an empty string. Perhaps HA 2024.10.1 made a change in the way a sensor with an empty string is handled? They do go to unknown again after a short time.
I do use these actions in automations to alternate dim and bright on button presses. They all still function correctly. Example from logbook…
I renamed all my emoncms entities to match the old ones. Automations worked again afterwards, but the new entities have no unit of measurement and I can’t figure out how to add that back in.
Last part of the logs. A lot of errors for integrations and sensors that has been working for ages.
2024-10-07 19:13:36.476 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-07 19:13:36.478 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tapo which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-07 19:13:36.481 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tapo_control which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-07 19:13:36.481 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration frigate which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-07 19:13:36.482 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nordpool which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-07 19:13:36.482 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration easee which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-07 19:13:38.121 WARNING (MainThread) [homeassistant.components.lovelace] Lovelace is running in storage mode. Define resources via user interface
2024-10-07 19:13:38.137 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2024-10-07 19:13:41.535 WARNING (MainThread) [hass_nabucasa.cloud_api] Fetched https://alexa-api.nabucasa.com/access_token (400)
2024-10-07 19:14:02.546 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.custom_ackumulerad_arlig_forbrukning_kyl_altan (<class 'homeassistant.components.utility_meter.sensor.UtilityMeterSensor'>) is using state class 'total_increasing' which is impossible considering device class ('power') it is using; expected None or one of 'measurement'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+utility_meter%22
2024-10-07 19:14:02.550 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.custom_ackumulerad_daglig_forbrukning_kyl_altan (<class 'homeassistant.components.utility_meter.sensor.UtilityMeterSensor'>) is using state class 'total_increasing' which is impossible considering device class ('power') it is using; expected None or one of 'measurement'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+utility_meter%22
2024-10-07 19:14:02.552 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.custom_ackumulerad_manatlig_forbrukning_kyl_altan (<class 'homeassistant.components.utility_meter.sensor.UtilityMeterSensor'>) is using state class 'total_increasing' which is impossible considering device class ('power') it is using; expected None or one of 'measurement'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+utility_meter%22
2024-10-07 19:14:03.392 WARNING (MainThread) [hass_nabucasa.cloud_api] Fetched https://alexa-api.nabucasa.com/access_token (400)
2024-10-07 19:14:03.466 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
File "/usr/src/homeassistant/homeassistant/components/cloud/alexa_config.py", line 547, in _handle_entity_registry_updated
await self._sync_helper(to_update, to_remove)
File "/usr/src/homeassistant/homeassistant/components/cloud/alexa_config.py", line 487, in _sync_helper
await self.async_get_access_token()
File "/usr/src/homeassistant/homeassistant/components/cloud/alexa_config.py", line 340, in async_get_access_token
raise alexa_errors.RequireRelink
homeassistant.components.alexa.errors.RequireRelink
2024-10-07 19:14:03.534 WARNING (MainThread) [hass_nabucasa.cloud_api] Fetched https://alexa-api.nabucasa.com/access_token (400)
2024-10-07 19:14:03.542 WARNING (MainThread) [hass_nabucasa.cloud_api] Fetched https://alexa-api.nabucasa.com/access_token (400)
2024-10-07 19:14:03.547 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
2024-10-07 19:14:03.555 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
2024-10-07 19:14:03.557 WARNING (MainThread) [hass_nabucasa.cloud_api] Fetched https://alexa-api.nabucasa.com/access_token (400)
2024-10-07 19:14:03.559 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
2024-10-07 19:14:03.572 WARNING (MainThread) [hass_nabucasa.cloud_api] Fetched https://alexa-api.nabucasa.com/access_token (400)
2024-10-07 19:14:03.582 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
2024-10-07 19:14:03.584 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Home Assistant Cloud for senz
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 594, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/senz/__init__.py", line 56, in async_setup_entry
account = await senz_api.get_account()
File "/usr/local/lib/python3.12/site-packages/aiosenz/api.py", line 35, in get_account
resp = await self.auth._request("get", "Account")
File "/usr/local/lib/python3.12/site-packages/aiosenz/auth.py", line 55, in _request
access_token = await self.get_access_token()
File "/usr/src/homeassistant/homeassistant/components/senz/api.py", line 25, in get_access_token
await self._oauth_session.async_ensure_token_valid()
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 531, in async_ensure_token_valid
new_token = await self.implementation.async_refresh_token(self.token)
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 103, in async_refresh_token
new_token = await self._async_refresh_token(token)
File "/usr/src/homeassistant/homeassistant/components/cloud/account_link.py", line 142, in _async_refresh_token
new_token = await account_link.async_fetch_access_token(
File "/usr/local/lib/python3.12/site-packages/hass_nabucasa/account_link.py", line 122, in async_fetch_access_token
resp.raise_for_status()
File "/usr/local/lib/python3.12/site-packages/aiohttp/client_reqrep.py", line 1121, in raise_for_status
raise ClientResponseError(
aiohttp.client_exceptions.ClientResponseError: 500, message='Internal Server Error', url='https://account-link.nabucasa.com/refresh_token/senz'
2024-10-07 19:14:03.747 WARNING (MainThread) [hass_nabucasa.cloud_api] Fetched https://alexa-api.nabucasa.com/access_token (400)
2024-10-07 19:14:03.749 WARNING (MainThread) [hass_nabucasa.cloud_api] Fetched https://alexa-api.nabucasa.com/access_token (400)
2024-10-07 19:14:03.749 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
2024-10-07 19:14:03.751 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
2024-10-07 19:14:03.760 WARNING (MainThread) [hass_nabucasa.cloud_api] Fetched https://alexa-api.nabucasa.com/access_token (400)
2024-10-07 19:14:03.760 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
2024-10-07 19:14:03.835 WARNING (MainThread) [hass_nabucasa.cloud_api] Fetched https://alexa-api.nabucasa.com/access_token (400)
2024-10-07 19:14:03.848 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
2024-10-07 19:14:04.167 WARNING (MainThread) [hass_nabucasa.cloud_api] Fetched https://alexa-api.nabucasa.com/access_token (400)
2024-10-07 19:14:04.167 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
2024-10-07 19:14:04.183 WARNING (MainThread) [hass_nabucasa.cloud_api] Fetched https://alexa-api.nabucasa.com/access_token (400)
2024-10-07 19:14:04.184 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
2024-10-07 19:14:04.271 ERROR (MainThread) [tibber.home] Error in rt_subscribe
File "/usr/local/lib/python3.12/site-packages/tibber/home.py", line 461, in _start
data = _add_extra_data(data)
File "/usr/local/lib/python3.12/site-packages/tibber/home.py", line 419, in _add_extra_data
live_data["lastMeterProduction"] = max(0, live_data["lastMeterProduction"])
TypeError: '>' not supported between instances of 'NoneType' and 'int'
2024-10-07 19:14:04.994 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to load_default_certs with args (<ssl.SSLContext object at 0x7fdd7b62f7d0>, <Purpose.SERVER_AUTH: _ASN1Object(nid=129, shortname='serverAuth', longname='TLS Web Server Authentication', oid='1.3.6.1.5.5.7.3.1')>) in /usr/local/lib/python3.12/ssl.py, line 713: context.load_default_certs(purpose) inside the event loop; This is causing stability issues. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#load_default_certs
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 189, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 674, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 641, in run_forever
self._run_once()
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1990, in _run_once
handle._run()
File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run
self._context.run(self._callback, *self._args)
File "/usr/local/lib/python3.12/site-packages/pyeasee/easee.py", line 312, in _sr_connect_loop
await self.sr_connection.run()
File "/usr/local/lib/python3.12/site-packages/pysignalr/client.py", line 92, in run
await self._transport.run()
File "/usr/local/lib/python3.12/site-packages/pysignalr/transport/websocket.py", line 77, in run
await self._loop()
File "/usr/local/lib/python3.12/site-packages/pysignalr/transport/websocket.py", line 102, in _loop
async for conn in connection_loop:
File "/usr/local/lib/python3.12/site-packages/pysignalr/__init__.py", line 26, in __aiter__
async with self as protocol:
File "/usr/local/lib/python3.12/site-packages/websockets/legacy/client.py", line 635, in __aenter__
traceback: Optional[TracebackType],
File "/usr/local/lib/python3.12/site-packages/websockets/legacy/client.py", line 654, in __await_impl__
await protocol.handshake(
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1149, in create_connection
transport, protocol = await self._create_connection_transport(
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1173, in _create_connection_transport
transport = self._make_ssl_transport(
File "/usr/local/lib/python3.12/asyncio/selector_events.py", line 83, in _make_ssl_transport
ssl_protocol = sslproto.SSLProtocol(
File "/usr/local/lib/python3.12/asyncio/sslproto.py", line 295, in __init__
sslcontext = _create_transport_context(
File "/usr/local/lib/python3.12/asyncio/sslproto.py", line 55, in _create_transport_context
sslcontext = ssl.create_default_context()
File "/usr/local/lib/python3.12/ssl.py", line 713, in create_default_context
not sure of the Integration itself but you could always customize the entitles in your config to bring back the unit of measure Customizing entities - Home Assistant
New configuration elements for schedules
This slipped into 2024.10 under the Radar
How could this have not been considered noteworthy !?!
schedule:
light_schedule:
name: "Light schedule"
wednesday:
to: "21:00:00"
brightness: 100
color_temp: 4000
thursday:
to: "23:00:00"
brightness: 90
color_temp: 3500
There’s mileage in this - very happy to see it
The binary sensor attributes this integration provided have been replaced with sensor entities in Home Assistant 2024.4. These deprecated attributes have now been removed.
Were these replacement sensors supposed to be created automatically?
I don’t see a way to configure or enable these via the integration page either.
These are the attributes I used before:
back_extender_round_trip_time_avg:
value_template: "{{ state_attr('binary_sensor.back_extender', 'round_trip_time_avg') }}"
unit_of_measurement: 'ms'
back_extender_round_trip_time_mdev:
value_template: "{{ state_attr('binary_sensor.back_extender', 'round_trip_time_mdev') }}"
