I somewhat can’t believe that HA is getting more and more user friendly, more beautiful UI’s and yet still user is not able to see real “last_changed” when entity was changed not by HA restart.
Maybe it’s worth to take a look at it globally and finally be able to solve intentional value of last changed “while HA was online”?
Hello, after this update of 2024.10 my HA restarting any issue:
2024-10-03 09:15:16.612 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
2024-10-03 09:16:05.509 WARNING (MainThread) [supervisor.homeassistant.websocket] Connection is closed
2024-10-03 09:16:05.545 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/core/state: Cannot connect to host 172.30.32.1:8123 ssl:False [Connect call failed (‘172.30.32.1’, 8123)]
2024-10-03 09:16:08.697 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting…
2024-10-03 09:16:08.711 INFO (SyncWorker_7) [supervisor.docker.manager] Starting homeassistant
2024-10-03 09:16:08.789 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2024-10-03 09:16:10.626 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-10-03 09:16:10.765 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-10-03 09:16:14.455 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state=‘NOT_RUNNING’, offline_db_migration=False)
2024-10-03 09:16:15.069 INFO (MainThread) [supervisor.auth] Auth request from ‘core_mosquitto’ for ‘homeassistant’
2024-10-03 09:16:15.074 INFO (MainThread) [supervisor.auth] Home Assistant not running, checking cache
2024-10-03 09:16:34.491 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state=‘RUNNING’, offline_db_migration=False)
2024-10-03 09:16:34.491 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
yes restart and hangs issue here too after update within 5 minutes, restore if i can 2 releases in a row update breaks something or system… onto the waiting for a fix. I would submit issue but cant even get into logs in time.
This version seems to have added animations to dashboard entity window popups. How do I disable them?
Or are popups for some other reason much slower to open than before?
Entity card’s history graph color has changed, it’s now tinted to purple from previous blue.
Is there a setting for it or is this coming from theme? Any ideas how to revert it?
I noticed this this morning. It was hanging on the “Connected” or “Not Connected” screen. I restarted HA Core and the device I was trying to cast to and it worked again.
truly love the new type: heading with its initial offerings. Didn’t get around it during beta, but now that I replaced many of my custom:button-card headers (because of their styling options) with the new type:heading cards, I am really noticing how natural they feel in the yaml configs and Dashboard results.
In my config, I use ‘hold’ for navigating away, simply to prevent accidental clicks. It has become so natural to do that everywhere, replacing that with the only available tap-action would be a bit of a step back
Hope that isn’t a too exotic request, and the team will consider adding it.
