2024.11.2 Zigbee Bug?
2024.11 has not been a smooth update it seems. Frigate streaming issue is getting traction in another post.
But after updating to the .2 patch release half my zigbee devices are now unreachable. Tried reloading the integrarion Nd told me something changed my network. Gave me the option to revert “recommended” now half my devices are not recognized. I try putting them in a discoverable state and then use the “Reconfigure” option within the device admin page but fails every time. Went ahead and removed the device from HA, but now it won’t finish getting interrogated.
Also having issues with my TS011F socket Zigbee switches which were fine on 2024.11.1 but now unreachable on 2024.11.2
This is the error:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:245
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 21:58:23 (3 occurrences)
Last logged: 22:00:05
[547852573792] Unexpected exception
  File "/usr/local/lib/python3.12/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 67, in wrap_zigpy_exceptions
    yield
  File "/usr/local/lib/python3.12/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 85, in wrapper
    return await RETRYABLE_REQUEST_DECORATOR(func)(*args, **kwargs)
  File "/usr/local/lib/python3.12/site-packages/zigpy/util.py", line 136, in retry
    return await func()
  File "/usr/local/lib/python3.12/site-packages/zigpy/zcl/__init__.py", line 375, in request
    return await self._endpoint.request(
  File "/usr/local/lib/python3.12/site-packages/zigpy/endpoint.py", line 270, in request
    return await self.device.request(
  File "/usr/local/lib/python3.12/site-packages/zigpy/device.py", line 378, in request
    await send_request()
  File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 825, in request
    await self.send_packet(
  File "/usr/local/lib/python3.12/site-packages/zigpy_znp/zigbee/application.py", line 1100, in send_packet
    raise DeliveryError(
zigpy.exceptions.DeliveryError: Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>
  File "/usr/src/homeassistant/homeassistant/components/zha/helpers.py", line 1335, in handler
    return await func(self, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/zha/switch.py", line 63, in async_turn_off
    await self.entity_data.entity.async_turn_off()
  File "/usr/local/lib/python3.12/site-packages/zha/application/platforms/switch.py", line 100, in async_turn_off
    await self._on_off_cluster_handler.turn_off()
  File "/usr/local/lib/python3.12/site-packages/zha/zigbee/cluster_handlers/general.py", line 472, in turn_off
    result = await self.off()
  File "/usr/local/lib/python3.12/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 84, in wrapper
    with wrap_zigpy_exceptions():
  File "/usr/local/lib/python3.12/contextlib.py", line 158, in __exit__
    self.gen.throw(value)
  File "/usr/local/lib/python3.12/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 76, in wrap_zigpy_exceptions
    raise ZHAException(message) from exc
zha.exceptions.ZHAException: Failed to send request: Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 245, in handle_call_service
    response = await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 2802, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2845, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1007, in entity_service_call
    single_response = await _handle_entity_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1079, in _handle_entity_call
    result = await task
  File "/usr/src/homeassistant/homeassistant/components/zha/helpers.py", line 1337, in handler
    raise HomeAssistantError(err) from err
homeassistant.exceptions.HomeAssistantError: Failed to send request: Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>
I’m seeing the same. One failed Zigbee device that I can’t fix or reach (others are still OK, even ones with the same switch). It’s happening with my S31 Lite zb by SONOFF:
Source: /usr/src/homeassistant/homeassistant/runner.py:147
First occurred: 9:13:05 PM (2 occurrences)
Last logged: 9:13:51 PM
Error doing job: Task exception was never retrieved (None)
    yield
    return await func()
zigpy.exceptions.DeliveryError: Request failed after 5 attempts: <Status.MAC_CHANNEL_ACCESS_FAILURE: 225>
  File "/usr/local/lib/python3.12/site-packages/zha/zigbee/device.py", line 764, in async_configure
    await self.identify_ch.trigger_effect(
zha.exceptions.ZHAException: Failed to send request: Request failed after 5 attempts: <Status.MAC_CHANNEL_ACCESS_FAILURE: 225>
