It seems as of the latest update to core the log data is stuck loading for all devices. I have tested on chrome, Firefox and via the companion app.
I also noticed that file editor add on was failing to start up after the update was applied to core so I temporarily removed it and had to hit disable on the notice about it. Everything else works as it should.
edit: also here are the log errors related to this (just got home to be able to add them to the post for those needing them to help debug):
Logger: homeassistant.components.websocket_api.http.connection
Source: components/recorder/core.py:357
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 10:46:32 AM (30 occurrences)
Last logged: 3:41:04 PM
[140613156223392] Error handling message: Unknown error (unknown_error) Robert Koganov from 192.168.2.2 (Mozilla/5.0 (Linux; Android 14; SM-S918B Build/UP1A.231005.007; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/131.0.6778.39 Mobile Safari/537.36 Home Assistant/2024.10.3-14058 (Android 14; SM-S918B))
[140612603843712] Error handling message: Unknown error (unknown_error) Robert Koganov from 192.168.2.2 (Mozilla/5.0 (Linux; Android 14; SM-S918B Build/UP1A.231005.007; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/131.0.6778.39 Mobile Safari/537.36 Home Assistant/2024.10.3-14058 (Android 14; SM-S918B))
[140612459929392] Error handling message: Unknown error (unknown_error) Robert Koganov from 192.168.2.2 (Mozilla/5.0 (Linux; Android 14; SM-S918B Build/UP1A.231005.007; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/131.0.6778.39 Mobile Safari/537.36 Home Assistant/2024.10.3-14058 (Android 14; SM-S918B))
[140612460164240] Error handling message: Unknown error (unknown_error) Robert Koganov from 192.168.2.2 (Mozilla/5.0 (Linux; Android 14; SM-S918B Build/UP1A.231005.007; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/131.0.6778.39 Mobile Safari/537.36 Home Assistant/2024.10.3-14058 (Android 14; SM-S918B))
[140612449220736] Error handling message: Unknown error (unknown_error) Robert Koganov from 192.168.1.100 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:132.0) Gecko/20100101 Firefox/132.0)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 28, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/history/websocket_api.py", line 524, in ws_stream
last_event_time = await _async_send_historical_states(
File "/usr/src/homeassistant/homeassistant/components/history/websocket_api.py", line 282, in _async_send_historical_states
last_time_ts, last_time_dt, payload = await instance.async_add_executor_job(
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 357, in async_add_executor_job
return self.hass.loop.run_in_executor(self._db_executor, target, *args)
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 863, in run_in_executor
executor.submit(func, *args), loop=self)
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 170, in submit
raise RuntimeError('cannot schedule new futures after shutdown')
RuntimeError: cannot schedule new futures after shutdown
Logger: aiohttp.server
Source: /usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py:448
First occurred: 10:46:33 AM (464 occurrences)
Last logged: 3:41:06 PM
Error handling request
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 477, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 567, in _handle
return await handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 117, in impl
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/history/__init__.py", line 121, in get
await get_instance(hass).async_add_executor_job(
I have opened a ticket here with the issue for those wanting to track it as well: 2024.11.3 Core - logs not loading · Issue #131431 · home-assistant/core · GitHub
