So my assumption would be that you remove that addon and the integration. Then add the cameras directly to HA. Or disable go2rtc my managing default config yourself.
Ok, thanks.
So remove addon but how to remove the integration ? (Reolink integration ??)
I already removed go2rtc by managing default config in a previous attempt but no luck.
I have no idea what you have in your setup. So Iām guessing here.
If you are using reolink and the addon, then youād keep reolink, remove the addon, and use default_config. If not then youād keep reolink, use the addon, and remove go2rtc from default config. Restarts required after making changes to go2rtc.
todays upgrade from 11.1 to 11.2 leads to incorrect sensor state phrasing. for example, previously my door sensors are said either OPEN or CLOSED. now all door sensors are showing as either OFF or ON.
ive verified the issue is with 11.2 after rolling back to 11.1.
11.1 -
11.2 -
anyone else?
edit:
measurement units seem to be affected too, as mine have gone missing.
