I’m running Home Assistant container on Kubernetes. Same for Music Assistant.
Still havent been able to make it work. There seem to be more issues
Here is a similar issue with spotcast
Logger: homeassistant.setup
Source: setup.py:334
First occurred: 08:29:44 (1 occurrences)
Last logged: 08:29:44
Setup failed for custom integration 'spotcast': Unable to import component: No module named 'spotipy'
File "/usr/src/homeassistant/homeassistant/setup.py", line 334, in _async_setup_component
component = await integration.async_get_component()
File "/usr/src/homeassistant/homeassistant/loader.py", line 1031, in async_get_component
self._component_future.result()
File "/usr/src/homeassistant/homeassistant/loader.py", line 1011, in async_get_component
comp = await self.hass.async_add_import_executor_job(
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/loader.py", line 1071, in _get_component
ComponentProtocol, importlib.import_module(self.pkg_path)
File "/usr/src/homeassistant/homeassistant/util/loop.py", line 200, in protected_loop_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 995, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/config/custom_components/spotcast/__init__.py", line 55, in <module>
from .helpers import (
File "/config/custom_components/spotcast/helpers.py", line 15, in <module>
import spotipy
ModuleNotFoundError: No module named 'spotipy'
and here the one for music assistant:
First occurred: 08:29:41 (1 occurrences)
Last logged: 08:29:41
Setup failed for custom integration 'mass': Unable to import component: No module named 'music_assistant_client'
File "/config/custom_components/mass/__init__.py", line 22, in <module>
from music_assistant_client import MusicAssistantClient
ModuleNotFoundError: No module named 'music_assistant_client'
