So, since upgrading to 2024.12.0, I’ve had identical errors with five custom integrations, as I mention here:
All of them produce essentially the same errors, with stack traces matching this:
2024-12-06 04:56:49.060 ERROR (MainThread) [homeassistant.config] Platform error: sensor - No module named 'portion'
File "/usr/src/homeassistant/homeassistant/config.py", line 1055, in _async_load_and_validate_platform_integration
platform = await p_integration.integration.async_get_platform(domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1107, in async_get_platform
platforms = await self.async_get_platforms((platform_name,))
File "/usr/src/homeassistant/homeassistant/loader.py", line 1184, in async_get_platforms
import_future.result()
File "/usr/src/homeassistant/homeassistant/loader.py", line 1154, in async_get_platforms
await self.hass.async_add_import_executor_job(
self._load_platforms, platform_names
File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/loader.py", line 1097, in _load_platforms
platform_name: self._load_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1271, in _load_platform
cache[full_name] = self._import_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1303, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File "/usr/src/homeassistant/homeassistant/util/loop.py", line 200, in protected_loop_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.13/importlib/__init__.py", line 88, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 1022, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/config/custom_components/schedule_state/sensor.py", line 47, in <module>
import portion as P
ModuleNotFoundError: No module named 'portion'
which differs only in the source file and the specific module not found. Schedule State fails trying to find ‘portion’, Alexa Media Player (yes, 5.0.1) fails trying to find ‘alexapy’, Frigidaire fails trying to find ‘frigidaire’, and Anniversaries fails trying to find ‘integrationhelper’.
Looking in the deps
folder, all of these are present:
drwxr-x---+ 4 root swarm 4.0K Dec 5 22:37 aiofiles/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:37 aiofiles-24.1.0.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 aiohappyeyeballs/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 aiohappyeyeballs-2.4.4.dist-info/
drwxr-x---+ 4 root swarm 4.0K Dec 5 22:31 aiohttp/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 aiohttp-3.11.9.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 aiohttp.libs/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 aiosignal/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 aiosignal-1.3.1.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:36 alexapy/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:36 alexapy-1.29.5.dist-info/
drwxr-x---+ 6 root swarm 4.0K Dec 5 22:37 anyio/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 anyio-4.6.2.post1.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 async_timeout/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 async_timeout-4.0.3.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 attr/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 attrs/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:31 attrs-24.2.0.dist-info/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:36 authcaptureproxy/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:36 authcaptureproxy-1.3.3.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 backoff/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 backoff-2.2.1.dist-info/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:36 beautifulsoup4-4.12.3.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:44 bin/
drwxr-x---+ 4 root swarm 4.0K Dec 5 22:36 bs4/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 certifi/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 certifi-2024.8.30.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:36 cffi/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:36 cffi-1.17.1.dist-info/
-rwxr-xr-x+ 1 root swarm 241K Dec 5 22:36 _cffi_backend.cpython-313-x86_64-linux-musl.so*
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:36 cffi.libs/
-rw-r--r--+ 1 root swarm 9.8K Dec 5 22:36 CHANGELOG.md
drwxr-x---+ 4 root swarm 4.0K Dec 5 22:44 chardet/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:44 chardet-5.2.0.dist-info/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:37 charset_normalizer/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 charset_normalizer-3.4.0.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 charset_normalizer.libs/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 click/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 click-8.1.7.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:29 croniter/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:29 croniter-2.0.2.dist-info/
drwxr-x---+ 4 root swarm 4.0K Dec 5 22:37 cryptography/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:37 cryptography-43.0.1.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 cryptography.libs/
drwxr-x---+ 5 root swarm 4.0K Dec 5 22:29 dateutil/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:44 deprecation-2.1.0.dist-info/
-rw-r--r--+ 1 root swarm 13K Dec 5 22:44 deprecation.py
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:44 frigidaire/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:44 frigidaire-0.18.23.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 frozenlist/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 frozenlist-1.5.0.dist-info/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:36 h11/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:36 h11-0.14.0.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 h2/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 h2-4.1.0.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 hpack/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 hpack-4.0.0.dist-info/
drwxr-x---+ 5 root swarm 4.0K Dec 5 22:37 httpcore/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:37 httpcore-1.0.5.dist-info/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:36 httpx/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:36 httpx-0.27.2.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:36 hyperframe/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:36 hyperframe-6.0.1.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 idna/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 idna-3.10.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 integrationhelper/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 integrationhelper-0.2.2.dist-info/
-rw-r--r--+ 1 root swarm 11K Dec 5 22:36 LICENSE
-rw-r--r--+ 1 root swarm 11K Dec 5 22:36 LICENSE.txt
drwxr-x---+ 9 root swarm 4.0K Dec 5 22:38 markdown_it/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:38 markdown_it_py-3.0.0.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:36 mdurl/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:36 mdurl-0.1.2.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 multidict/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 multidict-6.1.0.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 multidict.libs/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:44 packaging/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:44 packaging-24.2.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:43 portion/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:43 portion-2.4.0.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 propcache/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 propcache-0.2.1.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 propcache.libs/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:37 pycparser/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 pycparser-2.22.dist-info/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:44 pydantic/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:44 pydantic-1.10.19.dist-info/
drwxr-x---+ 6 root swarm 4.0K Dec 5 22:38 pygments/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:38 pygments-2.18.0.dist-info/
drwxr-x---+ 4 root swarm 4.0K Dec 5 22:44 pygrocy/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:44 pygrocy-2.0.0.dist-info/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:37 pyotp/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 pyotp-2.9.0.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:29 python_dateutil-2.9.0.post0.dist-info/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:29 pytz/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 pytz-2024.2.dist-info/
-rw-r--r--+ 1 root swarm 2.5K Dec 5 22:36 README.md
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 requests/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 requests-2.32.3.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:36 rich/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:36 rich-13.9.4.dist-info/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:37 shellingham/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 shellingham-1.5.4.dist-info/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:37 simplejson/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 simplejson-3.19.3.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:36 simplejson.libs/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:28 six-1.17.0.dist-info/
-rw-r--r--+ 1 root swarm 34K Dec 5 22:28 six.py
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:36 sniffio/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:36 sniffio-1.3.1.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:43 sortedcontainers/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:43 sortedcontainers-2.4.0.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 soupsieve/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:37 soupsieve-2.6.dist-info/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:28 srp/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:28 srp-1.0.22.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:44 test/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 typer/
drwxr-x---+ 3 root swarm 4.0K Dec 5 22:37 typer-0.15.1.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:36 typing_extensions-4.12.2.dist-info/
-rw-r--r--+ 1 root swarm 132K Dec 5 22:36 typing_extensions.py
drwxr-x---+ 5 root swarm 4.0K Dec 5 22:37 urllib3/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:37 urllib3-1.26.20.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 yarl/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 yarl-1.18.3.dist-info/
drwxr-x---+ 2 root swarm 4.0K Dec 5 22:31 yarl.libs
I’ve even deleted deps
and let HA recreate it to ensure that everything in there is okay. Also, I’ve tried backing out to 2024.11.3, which was my previously working version, but apparently once whatever is causing this error starts happening, it keeps happening, even under the older version.
As a further test, I tried running a shell in the Home Assistant container, then using pip
to install the missing packages directly in it, rather than relying on the copies in deps
. At that point, Home Assistant started normally with all five of these integrations working, but obviously that’s not a viable long-term solution.
Seems to me like there’s something up with HA’s loader here, although why it’s limited to just these five integrations’ dependencies is a bit of a mystery.
Apart from enabling debug logging on homeassistant.config and homeassistant.loader, which I’m about to do, anyone have any other advice on debugging dependency-loading issues? Or have seen this particular issue before?
