about the “prefer handling commands locally” setting, I just found a drawback.
This is my test:
- Turn on kitchen light
(assist will turn it on, not using chatgpt) - Turn off the light that you turned on before
(assist does not know the command, asks chatgpt but chagpt did not handled the other request, so It may turn off another light)
This is just an example, but it breaks conversations.
another example:
(it turns the light on)
What was the last command you did?
(it reports the latest command done using chatgpt, not the one about kitchen light)
Upgraded my test box without any issues, does feel snappier.
Seems Alexa Mdia Player is broken with this version.
Yep broken for me as well. Nothing tremendously useful in the logs that I can see
You can read all about it in the WTH announcement blog
@frenck this link gives me a 404.
Yeahhh this would be completely breaking for me. I assume we can turn it off?
Silly question: After updating, I do not see any way to get to the Scene > Review Mode. Scenes still launch when I try and view the scene. What am I missing?
Did you clear your cache or ctrl-F5?
I did… Problem solved ![]()
Thanks.
The stookwijzer integration is really nice now. Though the website of Atlas leefomgeving also gives a prediction of the next hours. Is that on the roadmap to be made visible (in attrributes or so)? It would be helpful that it remains oke for the rest of the evening for example.
This update seems to have deleted my configuration.yaml ![]()
Supervisor doesn’t seem to start properly either
Logger: homeassistant.components.recorder.core
Source: components/recorder/core.py:1176
integration: Recorder (documentation, issues)
First occurred: 21:57:14 (156 occurrences)
Last logged: 22:04:22
Error in database connectivity during commit: Error executing query: (sqlite3.OperationalError) unable to open database file (Background on this error at: https://sqlalche.me/e/20/e3q8). (retrying in 3 seconds)
and
Source: util/loop.py:200
First occurred: 22:00:09 (9 occurrences)
Last logged: 22:04:09
Error doing job: Task exception was never retrieved (None)
File "src/habluetooth/scanner.py", line 514, in _async_restart_scanner
File "src/habluetooth/scanner.py", line 526, in habluetooth.scanner.HaScanner._async_restart_scanner
File "src/habluetooth/scanner.py", line 542, in _async_reset_adapter
File "/usr/local/lib/python3.12/site-packages/habluetooth/util.py", line 13, in async_reset_adapter
File "/usr/local/lib/python3.12/site-packages/bluetooth_auto_recovery/__init__.py", line 24, in recover_adapter
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/util/loop.py", line 200, in protected_loop_func
File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1322, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 1262, in _find_spec
File "<frozen importlib._bootstrap_external>", line 1528, in find_spec
File "<frozen importlib._bootstrap_external>", line 1502, in _get_spec
File "<frozen importlib._bootstrap_external>", line 1605, in find_spec
File "<frozen importlib._bootstrap_external>", line 1648, in _fill_cache
OSError: [Errno 5] I/O error: '/usr/local/lib/python3.12/site-packages/bluetooth_auto_recovery'
and
Logger: homeassistant.components.recorder.util
Source: components/recorder/util.py:202
First occurred: 21:57:09 (168 occurrences)
Last logged: 22:04:07
and
Source: components/recorder/core.py:882
First occurred: 21:57:09 (1 occurrences)
Last logged: 21:57:09
Unrecoverable sqlite3 database corruption detected: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO states (entity_id, state, attributes, event_id, last_changed, last_changed_ts, last_reported_ts, last_updated, last_updated_ts, old_state_id, attributes_id, context_id, context_user_id, context_parent_id, origin_idx, context_id_bin, context_user_id_bin, context_parent_id_bin, metadata_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) RETURNING state_id] [parameters: (None, '-48', None, None, None, None, None, None, 1733345829.3116176, 39025954, 46266, None, None, None, 0, <memory at 0x7f4c49b7c0>, None, None, 1067)] (Background on this error at: https://sqlalche.me/e/20/4xp6)
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 2116, in _exec_insertmany_context
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/default.py", line 924, in do_execute
sqlite3.DatabaseError: database disk image is malformed
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 882, in _process_one_task_or_event_or_recover
File "/usr/src/homeassistant/homeassistant/components/recorder/tasks.py", line 297, in run
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1174, in _commit_event_session_or_retry
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1210, in _commit_event_session
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/session.py", line 2017, in commit
File "<string>", line 2, in commit
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/state_changes.py", line 139, in _go
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/session.py", line 1302, in commit
File "<string>", line 2, in _prepare_impl
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/session.py", line 1277, in _prepare_impl
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/session.py", line 4341, in flush
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/session.py", line 4476, in _flush
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/util/langhelpers.py", line 146, in __exit__
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/session.py", line 4437, in _flush
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/unitofwork.py", line 466, in execute
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/unitofwork.py", line 642, in execute
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/persistence.py", line 93, in save_obj
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/persistence.py", line 1143, in _emit_insert_statements
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1418, in execute
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/sql/elements.py", line 515, in _execute_on_connection
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1640, in _execute_clauseelement
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1844, in _execute_context
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 2124, in _exec_insertmany_context
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 2353, in _handle_dbapi_exception
sqlalchemy.exc.DatabaseError: (sqlite3.DatabaseError) database disk image is malformed
Among other sensor/integration errors.
Reboot/shutdown via GUI doesn’t work. Pulled the power of the rpi5 with no difference.
Can’t access backups to restore because supervisor doesn’t start (properly?).
Any ideas?
Hm, after the 2nd forced restart it seems to be working again.
Had the update available again, installing it this time worked.
Check if you have any history data.
I have history back until the 27th of november. Before that it’s empty ![]()
It seems I have certain history data earlier. Like temperature data, but state seems to only be available since the 27th.
for what ever reason my knx secure tunneling connection does not work anymore.
Routing is no options, since I do not get any values.
Glad I saw this before updating to 12.0. Following.
Yup. Went back to Core 2024.11.3. Want Alexa Media Player more than new features. Sounds like this could be an extended issue.
