2024.12: Scene you in 2025! šŸŽ„
Anyone else using self-signed certs? I am now getting this error, connecting to ZoneMinder via SSL:
2024-12-08 18:45:19.929 ERROR (MainThread) [homeassistant.components.cert_expiry.coordinator] Certificate validation error: {IP redacted} [Missing Authority Key Identifier]
2024-12-08 18:45:19.965 ERROR (MainThread) [homeassistant.components.cert_expiry.coordinator] Certificate validation error: {IP redacted} [self-signed certificate in certificate chain]
I poked around but donā€™t see anything in Python 3.13 indicating AKID is now a requirement in self-signed certs. Curious if anyone else has self-signed certs working on the latest version, before I fire up my CA machine and generate new certificates.
Yeah, It must have just been a once off. Even my test automation using the old syntax still works.
Well, believe it or not.
Yesterday i was creating a couple of sensors.
Then, off course, i restarted HA.
It took HA more then 5 minutes to restart.
Suddenly, all camerastreams worked perfect !
The reason ? I think i will never know but thatā€™s ok. Everything is working now how it should be :wink:
2024.12.1 seems to have broken the Lennox iComfort thermostat integration. HA is unable to connect to the iComfort server.
Commented on issue#52 on the integrationā€™s Github page.
MyiComfort will not load Ā· Issue #52 Ā· thevoltagesource/LennoxiComfort
Posting on that GitHub issue is the way to deal with it.
2024.12.2 has been released and it fixes the Tado integration issue. :slight_smile:
Hi.
Can someone that is on 2024.12.1 version try command inside docker:
curl -4 -vvv http://overpass-api.de/api/interpreter
Want to see is this working fine or it is something else.
Regards
Issues with skyconnect now worse under2024.12.2.
At least before i could restart ha every 23 hours and the connection would work. Now even restarting didnā€™t help.
This is what pops up if i try to turn the lights off:
This is what comes up in the logs:
Logger:
`homeassistant.components.websocket_api.http.connection`
Source: components/websocket_api/commands.py:245
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 12:19:29 (4 occurrences)
Last logged: 12:19:33
[140221303477664] Unexpected exception
  File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 67, in wrap_zigpy_exceptions
    yield
  File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 85, in wrapper
    return await RETRYABLE_REQUEST_DECORATOR(func)(*args, **kwargs)
  File "/usr/local/lib/python3.13/site-packages/zigpy/util.py", line 136, in retry
    return await func()
  File "/usr/local/lib/python3.13/site-packages/zigpy/zcl/__init__.py", line 375, in request
    return await self._endpoint.request(
    ...<9 lines>...
  File "/usr/local/lib/python3.13/site-packages/zigpy/endpoint.py", line 270, in request
    return await self.device.request(
    ...<11 lines>...
  File "/usr/local/lib/python3.13/site-packages/zigpy/device.py", line 378, in request
    await send_request()
  File "/usr/local/lib/python3.13/site-packages/zigpy/application.py", line 835, in request
    await self.send_packet(
    ...<14 lines>...
  File "/usr/local/lib/python3.13/site-packages/bellows/zigbee/application.py", line 852, in send_packet
    raise zigpy.exceptions.DeliveryError(
        f"Failed to deliver message: {send_status!r}", send_status
zigpy.exceptions.DeliveryError: Failed to deliver message: <sl_Status.ZIGBEE_DELIVERY_FAILED: 3074>
  File "/usr/src/homeassistant/homeassistant/components/zha/helpers.py", line 1335, in handler
    return await func(self, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/zha/light.py", line 183, in async_turn_off
    await self.entity_data.entity.async_turn_off(
        transition=kwargs.get(ATTR_TRANSITION)
  File "/usr/local/lib/python3.13/site-packages/zha/application/platforms/light/__init__.py", line 504, in async_turn_off
    result = await self._on_off_cluster_handler.off()
  File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 84, in wrapper
    with wrap_zigpy_exceptions():
  File "/usr/local/lib/python3.13/contextlib.py", line 162, in __exit__
    self.gen.throw(value)
  File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 76, in wrap_zigpy_exceptions
    raise ZHAException(message) from exc
zha.exceptions.ZHAException: Failed to send request: Failed to deliver message: <sl_Status.ZIGBEE_DELIVERY_FAILED: 3074>
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 245, in handle_call_service
    response = await hass.services.async_call(
    ...<7 lines>...
  File "/usr/src/homeassistant/homeassistant/core.py", line 2802, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2845, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1007, in entity_service_call
    single_response = await _handle_entity_call(
        hass, entity, func, data, call.context
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1079, in _handle_entity_call
    result = await task
  File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 639, in async_handle_light_off_service
    await light.async_turn_off(**filter_turn_off_params(light, params))
  File "/usr/src/homeassistant/homeassistant/components/zha/helpers.py", line 1337, in handlerloop
    raise HomeAssistantError(err) from err
homeassistant.exceptions.HomeAssistantError: Failed to send request: Failed to deliver message: <sl_Status.ZIGBEE_DELIVERY_FAILED: 3074>
Running all updated on a VMware VM
After update to 12.2 enigma2 integration not working:
enigma2: Not adding entity with invalid device info: Invalid device info {'configuration_url': 'http://root:[email protected]', 'connections': set(), 'identifiers': set(), 'manufacturer': 'Zgemma', 'model': 'H7', 'name': '192.168.1.108'} for 'enigma2' config entry: device info must include at least one of identifiers or connections
On 12.1 worked good.
Gone back to 12.1 but the same problem now. :frowning: Dont know what happend.
I wish I could codeā€¦ then I would contribute. Another Good Job to the whole team!!
Using the built-in Shelly integration appears to be fine.
Anybody having issues with timers on the M5Stack Atom since this update? The timer still goes off, but it only does the blinking light, not the sound. Started happening immediately upon update, across all of the Atoms in my house (~5 of them). (The new conversation response where it repeats back the time it has set is a great change tho!)
Regarding the addons constantly restarting, only mention I can find is in the supervisor logs, the addons themselves donā€™t seem to be logging a issue and its the watchdog restarting them.
2024-12-12 09:11:24.182 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2024-12-12 09:13:19.009 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/music-assistant/home-assistant-addon repository
2024-12-12 09:13:19.078 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/adamoutler/mqtt-explorer repository
2024-12-12 09:13:19.132 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/ParadoxAlarmInterface/hassio-repository repository
2024-12-12 09:13:19.176 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/CoolKit-Technologies/ha-addon repository
2024-12-12 09:13:19.229 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/sabeechen/hassio-google-drive-backup repository
2024-12-12 09:13:19.290 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
2024-12-12 09:13:19.348 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
2024-12-12 09:13:19.388 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
2024-12-12 09:13:26.114 INFO (MainThread) [supervisor.store] Loading add-ons from store: 88 all - 0 new - 0 remove
2024-12-12 09:13:26.116 INFO (MainThread) [supervisor.store] Loading add-ons from store: 88 all - 0 new - 0 remove
2024-12-12 09:15:53.150 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-12-12 09:45:55.488 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-12-12 09:53:27.524 INFO (MainThread) [supervisor.host.info] Updating local host information
2024-12-12 09:53:30.564 INFO (MainThread) [supervisor.host.services] Updating service information
2024-12-12 09:53:30.642 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-12-12 09:53:32.395 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-12-12 09:53:33.243 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2024-12-12 10:11:24.186 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2024-12-12 10:11:24.193 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2024-12-12 10:11:24.525 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2024-12-12 10:11:24.897 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-12-12 10:11:24.900 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2024-12-12 10:11:24.902 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2024-12-12 10:11:24.904 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2024-12-12 10:11:24.907 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2024-12-12 10:11:24.909 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-12-12 10:11:24.910 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2024-12-12 10:11:24.917 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2024-12-12 10:11:24.919 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2024-12-12 10:11:24.920 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-12-12 10:11:24.921 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-12-12 10:11:26.681 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-12-12 10:11:26.683 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2024-12-12 10:11:26.684 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2024-12-12 10:16:25.575 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-12-12 10:30:40.256 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 477, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.12/site-packages/sentry_sdk/integrations/aiohttp.py", line 161, in sentry_app_handle
    reraise(*_capture_exception())
  File "/usr/local/lib/python3.12/site-packages/sentry_sdk/utils.py", line 1723, in reraise
    raise value
  File "/usr/local/lib/python3.12/site-packages/sentry_sdk/integrations/aiohttp.py", line 144, in sentry_app_handle
    response = await old_handle(self, request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 567, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 199, in block_bad_requests
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 215, in system_validation
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 234, in token_validation
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 298, in core_proxy
  File "/usr/src/supervisor/supervisor/api/proxy.py", line 217, in websocket
    response = await server.receive_json()
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_ws.py", line 573, in receive_json
    data = await self.receive_str(timeout=timeout)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_ws.py", line 557, in receive_str
    raise TypeError(
TypeError: Received message 257:None is not WSMsgType.TEXT
2024-12-12 10:30:40.552 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Cannot proxy websocket message of unsupported type: 257
2024-12-12 10:30:40.554 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Cannot proxy websocket message of unsupported type: 257
2024-12-12 10:30:40.612 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API for f4f71350_ewelink_smart_home_slug closed
2024-12-12 10:30:40.618 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API for f4f71350_ewelink_smart_home_slug closed
2024-12-12 10:30:46.762 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon eWeLink Smart Home is failed, restarting...
2024-12-12 10:30:46.805 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_f4f71350_ewelink_smart_home_slug application
2024-12-12 10:30:56.730 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on f4f71350/aarch64-addon-ewelink_smart_home_slug with version 1.4.3
2024-12-12 10:31:05.318 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
2024-12-12 10:31:05.358 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
2024-12-12 10:31:05.406 INFO (MainThread) [supervisor.api.proxy] WebSocket access from f4f71350_ewelink_smart_home_slug
2024-12-12 10:31:05.452 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
2024-12-12 10:31:08.822 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
2024-12-12 10:31:08.842 INFO (MainThread) [supervisor.api.proxy] WebSocket access from f4f71350_ewelink_smart_home_slug
2024-12-12 10:31:08.860 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
2024-12-12 10:46:46.491 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-12-12 11:11:26.690 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2024-12-12 11:11:26.698 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2024-12-12 11:11:27.359 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2024-12-12 11:11:27.817 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-12-12 11:11:27.819 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2024-12-12 11:11:27.821 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2024-12-12 11:11:27.823 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2024-12-12 11:11:27.837 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2024-12-12 11:11:27.840 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-12-12 11:11:27.843 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2024-12-12 11:11:27.854 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2024-12-12 11:11:27.856 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2024-12-12 11:11:27.857 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-12-12 11:11:27.858 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-12-12 11:11:29.417 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-12-12 11:11:29.419 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2024-12-12 11:11:29.420 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2024-12-12 11:16:58.153 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-12-12 11:20:31.476 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_e92a3241_paradox_alarm_interface_3.x application
2024-12-12 11:20:56.792 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on paradoxalarminterface/pai with version 3.6.0
2024-12-12 11:21:16.445 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'pai'
2024-12-12 11:21:19.547 INFO (MainThread) [supervisor.auth] Successful login for 'pai'
2024-12-12 11:21:36.795 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Paradox Alarm Interface is failed, restarting...
2024-12-12 11:21:36.832 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_e92a3241_paradox_alarm_interface_3.x application
2024-12-12 11:22:07.553 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on paradoxalarminterface/pai with version 3.6.0
2024-12-12 11:22:36.500 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Paradox Alarm Interface is failed, restarting...
2024-12-12 11:22:36.560 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning addon_e92a3241_paradox_alarm_interface_3.x application
2024-12-12 11:22:59.241 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on paradoxalarminterface/pai with version 3.6.0
2024-12-12 11:23:42.149 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Paradox Alarm Interface is failed, restarting...
2024-12-12 11:23:42.187 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_e92a3241_paradox_alarm_interface_3.x application
2024-12-12 11:24:10.066 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on paradoxalarminterface/pai with version 3.6.0
2024-12-12 11:24:20.028 ERROR (MainThread) [aiohttp.server] Error handling request
    raise value
    raise TypeError(
2024-12-12 11:24:20.281 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Cannot proxy websocket message of unsupported type: 257
2024-12-12 11:24:20.292 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Cannot proxy websocket message of unsupported type: 257
2024-12-12 11:24:21.474 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API for f4f71350_ewelink_smart_home_slug closed
2024-12-12 11:24:21.708 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API for f4f71350_ewelink_smart_home_slug closed
2024-12-12 11:24:34.471 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon eWeLink Smart Home is failed, restarting...
2024-12-12 11:24:34.544 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_f4f71350_ewelink_smart_home_slug application
2024-12-12 11:25:01.894 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on f4f71350/aarch64-addon-ewelink_smart_home_slug with version 1.4.3
2024-12-12 11:25:17.429 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
2024-12-12 11:25:17.708 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
2024-12-12 11:25:21.919 INFO (MainThread) [supervisor.api.proxy] WebSocket access from f4f71350_ewelink_smart_home_slug
2024-12-12 11:25:23.266 ERROR (MainThread) [aiohttp.server] Error handling request
    raise value
    raise TypeError(
2024-12-12 11:25:24.024 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
2024-12-12 11:25:24.027 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Cannot proxy websocket message of unsupported type: 257
2024-12-12 11:25:24.081 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API for f4f71350_ewelink_smart_home_slug closed
2024-12-12 11:25:38.091 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon eWeLink Smart Home is failed, restarting...
2024-12-12 11:25:38.326 INFO (SyncWorker_7) [supervisor.docker.manager] Cleaning addon_f4f71350_ewelink_smart_home_slug application
2024-12-12 11:26:00.893 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on f4f71350/aarch64-addon-ewelink_smart_home_slug with version 1.4.3
2024-12-12 11:26:43.056 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
2024-12-12 11:26:43.902 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
2024-12-12 11:26:45.713 INFO (MainThread) [supervisor.api.proxy] WebSocket access from f4f71350_ewelink_smart_home_slug
2024-12-12 11:26:45.932 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
2024-12-12 11:26:50.828 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Paradox Alarm Interface is failed, restarting...
2024-12-12 11:26:50.907 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning addon_e92a3241_paradox_alarm_interface_3.x application
2024-12-12 11:26:52.331 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
2024-12-12 11:26:52.570 INFO (MainThread) [supervisor.api.proxy] WebSocket access from f4f71350_ewelink_smart_home_slug
2024-12-12 11:26:52.616 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
2024-12-12 11:27:39.147 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on paradoxalarminterface/pai with version 3.6.0
2024-12-12 11:27:46.016 ERROR (MainThread) [aiohttp.server] Error handling request
    raise value
    raise TypeError(
2024-12-12 11:27:46.797 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Cannot proxy websocket message of unsupported type: 257
2024-12-12 11:27:46.799 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Cannot proxy websocket message of unsupported type: 257
2024-12-12 11:27:47.425 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API for f4f71350_ewelink_smart_home_slug closed
2024-12-12 11:27:47.456 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API for f4f71350_ewelink_smart_home_slug closed
2024-12-12 11:27:50.016 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'pai'
2024-12-12 11:27:51.460 INFO (MainThread) [supervisor.auth] Successful login for 'pai'
2024-12-12 11:28:02.829 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon eWeLink Smart Home is failed, restarting...
2024-12-12 11:28:02.891 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_f4f71350_ewelink_smart_home_slug application
2024-12-12 11:28:24.672 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on f4f71350/aarch64-addon-ewelink_smart_home_slug with version 1.4.3
2024-12-12 11:29:05.756 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
2024-12-12 11:29:05.900 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
2024-12-12 11:29:09.439 ERROR (MainThread) [aiohttp.server] Error handling request
    raise value
    raise TypeError(
2024-12-12 11:29:09.852 ERROR (MainThread) [aiohttp.server] Error handling request
    raise value
    raise TypeError(
2024-12-12 11:29:24.628 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon eWeLink Smart Home is failed, restarting...
2024-12-12 11:29:24.780 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_f4f71350_ewelink_smart_home_slug application
2024-12-12 11:29:48.638 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on f4f71350/aarch64-addon-ewelink_smart_home_slug with version 1.4.3
2024-12-12 11:30:39.599 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Paradox Alarm Interface is failed, restarting...
2024-12-12 11:30:39.657 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_e92a3241_paradox_alarm_interface_3.x application
2024-12-12 11:30:41.869 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
2024-12-12 11:30:41.888 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
2024-12-12 11:30:42.124 INFO (MainThread) [supervisor.api.proxy] WebSocket access from f4f71350_ewelink_smart_home_slug
2024-12-12 11:30:42.186 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
2024-12-12 11:30:57.848 ERROR (MainThread) [supervisor.homeassistant.api] Error on call https://172.30.32.1:8123/api/states/binary_sensor.10016270ab_569402A6082A205768: [Errno None] Can not write request body for https://172.30.32.1:8123/api/states/binary_sensor.10016270ab_569402A6082A205768
2024-12-12 11:30:57.042 ERROR (MainThread) [supervisor.api.proxy] Error on API for request states/binary_sensor.10016270ab_569402A6082A205768
2024-12-12 11:30:59.635 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
2024-12-12 11:31:01.500 INFO (MainThread) [supervisor.api.proxy] WebSocket access from f4f71350_ewelink_smart_home_slug
2024-12-12 11:31:01.646 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
2024-12-12 11:31:29.093 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on paradoxalarminterface/pai with version 3.6.0
2024-12-12 11:31:59.293 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Paradox Alarm Interface is failed, restarting...
2024-12-12 11:31:59.324 INFO (SyncWorker_7) [supervisor.docker.manager] Cleaning addon_e92a3241_paradox_alarm_interface_3.x application
2024-12-12 11:32:27.201 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on paradoxalarminterface/pai with version 3.6.0
2024-12-12 11:32:49.968 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'pai'
2024-12-12 11:32:58.991 INFO (MainThread) [supervisor.auth] Successful login for 'pai'
2024-12-12 11:33:09.643 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Paradox Alarm Interface is failed, restarting...
2024-12-12 11:33:09.774 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_e92a3241_paradox_alarm_interface_3.x application
Is the action ā€˜group.setā€™ expected to be gone since 2024.12.2?
no
Okay, created Service 'group.set' no longer available? Ā· Issue #133072 Ā· home-assistant/core Ā· GitHub
And CUPS sensor is working again as of HA Core 2024.12.2
Thank you!
I wonder if that (steadily increasing RAM usage) was what happened to me. After I upgraded, it would seem OK, but then when I checked a couple hours later it was almost completely unresponsive. I could get my first page, but couldnā€™t change pages or do anything else. I had to pull the plug on the box and then re-plug it in again to get it going again. And that reset the logs, so I couldnā€™t see what caused it. It happened multiple times, every time, until I used a backup to downgraded the core to 2024.11.3. That fixed it.
hi all. after updating to 2024.12.3 from 2024.12.2, i could not load any UI just the menu. i have installed HA on a VM on Proxmox and i have allways updated with no issues. i have hourly backups and restored latest version. any one else had problems?
