I have 2 instances, one at home and one in my camper. In both are shellys installed and after the upgrade to 12.0 both lost connection to the Shellys. After restoring to 11.3 it works again.
Netatmo is working ok for me after upgrading.
Zha not working on 2024.12
Logger: homeassistant.config_entries
Source: config_entries.py:640
First occurred: 7:47:00 AM (1 occurrences)
Last logged: 7:47:00 AM
Error setting up entry Sonoff Zigbee 3.0 USB Dongle Plus, s/n: 6692ec78e0c9eb118556914f1d69213e - ITead for zha
File â/usr/src/homeassistant/homeassistant/config_entries.pyâ, line 640, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File â/usr/src/homeassistant/homeassistant/components/zha/init.pyâ, line 132, in async_setup_entry
async with radio_mgr.connect_zigpy_app() as app:
File â/usr/local/lib/python3.13/contextlib.pyâ, line 214, in aenter
return await anext(self.gen)
File â/usr/src/homeassistant/homeassistant/components/zha/radio_manager.pyâ, line 182, in connect_zigpy_app
app = await self.radio_type.controller.new(
app_config, auto_form=False, start_radio=False
File â/usr/local/lib/python3.13/site-packages/zigpy/application.pyâ, line 239, in new
await app._load_db()
File â/usr/local/lib/python3.13/site-packages/zigpy/application.pyâ, line 111, in _load_db
await self._dblistener.load()
File â/usr/local/lib/python3.13/site-packages/zigpy/appdb.pyâ, line 684, in load
device = zigpy.quirks.get_device(device)
File â/usr/local/lib/python3.13/site-packages/zigpy/quirks/init.pyâ, line 43, in get_device
return _DEVICE_REGISTRY.get_device(device)
File â/usr/local/lib/python3.13/site-packages/zigpy/quirks/registry.pyâ, line 125, in get_device
raise MultipleQuirksMatchException(
f"Multiple matches found for device {device}: {matches}"
zigpy.exceptions.MultipleQuirksMatchException: Multiple matches found for device : [QuirksV2RegistryEntry(quirk_file=PosixPath(â/usr/local/lib/python3.13/site-packages/zhaquirks/xiaomi/aqara/motion_agl1.pyâ), quirk_file_line=141, manufacturer_model_metadata=(ManufacturerModelMetadata(manufacturer=âaqaraâ, model=âlumi.sensor_occupy.agl1â),), friendly_name=FriendlyNameMetadata(model=âPresence Sensor FP1Eâ, manufacturer=âAqaraâ), device_alerts=(), filters=(), custom_device_class=None, device_node_descriptor=None, skip_device_configuration=False, adds_metadata=(AddsMetadata(cluster=<class âzigpy.zcl.clusters.general.DeviceTemperatureâ>, endpoint_id=1, cluster_type=<ClusterType.Server: 0>, constant_attributes=frozendict.frozendict({})), AddsMetadata(cluster=<class âzhaquirks.xiaomi.aqara.motion_agl1.OccupancySensingLocalâ>, endpoint_id=1, cluster_type=<ClusterType.Server: 0>, constant_attributes=frozendict.frozendict({})), AddsMetadata(cluster=<class âzhaquirks.xiaomi.aqara.motion_agl1.IasZoneLocalâ>, endpoint_id=1, cluster_type=<ClusterType.Server: 0>, constant_attributes=frozendict.frozendict({}))), removes_metadata=(), replaces_metadata=(ReplacesMetadata(remove=RemovesMetadata(cluster_id=64704, endpoint_id=1, cluster_type=<ClusterType.Server: 0>), add=AddsMetadata(cluster=<class âzhaquirks.xiaomi.aqara.motion_agl1.OppleClusterâ>, endpoint_id=1, cluster_type=<ClusterType.Server: 0>, constant_attributes=frozendict.frozendict({}))),), replaces_cluster_occurrences_metadata=(), entity_metadata=(NumberMetadata(entity_platform=<EntityPlatform.NUMBER: ânumberâ>, entity_type=<EntityType.CONFIG: âconfigâ>, cluster_id=64704, endpoint_id=1, cluster_type=<ClusterType.Server: 0>, initially_disabled=False, attribute_initialized_from_cache=True, translation_key=âapproach_distanceâ, fallback_name=âApproach distanceâ, attribute_name=âapproach_distanceâ, reporting_config=None, min=0, max=6, step=0.1, unit=<UnitOfLength.METERS: âmâ>, mode=None, multiplier=0.01, device_class=<NumberDeviceClass.DISTANCE: âdistanceâ>), ZCLSensorMetadata(entity_platform=<EntityPlatform.SENSOR: âsensorâ>, entity_type=<EntityType.STANDARD: âstandardâ>, cluster_id=64704, endpoint_id=1, cluster_type=<ClusterType.Server: 0>, initially_disabled=False, attribute_initialized_from_cache=True, translation_key=âmotion_distanceâ, fallback_name=âMotion distanceâ, attribute_name=âmotion_distanceâ, reporting_config=None, divisor=1, multiplier=0.01, unit=<UnitOfLength.METERS: âmâ>, device_class=<SensorDeviceClass.DISTANCE: âdistanceâ>, state_class=<SensorStateClass.MEASUREMENT: âmeasurementâ>), ZCLEnumMetadata(entity_platform=<EntityPlatform.SELECT: âselectâ>, entity_type=<EntityType.CONFIG: âconfigâ>, cluster_id=64704, endpoint_id=1, cluster_type=<ClusterType.Server: 0>, initially_disabled=False, attribute_initialized_from_cache=True, translation_key=âmotion_sensitivityâ, fallback_name=âMotion sensitivityâ, enum=<enum âAqaraMotionSensitivityâ>, attribute_name=âmotion_sensitivityâ, reporting_config=None), WriteAttributeButtonMetadata(entity_platform=<EntityPlatform.BUTTON: âbuttonâ>, entity_type=<EntityType.CONFIG: âconfigâ>, cluster_id=64704, endpoint_id=1, cluster_type=<ClusterType.Server: 0>, initially_disabled=False, attribute_initialized_from_cache=True, translation_key=âreset_no_presence_statusâ, fallback_name=âPresence status resetâ, attribute_name=âreset_no_presence_statusâ, attribute_value=1), WriteAttributeButtonMetadata(entity_platform=<EntityPlatform.BUTTON: âbuttonâ>, entity_type=<EntityType.DIAGNOSTIC: âdiagnosticâ>, cluster_id=64704, endpoint_id=1, cluster_type=<ClusterType.Server: 0>, initially_disabled=False, attribute_initialized_from_cache=True, translation_key=ârestart_deviceâ, fallback_name=âRestart deviceâ, attribute_name=ârestart_deviceâ, attribute_value=0)), device_automation_triggers_metadata=frozendict.frozendict({})), QuirksV2RegistryEntry(quirk_file=PosixPath(â/config/zha_quirks/motion_agl1.pyâ), quirk_file_line=118, manufacturer_model_metadata=(ManufacturerModelMetadata(manufacturer=âaqaraâ, model=âlumi.sensor_occupy.agl1â),), friendly_name=FriendlyNameMetadata(model=âPresence Sensor FP1Eâ, manufacturer=âAqaraâ), device_alerts=(), filters=(), custom_device_class=None, device_node_descriptor=None, skip_device_configuration=False, adds_metadata=(AddsMetadata(cluster=<class âzigpy.zcl.clusters.general.DeviceTemperatureâ>, endpoint_id=1, cluster_type=<ClusterType.Server: 0>, constant_attributes=frozendict.frozendict({})), AddsMetadata(cluster=<class âzigpy.zcl.clusters.measurement.OccupancySensingâ>, endpoint_id=1, cluster_type=<ClusterType.Server: 0>, constant_attributes=frozendict.frozendict({}))), removes_metadata=(), replaces_metadata=(ReplacesMetadata(remove=RemovesMetadata(cluster_id=64704, endpoint_id=1, cluster_type=<ClusterType.Server: 0>), add=AddsMetadata(cluster=<class âmotion_agl1.OppleClusterâ>, endpoint_id=1, cluster_type=<ClusterType.Server: 0>, constant_attributes=frozendict.frozendict({}))),), replaces_cluster_occurrences_metadata=(), entity_metadata=(NumberMetadata(entity_platform=<EntityPlatform.NUMBER: ânumberâ>, entity_type=<EntityType.CONFIG: âconfigâ>, cluster_id=64704, endpoint_id=1, cluster_type=<ClusterType.Server: 0>, initially_disabled=False, attribute_initialized_from_cache=True, translation_key=âapproach_distanceâ, fallback_name=âApproach distanceâ, attribute_name=âapproach_distanceâ, reporting_config=None, min=0, max=6, step=0.1, unit=None, mode=None, multiplier=0.01, device_class=<NumberDeviceClass.DISTANCE: âdistanceâ>), ZCLEnumMetadata(entity_platform=<EntityPlatform.SENSOR: âsensorâ>, entity_type=<EntityType.STANDARD: âstandardâ>, cluster_id=64704, endpoint_id=1, cluster_type=<ClusterType.Server: 0>, initially_disabled=False, attribute_initialized_from_cache=True, translation_key=âmotionâ, fallback_name=âMotionâ, enum=<enum âAqaraMotionâ>, attribute_name=âmotionâ, reporting_config=None), ZCLSensorMetadata(entity_platform=<EntityPlatform.SENSOR: âsensorâ>, entity_type=<EntityType.STANDARD: âstandardâ>, cluster_id=64704, endpoint_id=1, cluster_type=<ClusterType.Server: 0>, initially_disabled=False, attribute_initialized_from_cache=True, translation_key=âmotion_distanceâ, fallback_name=âMotion distanceâ, attribute_name=âmotion_distanceâ, reporting_config=None, divisor=1, multiplier=0.01, unit=None, device_class=<SensorDeviceClass.DISTANCE: âdistanceâ>, state_class=<SensorStateClass.MEASUREMENT: âmeasurementâ>), ZCLEnumMetadata(entity_platform=<EntityPlatform.SELECT: âselectâ>, entity_type=<EntityType.CONFIG: âconfigâ>, cluster_id=64704, endpoint_id=1, cluster_type=<ClusterType.Server: 0>, initially_disabled=False, attribute_initialized_from_cache=True, translation_key=âmotion_sensitivityâ, fallback_name=âMotion sensitivityâ, enum=<enum âAqaraMotionSensitivityâ>, attribute_name=âmotion_sensitivityâ, reporting_config=None), WriteAttributeButtonMetadata(entity_platform=<EntityPlatform.BUTTON: âbuttonâ>, entity_type=<EntityType.CONFIG: âconfigâ>, cluster_id=64704, endpoint_id=1, cluster_type=<ClusterType.Server: 0>, initially_disabled=False, attribute_initialized_from_cache=True, translation_key=âreset_no_presence_statusâ, fallback_name=âPresence status resetâ, attribute_name=âreset_no_presence_statusâ, attribute_value=1), WriteAttributeButtonMetadata(entity_platform=<EntityPlatform.BUTTON: âbuttonâ>, entity_type=<EntityType.CONFIG: âconfigâ>, cluster_id=64704, endpoint_id=1, cluster_type=<ClusterType.Server: 0>, initially_disabled=False, attribute_initialized_from_cache=True, translation_key=ârestart_deviceâ, fallback_name=âRestart deviceâ, attribute_name=ârestart_deviceâ, attribute_value=0)), device_automation_triggers_metadata=frozendict.frozendict({}))]
See here: Sun next setting is wrong · Issue #131850 · home-assistant/core · GitHub
I regularly see this problem after updating but it seems to correct itself after midnight. If I update the automations donât kick in for the sun state. If I update in the early morning, the sunrise doesnât work. The next time those come around they seem to be working. Maybe its forgetting the current sun state or miscalculating it?
Curious I started digging and noticed that the core.restore_state doesnât have sensor data.
Perhaps because its listed as a sensor, and sensors are volatile and their data is refreshed the next time they sense, maybe Sun shouldnât be a sensor, or perhaps it just needs to revaluate its current state after restart.
I think what needs to happen is we implement a RestoreEntity method for it, and then decide will it resume from last state or should it simply recalculate its current state.
Not sure if this is relevant: Retain last state change data of a sensor after reboot - #37 by EinSchwerd
its solved. Update in HACS
Honestly? Switch to Docker. Itâs a trivial thing to do (I did it myself) and your problems will go away.
Also on me ZHA is not working (with Lidl coordinator, custom firmware) after 2024.12 update. Reverting back to Core 24.11.3 / Supervizor 2024.11.4 solve the problem.
Yes, after completely deleting the Integration and re-installing, it now works again.
Ran into the exact same thing. If you read the very log message you just posted, it tells you why â multiple matching quirks for your Aqara FP1E presence sensor. The custom quirk made by jeverly which you probably installed has been updated and is now shipped with HA itself. Removing the custom quirk and rebooting will fix things. For sure a very user un-friendly fail-mode by ZHA thoughâŠ
checked all backend logic today, and must have been a handmade user fluke yesterday,
all of my yaml scripts/automations using the modern syntax behaved correctly at sunrise
given the fact I dont have âoldâ syntax anywhere, I must conclude all is well after all.
Thatâs great, thanks for info. Now itâs only who will do it (iâd say the one who âmessed upâ should correct that⊠in any case someone who know how to do itâŠ)
But i guess that in any case we have to wait for next HA update for this to become effectiveâŠ
No. Minor releases are for bug fixes. Thatâs what this is.
Open an issue with the PR and it should be reverted if it is as obvious a mistake as you claim.
As it was said before, if you are using the custom ShellyForHass integration you need to get rid of it and use the Shelly core integration. ShellyForHas has been dead for a year and probably no one will ever fix it.
Upgrading to version 2024.12.0. Get notification âUnable to set up dependencies of âdefault_configâ. Setup failed for dependencies: [âstreamâ]â.Following rtsp:/ based stream cameras stop working. Appreciate any advice.
I meant those minor updates, yes.
But, i never worked with lokalize, so i donât know the interface neither how/where to open that issueâŠ
Me either. Iâll see if I can find out for you.
This ?
Logger: homeassistant.setup
Source: setup.py:416
First occurred: 5 December 2024 at 08:20:54 (1 occurrences)
Last logged: 5 December 2024 at 08:20:54
Error during setup of component stream
File "/usr/src/homeassistant/homeassistant/setup.py", line 416, in _async_setup_component
result = await task
File "/usr/src/homeassistant/homeassistant/components/stream/__init__.py", line 226, in async_setup
await hass.async_add_executor_job(set_pyav_logging, debug_enabled)
File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/stream/__init__.py", line 196, in set_pyav_logging
import av # pylint: disable=import-outside-toplevel
File "/usr/local/lib/python3.13/site-packages/av/__init__.py", line 3, in <module>
from av._core import time_base, library_versions, ffmpeg_version_info
ImportError: Error loading shared library : No such file or directory (needed by /usr/local/lib/python3.13/site-packages/av/../av.libs/libjxl-2cfeb5f2.so.0.10.2)
They probably forgot to put it in the docker for arm
The devs are now aware of the issue.
Thanks a lot for your help! Much appreciated!
File â/usr/src/homeassistant/homeassistant/components/logbook/processor.pyâ, line 259, in _humanify
data = describe_event(event_cache_get(row))
File â/usr/src/homeassistant/homeassistant/components/zha/logbook.pyâ, line 44, in async_describe_zha_event
zha_device = async_get_zha_device_proxy(
hass, event.data[ATTR_DEVICE_ID]
).device
File â/usr/src/homeassistant/homeassistant/components/zha/helpers.pyâ, line 1060, in async_get_zha_device_proxy
zha_gateway_proxy = get_zha_gateway_proxy(hass)
File â/usr/src/homeassistant/homeassistant/components/zha/helpers.pyâ, line 1039, in get_zha_gateway_proxy
raise ValueError(âNo gateway object existsâ)
ValueError: No gateway object exists
2024-12-06 13:59:58.253 ERROR (DbWorker_0) [homeassistant.components.logbook.processor] Error with zha describe event for zha_event
).device
2024-12-06 13:59:58.262 ERROR (DbWorker_0) [homeassistant.components.logbook.processor] Error with zha describe event for zha_event
).device
2024-12-06 13:59:58.268 ERROR (DbWorker_0) [homeassistant.components.logbook.processor] Error with zha describe event for zha_event
).device
