2024.2: More voice, more icons, more integrations, more... everything!
I do not have the matter diagnostics and actions, even the “share device” is not there, only “download diagnostics” and the three dots only shows “remove”, same as before the update :confused:
Share device doesn’t work as far as I can tell anyway.
Edit: just kidding. Matter server update fixed it
Yeah but Google actively tries to kill apps that havent been opened in a while. Sounds like a good idea to let tokens be indefinate or a year
Raised that same question in beta. It’s not causing a repair because yaml is not deprecated.
For the same reason they are not imported.
You can delete yaml and add them in Ui in a snap though
Never thought of such a feature, and i have noone to share with anyway :smile:
No, I plan to keep it as a custom integration.
this is on purpose to differentiate between proximity configuration with same monitored zone. you can easily rename the created service to your needs.
btw why did you create 4 proximity configuration for the same zone? do you want to track different groups of persons or use different “ignored zone” settings?
Alrighty, so scenario of my dad’s phone is handled and should not be a concern.
This would just leave me with the odd ‘laptop I’ve not used in a while’ case. I guess I can live with it but I’d love to be able to customize the token expiration.
Personally, I’d set it to a year - I know, quite long.
In terms of using long lived tokens, I guess that would also be an option but I’m not aware of how to achieve authentication in the app/web UI with an already existing token.
Just wanted to say I’m loving the update! Drag and drop, CSV export from history, and many other long-term wishlist items coming all at once. Thanks!
You can have more than 1 long lived token ! , Maybe you can create 1 for this purpose
Awesome - changing the theme resolved the problem.
Thank you.
For me the time integration stopped working on upgrade without any repair options. Had to read the changelog and put 2+2 together that time&date are now configurable via UI. Only after I added the time integration via the UI did my automations with a time trigger started working again. Not great. Also no error message anywhere in the automations that my time-based automation does not have an integration active for it to trigger from.
Still can’t authenticate Tuya even after changing theme. Where is the fracking QR code I’m supposed to scan?
Thanks for your explanation, all clear now! :+1:t2:
There is no code for tuya integration in Smart Life app
I’m getting this repair warning since upgrading:
The `beat` Time & Date sensor is being removed
This stops working in version 2024.7.0. Please address before upgrading.
Please remove the `beat` key from the `display_options` for the time_date entry in your configuration.yaml file and restart Home Assistant to fix this issue.
I can see that this is due to this change: Deprecate 'beat' display option in Time & Date by emontnemery · Pull Request #106871 · home-assistant/core · GitHub
I don’t what ‘beat’ is, I’m not seeing a ‘time_date’ entry in my configuration.yaml and I don’t know what is being referred to by ‘display_options’ :confused:
The only way I could get the Tuya QR was to delete the integration and re-install.
Hi, Look in your sensors.yaml file.
Thank you!
After you try to add the updated Tuya integration and get an empty screen where the QR code should be, restart Home Assistant and try to add the integration again. It should work then.
(This is assuming you’re not using a custom theme. If you are, reset back to the default Home Assistant theme, restart, and re-add the integration)
