I am using Minimalist ui. After the update today (2024.4.0) I can no longer navigate to my different views. I changed Hold action to tap action just to see if that would work and didn’t. It’s the navigation path and not the action that quit working. Anybody else have this happen and any advise? I restored my back up and updated again and it happened a second time? My Settings cog at the top right for “config/dashboard” is also not working. Update: If I use tap bar I can navigate my views, and this issue only seems to be affecting my home.yaml? All other views the nav paths are working. Theres no difference in the navigation code between the home.yaml and say the LivingRoom.yaml. I can’t go from home to living room but i can go from living room back to home?
For some reason I had to go back and put all off my navigation paths in “…” which I didn’t before.
