I upgraded yesterday and my install is constantly crashing now, it seems to be automation related and I found this t hread, Home Assistant crashing on 2024.4.x but it is a little lite on the details
home-assistant | 2024-04-16 04:58:28.942 ERROR (Recorder) [homeassistant] Error doing job: Task was destroyed but it is pending!
home-assistant | 2024-04-16 04:58:28.949 ERROR (MainThread) [homeassistant] Error doing job: Exception in callback <_asyncio.TaskStepMethWrapper object at 0x7f54fbdeb1c0>()
home-assistant | Traceback (most recent call last):
home-assistant | File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run
home-assistant | self._context.run(self._callback, *self._args)
home-assistant | RuntimeError: Cannot enter into task <Task pending name='Task-231270' coro=<BaseSelectorEventLoop._accept_connection2() running at /usr/local/lib/python3.12/asyncio/selector_events.py:213>> while another task <Task pending name='Ping 192.168.1.102 - Terry - refresh' coro=<DataUpdateCoordinator._handle_refresh_interval() running at /usr/src/homeassistant/homeassistant/helpers/update_coordinator.py:258> wait_for=<Future finished result=None> cb=[set.remove(), set.remove()]> is being executed.
home-assistant | 2024-04-16 04:58:29.060 ERROR (MainThread) [homeassistant] Error doing job: Exception in callback <_asyncio.TaskStepMethWrapper object at 0x7f54fbd6a7a0>()
2024-04-15 16:15:56.752 ERROR (MainThread) [homeassistant] Error doing job: Exception in callback Task.task_wakeup()
File “/usr/local/lib/python3.12/asyncio/events.py”, line 88, in _run
RuntimeError: Leaving task <Task pending name=‘Task-17488’ coro=<WebSocketHandler._writer() running at /usr/src/homeassistant/homeassistant/components/websocket_api/http.py:138> wait_for=> does not match the current task .
2024-04-15 16:15:56.759 ERROR (MainThread) [homeassistant] Error doing job: Exception in callback <_asyncio.TaskStepMethWrapper object at 0x7f169e913d90>()
Often it will mention a specific automation, like it tried to run it and then it goes crazy and I have been disabling those automations but, what is wrong with them?
an example of one;
- alias: when outside temp is lower than the aircon setting while cooling
- platform: state
entity_id: sensor.aarlo_temperature_babymonitor
- platform: state
entity_id: sensor.gosford_temp
condition:
- condition: state
entity_id: input_boolean.house_status
state: 'on'
- condition: template
value_template: "{{ states('climate.daikinap20019') == 'cool' }}"
value_template: "{{ state_attr('climate.daikinap20019', 'temperature') | float(0) > states('sensor.gosford_temp') | int(0) }}"
value_template: "{% if states('sensor.aarlo_temperature_babymonitor') | float(0) >= states('input_number.matthias_max_temp') | float(0) - 3 %}False{%else%}True{% endif %}"
- continue_on_error: True
message: |-
It is colder outsider, air con off
title: "The AirCon"
service: notify.jurgen
- service: climate.turn_off
entity_id: climate.daikinap20019
any thoughts?
