2024.4.4 → 2024.5.0 issue
I have just installed version 2024.5.0, but at every reboot attempt the message “Home Assistant is starting, not everything will be available until it is finished” remains visible and I have verified that several devices are not available. I then went back to version 2024.4.4 and with this everything works fine. I tried to put the registry here, but it turns out to be too large. How can I do? Could you help me solve the problem? Thank you.
This is part of the log, I hope it is sufficient:
2024-05-03 10:09:38.163 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/config/custom_components/tuya_local/device.py", line 147, in actually_start
self._refresh_task = self._hass.async_create_task(self.receive_loop())
File "/usr/src/homeassistant/homeassistant/core.py", line 816, in async_create_task
self.verify_event_loop_thread("async_create_task")
File "/usr/src/homeassistant/homeassistant/core.py", line 440, in verify_event_loop_thread
frame.report(
File "/usr/src/homeassistant/homeassistant/helpers/frame.py", line 162, in report
_report_integration(what, integration_frame, level, error_if_integration)
File "/usr/src/homeassistant/homeassistant/helpers/frame.py", line 203, in _report_integration
raise RuntimeError(
RuntimeError: Detected that custom integration 'tuya_local' calls async_create_task from a thread at custom_components/tuya_local/device.py, line 147: self._refresh_task = self._hass.async_create_task(self.receive_loop()). Please report it to the author of the 'tuya_local' custom integration.
2024-05-03 10:09:38.202 WARNING (MainThread) [py.warnings] /usr/local/lib/python3.12/asyncio/base_events.py:1973: RuntimeWarning: coroutine 'TuyaLocalDevice.receive_loop' was never awaited
handle = self._ready.popleft()
2024-05-03 10:09:38.202 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
frame.report(
raise RuntimeError(
2024-05-03 10:09:38.212 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
frame.report(
raise RuntimeError(
2024-05-03 10:09:38.235 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
frame.report(
raise RuntimeError(
2024-05-03 10:09:38.238 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
frame.report(
raise RuntimeError(
2024-05-03 10:09:38.246 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
frame.report(
raise RuntimeError(
2024-05-03 10:09:38.271 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
frame.report(
raise RuntimeError(
2024-05-03 10:09:38.284 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
frame.report(
raise RuntimeError(
2024-05-03 10:09:38.286 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
frame.report(
raise RuntimeError(
2024-05-03 10:09:38.301 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
frame.report(
raise RuntimeError(
2024-05-03 10:09:38.305 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
frame.report(
raise RuntimeError(
2024-05-03 10:09:38.316 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
frame.report(
raise RuntimeError(
2024-05-03 10:09:38.320 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
frame.report(
raise RuntimeError(
Looks like it’s something to do with the tuya_local
integration. Try disabling it and restarting.
You might also want to open an issue on the custom integration’s github as well.
I found a thread already open on GitHub:
It seems to be a general problem and is being discussed.
Thanks for the suggestion.
