2024.5.3 Rest Error fetching data
Hi everybody. I installed the 2024.5.3 and now I get Rest error fetching data.
When I add the url on the browser the source is working correct. Somehow something is wrong.
Anybody have this issue?
Here are the sensors I get the error.
rest:
  • resource: “http://192.168.1.200/data.jsn
    scan_interval: 10
    • name: “ELWAXX_Power”
      unique_id: “elwaxx_power”
      value_template: “{{ value_json.power }}”
      unit_of_measurement: “W”
      device_class: power
      state_class: measurement
    • name: “ELWAXX_TEMP”
      unique_id: “elwaxx_temp”
      value_template: “{{ value_json.temp1 / 10 }}”
      unit_of_measurement: “°C”
      device_class: temperature
    • name: “ELWAXX_Target”
      unique_id: “elwaxx_target”
      value_template: “{{ value_json.ww1target / 10 }}”
When I use the 2024.4.3 everything is working correct.
The issue start after the 2024.5.1
Any suggestion or help? Thanks in advance.
P.S. the http://192.168.1.200/data.jsn is working/provide data correct
Thanks francisp. Here is the code.
rest:
  - resource: "http://192.168.1.200/data.jsn"
    scan_interval: 10
      - name: "ELWAXX_Power"
        unique_id: "elwaxx_power"
        value_template: "{{ value_json.power }}"
        unit_of_measurement: "W"
        device_class: power
      - name: "ELWAXX_TEMP"
        unique_id: "elwaxx_temp"
        value_template: "{{ value_json.temp1 / 10 }}"
        unit_of_measurement: "°C"
      - name: "ELWAXX_Target"
        unique_id: "elwaxx_target"
        value_template: "{{ value_json.ww1target / 10 }}"
Here are the log.
Logger: homeassistant.components.rest.data
Source: components/rest/data.py:127
integration: RESTful (documentation, issues)
First occurred: 06:58:09 (30 occurrences)
Last logged: 07:45:43
Error fetching data: http://192.168.1.200/data.jsn failed with All connection attempts failed
Error fetching data: http://192.168.1.200/data.jsn failed with Server disconnected without sending a response.
First occurred: 07:47:56 (1 occurrences)
Last logged: 07:47:56
Is that resource really correct? Typically those should end with .json but in your case it’s .jsn.
Does it work from your browser to get the file?
