Looks like there were updates around 5 months ago. Perhaps you misread gihub? A couple of files in the root directory haven’t been changed in 2 years, but in /src/ there are changes.
Last update I saw just now was July 2023, so yeah, I was mistaken there, but I was also going on this as well: Help Wanted
I’m pretty sure someone forked the repo and took it over. Maybe I’m miss remembering.
I couldn’t find the forked repo, thanks for posting it
I was using the beta and now in 2024.5.0 but it is not showing the “collapse” arrow. I’m a sad panda.
There is a team actively maintaining and developing a fork in the absence of the original developer’s availability for the project.
Edit - I see this has been mentioned.
I’ve been happily using the fork for a couple weeks now. I started using in when running into issues with frigate notifications that were resolved with the fork.
oh man, I was todays old to learn that you can change icon of the automation
Have you cleared your cache ?
That work fine for me
After Update to 2024.5.0 the Zigbee Home Automation goes to Initialize state.
The ZHABridge works well.
On Restart Home-Assistant (Not the Host) the function will work but the Initialize of the Integration starts again. Sometimes for a short period of time it works.
Meantime is does not work until a restart of Home-Assistant again.
My logs are more or less disabled (critical only). There is way too much for my small Pi to handle - but I just enabled the logs and reupgraded again and it seems like the dreame plugin kills it:
[root@pi4](2):~
# cat /home/homeassistant/.homeassistant/home-assistant.log
2024-05-03 11:12:12.366 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration adaptive_lighting which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-03 11:12:12.369 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration media_player_template which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-03 11:12:12.371 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration ac_infinity which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-03 11:12:12.373 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration home_connect_alt which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-03 11:12:12.375 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration nintendo_parental which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-03 11:12:12.377 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-03 11:12:12.379 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration thermal_comfort which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-03 11:12:12.380 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration skyq which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-03 11:12:12.382 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration var which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-03 11:12:12.384 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration localtuya which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-03 11:12:12.386 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-03 11:12:12.387 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-03 11:12:12.388 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration mbapi2020 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-03 11:12:12.389 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration webrtc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-03 11:12:12.390 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration ble_monitor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-03 11:12:12.391 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration daily which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-03 11:12:12.392 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration dreame_vacuum which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-03 11:12:12.393 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration imagedirectory which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-03 11:12:12.395 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration icloud3 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-03 11:12:12.846 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //home/homeassistant/.homeassistant/home-assistant_v2.db was shutdown cleanly
2024-05-03 11:12:12.889 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=263 from 2024-05-03 09:11:15.062079)
2024-05-03 11:13:12.535 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: {('mbapi2020', '4e007805699387610a19e194758d817b'): 2428281.789092767, ('mbapi2020', 'f12a7a6d4db0fa970e18571425a2124d'): 2428281.791315036, ('min_max', '58531e3f0ac3ea77efb759353a7bdea6'): 2428281.894931041, ('min_max', '0d37a08eeb29c318d1465fe8293f9423'): 2428281.895358703}
2024-05-03 11:13:13.069 ERROR (Thread-2) [root] Uncaught thread exception
File "/usr/local/lib/python3.12/threading.py", line 1073, in _bootstrap_inner
self.run()
File "/home/homeassistant/.homeassistant/custom_components/ble_monitor/__init__.py", line 633, in run
mysocket[hci] = aiobs.create_bt_socket(hci)
File "/home/homeassistant/.homeassistant/deps/lib/python3.12/site-packages/aioblescan/aioblescan.py", line 1691, in create_bt_socket
family=socket.AF_BLUETOOTH, type=socket.SOCK_RAW, proto=socket.BTPROTO_HCI
AttributeError: module 'socket' has no attribute 'AF_BLUETOOTH'
2024-05-03 11:13:15.168 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to import_module inside the event loop by custom integration 'dreame_vacuum' at custom_components/dreame_vacuum/dreame/protocol.py, line 67: timezone = datetime.datetime.now(tzlocal.get_localzone()).strftime("%z") (offender: /usr/local/lib/python3.12/importlib/resources/_common.py, line 82: return importlib.import_module(cand)), please create a bug report at https://github.com/Tasshack/dreame-vacuum/issues
2024-05-03 11:13:15.176 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to import_module inside the event loop by custom integration 'dreame_vacuum' at custom_components/dreame_vacuum/dreame/protocol.py, line 67: timezone = datetime.datetime.now(tzlocal.get_localzone()).strftime("%z") (offender: /usr/local/lib/python3.12/importlib/resources/_common.py, line 82: return importlib.import_module(cand)), please create a bug report at https://github.com/Tasshack/dreame-vacuum/issues
2024-05-03 11:13:15.185 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to import_module inside the event loop by custom integration 'dreame_vacuum' at custom_components/dreame_vacuum/dreame/protocol.py, line 67: timezone = datetime.datetime.now(tzlocal.get_localzone()).strftime("%z") (offender: /usr/local/lib/python3.12/importlib/resources/_common.py, line 82: return importlib.import_module(cand)), please create a bug report at https://github.com/Tasshack/dreame-vacuum/issues
2024-05-03 11:13:16.280 ERROR (MainThread) [homeassistant.components.climate] The mqtt platform for the climate integration does not support platform setup. Please remove it from your config.
2024-05-03 11:13:16.281 ERROR (MainThread) [homeassistant.components.climate] The mqtt platform for the climate integration does not support platform setup. Please remove it from your config.
2024-05-03 11:13:16.282 ERROR (MainThread) [homeassistant.components.climate] The mqtt platform for the climate integration does not support platform setup. Please remove it from your config.
2024-05-03 11:13:18.986 ERROR (MainThread) [homeassistant.setup] Error during setup of component ebusd
File "/home/homeassistant/.local/lib/python3.12/site-packages/homeassistant/setup.py", line 404, in _async_setup_component
result = await task
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/home/homeassistant/.local/lib/python3.12/site-packages/homeassistant/components/ebusd/__init__.py", line 76, in setup
"sensor_types": SENSOR_TYPES[circuit],
KeyError: '470'
2024-05-03 11:13:20.131 WARNING (ImportExecutor_0) [homeassistant.helpers.typing] HomeAssistantType was used from webrtc, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.HomeAssistant instead, please report it to the author of the 'webrtc' custom integration
2024-05-03 11:13:20.153 WARNING (ImportExecutor_0) [homeassistant.helpers.typing] ServiceCallType was used from webrtc, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.ServiceCall instead, please report it to the author of the 'webrtc' custom integration
2024-05-03 11:13:21.165 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' accesses hass.components.frontend. This is deprecated and will stop working in Home Assistant 2024.9, it should be updated to import functions used from frontend directly at custom_components/hacs/frontend.py, line 68: hass.components.frontend.async_register_built_in_panel(, please create a bug report at https://github.com/hacs/integration/issues
2024-05-03 11:13:21.292 ERROR (MainThread) [homeassistant.setup] Setup failed for 'brother': Unable to import component: No module named 'asyncore'
File "/home/homeassistant/.local/lib/python3.12/site-packages/homeassistant/setup.py", line 322, in _async_setup_component
component = await integration.async_get_component()
File "/home/homeassistant/.local/lib/python3.12/site-packages/homeassistant/loader.py", line 996, in async_get_component
self._component_future.result()
File "/home/homeassistant/.local/lib/python3.12/site-packages/homeassistant/loader.py", line 976, in async_get_component
comp = await self.hass.async_add_import_executor_job(
File "/home/homeassistant/.local/lib/python3.12/site-packages/homeassistant/loader.py", line 1036, in _get_component
ComponentProtocol, importlib.import_module(self.pkg_path)
File "/home/homeassistant/.local/lib/python3.12/site-packages/homeassistant/util/loop.py", line 144, in protected_loop_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 995, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/home/homeassistant/.local/lib/python3.12/site-packages/homeassistant/components/brother/__init__.py", line 9, in <module>
from brother import Brother, BrotherSensors, SnmpError, UnsupportedModelError
File "/home/homeassistant/.homeassistant/deps/lib/python3.12/site-packages/brother/__init__.py", line 11, in <module>
import pysnmp.hlapi.asyncio as hlapi
File "/home/homeassistant/.homeassistant/deps/lib/python3.12/site-packages/pysnmp/hlapi/__init__.py", line 10, in <module>
from pysnmp.hlapi import auth
File "/home/homeassistant/.homeassistant/deps/lib/python3.12/site-packages/pysnmp/hlapi/auth.py", line 7, in <module>
from pysnmp.entity import config
File "/home/homeassistant/.homeassistant/deps/lib/python3.12/site-packages/pysnmp/entity/config.py", line 8, in <module>
from pysnmp.carrier.asyncore.dgram import udp, udp6, unix
File "/home/homeassistant/.homeassistant/deps/lib/python3.12/site-packages/pysnmp/carrier/asyncore/dgram/udp.py", line 9, in <module>
from pysnmp.carrier.asyncore.dgram.base import DgramSocketTransport
File "/home/homeassistant/.homeassistant/deps/lib/python3.12/site-packages/pysnmp/carrier/asyncore/dgram/base.py", line 10, in <module>
from pysnmp.carrier.asyncore.base import AbstractSocketTransport
File "/home/homeassistant/.homeassistant/deps/lib/python3.12/site-packages/pysnmp/carrier/asyncore/base.py", line 9, in <module>
import asyncore
ModuleNotFoundError: No module named 'asyncore'
2024-05-03 11:13:22.889 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] CURRENT_HVAC_HEAT was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACAction.HEATING instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:22.899 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] CURRENT_HVAC_IDLE was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACAction.IDLE instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:22.915 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] HVAC_MODE_AUTO was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.AUTO instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:22.932 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] HVAC_MODE_HEAT was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.HEAT instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:22.944 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] HVAC_MODE_OFF was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.OFF instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:22.957 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] SUPPORT_PRESET_MODE was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.PRESET_MODE instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:22.970 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] SUPPORT_TARGET_TEMPERATURE was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.TARGET_TEMPERATURE instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:22.983 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] SUPPORT_TARGET_TEMPERATURE_RANGE was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.TARGET_TEMPERATURE_RANGE instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:22.994 WARNING (ImportExecutor_0) [homeassistant.const] TEMP_CELSIUS was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use UnitOfTemperature.CELSIUS instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:23.006 WARNING (ImportExecutor_0) [homeassistant.const] TEMP_FAHRENHEIT was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use UnitOfTemperature.FAHRENHEIT instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:23.023 WARNING (ImportExecutor_0) [homeassistant.components.cover] SUPPORT_CLOSE was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use CoverEntityFeature.CLOSE instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:23.038 WARNING (ImportExecutor_0) [homeassistant.components.cover] SUPPORT_OPEN was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use CoverEntityFeature.OPEN instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:23.056 WARNING (ImportExecutor_0) [homeassistant.components.cover] SUPPORT_SET_POSITION was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use CoverEntityFeature.SET_POSITION instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:23.067 WARNING (ImportExecutor_0) [homeassistant.components.cover] SUPPORT_STOP was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use CoverEntityFeature.STOP instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:23.078 WARNING (ImportExecutor_0) [homeassistant.components.cover] SUPPORT_CLOSE was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use CoverEntityFeature.CLOSE instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:23.089 WARNING (ImportExecutor_0) [homeassistant.components.cover] SUPPORT_OPEN was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use CoverEntityFeature.OPEN instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:23.102 WARNING (ImportExecutor_0) [homeassistant.components.cover] SUPPORT_SET_POSITION was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use CoverEntityFeature.SET_POSITION instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:23.113 WARNING (ImportExecutor_0) [homeassistant.components.cover] SUPPORT_STOP was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use CoverEntityFeature.STOP instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:23.136 WARNING (ImportExecutor_0) [homeassistant.components.fan] SUPPORT_DIRECTION was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use FanEntityFeature.DIRECTION instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:23.148 WARNING (ImportExecutor_0) [homeassistant.components.fan] SUPPORT_OSCILLATE was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use FanEntityFeature.OSCILLATE instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:23.159 WARNING (ImportExecutor_0) [homeassistant.components.fan] SUPPORT_SET_SPEED was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use FanEntityFeature.SET_SPEED instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:23.170 WARNING (ImportExecutor_0) [homeassistant.components.fan] SUPPORT_DIRECTION was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use FanEntityFeature.DIRECTION instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:23.183 WARNING (ImportExecutor_0) [homeassistant.components.fan] SUPPORT_OSCILLATE was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use FanEntityFeature.OSCILLATE instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:23.195 WARNING (ImportExecutor_0) [homeassistant.components.fan] SUPPORT_SET_SPEED was used from localtuya, this is a deprecated constant which will be removed in HA Core 2025.1. Use FanEntityFeature.SET_SPEED instead, please report it to the author of the 'localtuya' custom integration
2024-05-03 11:13:23.294 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'localtuya' accesses hass.helpers.service. This is deprecated and will stop working in Home Assistant 2024.11, it should be updated to import functions used from service directly at custom_components/localtuya/__init__.py, line 164: hass.helpers.service.async_register_admin_service(, please create a bug report at https://github.com/rospogrigio/localtuya/issues
2024-05-03 11:13:23.748 WARNING (ImportExecutor_0) [homeassistant.helpers.typing] EventType was used from icloud3, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.Event instead, please report it to the author of the 'icloud3' custom integration
2024-05-03 11:13:23.783 WARNING (ImportExecutor_0) [homeassistant.helpers.typing] EventType was used from icloud3, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.Event instead, please report it to the author of the 'icloud3' custom integration
2024-05-03 11:13:24.066 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'ble_monitor' accesses hass.helpers.device_registry. This is deprecated and will stop working in Home Assistant 2024.11, it should be updated to import functions used from device_registry directly at custom_components/ble_monitor/binary_sensor.py, line 134: dev_registry = hass.helpers.device_registry.async_get(hass), please create a bug report at https://github.com/custom-components/ble_monitor/issues
2024-05-03 11:13:24.076 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'ble_monitor' accesses hass.helpers.entity_registry. This is deprecated and will stop working in Home Assistant 2024.11, it should be updated to import functions used from entity_registry directly at custom_components/ble_monitor/binary_sensor.py, line 135: ent_registry = hass.helpers.entity_registry.async_get(hass), please create a bug report at https://github.com/custom-components/ble_monitor/issues
2024-05-03 11:13:24.349 WARNING (MainThread) [homeassistant.components.light] Entity None (<class 'custom_components.localtuya.light.LocaltuyaLight'>) is using deprecated supported features values which will be removed in HA Core 2025.1. Instead it should use <LightEntityFeature.EFFECT|19: 23> and color modes, please create a bug report at https://github.com/rospogrigio/localtuya/issues and reference https://developers.home-assistant.io/blog/2023/12/28/support-feature-magic-numbers-deprecation
2024-05-03 11:13:24.349 WARNING (MainThread) [homeassistant.components.light] None (<class 'custom_components.localtuya.light.LocaltuyaLight'>) does not set supported color modes, this will stop working in Home Assistant Core 2025.3, please create a bug report at https://github.com/rospogrigio/localtuya/issues
2024-05-03 11:13:24.351 WARNING (MainThread) [homeassistant.components.light] Entity None (<class 'custom_components.localtuya.light.LocaltuyaLight'>) is using deprecated supported features values which will be removed in HA Core 2025.1. Instead it should use <LightEntityFeature.EFFECT|3: 7> and color modes, please create a bug report at https://github.com/rospogrigio/localtuya/issues and reference https://developers.home-assistant.io/blog/2023/12/28/support-feature-magic-numbers-deprecation
2024-05-03 11:13:24.351 WARNING (MainThread) [homeassistant.components.light] None (<class 'custom_components.localtuya.light.LocaltuyaLight'>) does not set supported color modes, this will stop working in Home Assistant Core 2025.3, please create a bug report at https://github.com/rospogrigio/localtuya/issues
2024-05-03 11:13:24.354 WARNING (MainThread) [homeassistant.components.light] Entity None (<class 'custom_components.localtuya.light.LocaltuyaLight'>) is using deprecated supported features values which will be removed in HA Core 2025.1. Instead it should use <LightEntityFeature.EFFECT|3: 7> and color modes, please create a bug report at https://github.com/rospogrigio/localtuya/issues and reference https://developers.home-assistant.io/blog/2023/12/28/support-feature-magic-numbers-deprecation
2024-05-03 11:13:24.354 WARNING (MainThread) [homeassistant.components.light] None (<class 'custom_components.localtuya.light.LocaltuyaLight'>) does not set supported color modes, this will stop working in Home Assistant Core 2025.3, please create a bug report at https://github.com/rospogrigio/localtuya/issues
2024-05-03 11:13:24.577 WARNING (MainThread) [custom_components.sonoff] Can't login in auto mode: TimeoutError()
2024-05-03 11:13:27.162 WARNING (MainThread) [homeassistant.helpers.entity] Entity camera.rosi_map (<class 'custom_components.dreame_vacuum.camera.DreameVacuumCameraEntity'>) is using deprecated supported features values which will be removed in HA Core 2025.1. Instead it should use <CameraEntityFeature: 0>, please create a bug report at https://github.com/Tasshack/dreame-vacuum/issues and reference https://developers.home-assistant.io/blog/2023/12/28/support-feature-magic-numbers-deprecation
Here the memory usage increases massively until OOM.
In automations, when adding an “entity - numeric status” trigger or condition, the number I input will be changed to 0,1 lower. So 15 becomes 14,9 and 1000 becomes 999,9. Using the Dutch locale for number (so the “,” is the decimal point).
That’s definitely it. Well spotted.
Question on floors and areas.
I have areas defined for all the rooms in my house, including stairs. These don’t fit neatly into ‘floors’, since by definition they cross floors. So far I’m just excluding them from floors entirely, but I’d rather have them be able to exist in both floors.
How are others dealing with this? Is there already an enhancement in the works?
There are a number of ways to handle this:
- Put it on the floor that makes the most sense.
- Make an additional floor just for the stairs.
Typically people are going with #2 because you can specify multiple floors on service calls.
The upgrade went fine for me. The only thing I’m noticing that is not working right is the new data table features. If I go into Automations, it will save my preference for the sort and group, but if I set it to NO GROUPING, it does not save this. If I pick any of the group types, it remembers that. It just doesn’t save if I change it to No Grouping.
Previous issue with Matter Server integration now resolved on 2024.5.1 hotfix. Everything working perfect again.
Nice work!
Liking the new grouping and Energy devices UX improvements.
They just released an update (I personally have not had a chance to test yet) but in the meantime, their dev release fixed/allowed upgrade to 2024.5 to finish successfully.
Upgrade from 2024.4.4 to 2024.5.1 whent great. I was a bit scared with both MQTT and Matter Server in my environment. Smooth as silk -thanks for all the hard work. Looking forward to messing with the new features.
