ianadd
(ian)
June 7, 2024, 2:35am
1
This upgrade warns I need to upgrade to v3.0 and pay a subscription to continue to use openweathermap.
I decide to delete the integration and use open-meteo as it is free.
I go to integrations and delete the integration entry - one device and 27 entities.
The integration disappears from the integrations page.
Deprecation warning remains and when clicked reports an error:
Config flow could not be loaded: 500 Internal Server Error Server got itself in trouble
Restart of HA and the integration reappears !!!
you don’t need to pay, you get 2,000 API calls / day for free
ianadd
(ian)
June 7, 2024, 2:57am
3
Thanks for that, but the actual issue - removal of the integration remains.
Arh
June 7, 2024, 6:14am
4
I had this issue. After deletion of the integration the warning was still there. Restarted HA and the I could then confirm the problem was solved by pressing submit.
But if you restart with the integration configured (after deleting it and re-adding it, but before rebooting), you will still get the same error.
Deleting the integration, rebooting, clearing the repair, AND then re-adding the integration fixed it for me.
eliliam
(Eli Smith)
June 8, 2024, 5:52am
6
I’m in the same boat and trying to fix it, what do you mean by “clearing the repair”?
ziptbm
June 8, 2024, 12:19pm
7
After uninstalling the integration and rebooting, the repair no longer shows the error and instead provides a “submit” option to clear it.
Then reinstall and configure. But if the integration is still installed over a reboot, the error persists.
