2024.6: Dipping our toes in the world of AI using LLMs šŸ¤–
Agreed, I think most of the work here is the pipeline between the HA instance an its prompts (entity names, etc.), and the HA instance and the response. What happens between the prompt and the response just goes through the API.
In that sense it makes the most sense to get rolling using the OpenAI API so people can test and try things out. I’m running Ollama locally now, but while the local solutions are working well, they are also changing fast, APIs still shifting, and setting them up can be tricky, especially if you are hoping to use your GPU for larger models.
I’m sure this is ultimately the goal to support, it just takes time that runs in parallel to the time needed to integrate the responses with HA’s controls (which is what we are seeing here).
Is there a documentation how to change the background picture? I am not finding it.
The most useful application of LLMs in HA would be to be able to build automations and scripts based on prompts.
ā€œCreate an automation that turns on the living room light when I’m in the room and turns it off automatically when the upstairs is vacant for at least 30 minutes. If it’s after 8pm turn on the lamp insteadā€
It’s a relatively fixed problem space in terms of variables. It would be a lot easier than using copilots hacked together YAML since you could have deep knowledge of the triggers, conditions, and actions available.
I’d prioritize that higher than Assist integration IMO.
Edit dashboard > edit specific view > background tab.
Hmmmmm. So which add-on…? The url does nothing…
Looks like a minor bug caused by the TasmoBackup Add-on will come up on this one.
Ticket (kinda) open… you’ll get a warning an add-on (not identified on-screen correctly) has a ā€œmissing repositoryā€.
Great release again!
For section dashboard view: I would really like to make a 2 column wide section, should I submit a request on github?
Fairly uneventful update. :tada:
Schedule helper UI is broken in 2024.6.0 though.
It’s coming. :smiley_cat:
Yeah, that’s totally fair. I’m not used to HA development prioritizing an external service first, but I can understand that it might be easier to start with that for this particular functionality.
Mostly, I just wish this had been addressed a little more explicitly. I don’t disagree that ā€œdipping our toesā€ implies a beginning, but I would have loved an acknowledgment in the blog post, like: ā€œWe’re launching this feature with support for external LLM services to begin with. In the future, Home Assistant will also support local-only LLMs like Ollama.ā€
Ollama is not an LLM but a service that is able to run most local LLMs. It’s been added to Home Assistant in 2024.4: Ollama - Home Assistant
As we mentioned in the live stream, and will further expand on in our deep dive blog post tomorrow, we’re collaborating with NVIDIA to bring control of Home Assistant to Ollama. It doesn’t support it out of the box nor are any of the main open source models tuned for it. It’s something that needs to be built from scratch and something NVIDIA showed a prototype of last week: https://youtu.be/aq7QS9AtwE8?si=yZilHo4uDUCAQiqN
Fair! I’m excited to learn more. As for the Ollama bit, you got me; I’m not entirely sure how all the pieces intersect, and mostly I just meant ā€œsome sort of local LLMā€.
That is amazing… congrats! I am watching NVIDIA key developers doing stuff with Home Assistant, same folks at the company that just passed Apple’s valuation, over USD 3 Trillion and are work with Musk company’s Tesla, X … keep it up and feel good that you are doing some important and fun work!
How about adding Azure OpenAI Conversation to Home Assistant Cloud? In that way I can afford more bill than $65 since I can discontinue my OpenAI subscription. Of course it should be an option for who wants to use.
We already have Google Assistant and Alexa on Home Assistant Cloud. Why not OpenAI?
Big thank you to all of the developers for another great release. Excited to install it tonight after the toddler falls asleep.
Matt
While I like some of the intention behind integrating AI into Home Assistant, I think it’s kind of misleading to say that the LLM will be ā€œunderstanding the intention behind the spoken commandā€. LLMs run statistical calculations to determine the most likely response to a query. They have no intelligence as we know it. No true knowledge. They just predict the most likely sequence of tokens.
The demonstration of the AI voice assistant, while interesting, left me wondering. Is it better to say ā€œI’m doing a meeting. Make sure people see my faceā€. Or to simply say ā€œTurn on my webcam lightā€. How subtle do you expect home commands to be that they require the energy and processing overhead required by an LLM. I fail to see the use cases. I hope that the Home Assistant team concentrates on continuing to make home automation that fits the habits of regular people.
Strongly seconded.
Yep, I would much rather HA Voice be able to handle minor mistakes in my speech locally and turn things on/off etc, than rely on an LLM to figure out what I want from some obscure request.
One idea for background images - allow an image of a room picture to a room card or card section. This will give a visual cue for room controls rather than text or or just an icon.
One control on images would be a transparency llevel, so not to make the background images too distracting.
The new 24.6 release is fantastic and makes me really eager to get my hands dirty and replace all those Amazon Echos with something that actually can understand what I meant to say.
And here comes the problem - replace them with what? Are there still no aesthetically pleasing devices out there? Or at least some nice 3D printed cases to put the ESP32 wire hell? Any ideas are welcome, thank you.
