After updating to 2024.7 (I think) I have had nothing but issues. Firstly, all of the entities from Zigbee2MQTT were duplicated with name suffixed by “_2” and old entities were unavailable. Had to manually delete old entities and rename the new ones.
Then, multiple integrations are not loaded. Starting with pyscript, which doesn’t give another error other than a task for setting it up timed out.
Other integrations that fail to load are powercalc and Tapo camera control.
HACS is acting up too, I can’t install updates to installed integrations (namely powercalc, so myabe the update would fix the issue mentionned above but I can’t install so I can’t know)
I have another custom addon that I’m working on that is behaving weird, it seems it’s unable to access external urls, so I suspect HACS has the same kind of issues: can’t reach anything from outside the local machine.
Any leads on how to fix this trainwreck ?
