Restart HA. Try to start and stop the hive a couple of times.
There will be logs.
By the way the trace on the GitHub issue was from an automation.
I am not in customer support, so I don’t have to worry about putting your back up. If you can’t be bothered to report bugs properly, I will call you out. You are not my customer. However I hope the logging suggestions are constructive.
Like many others, I would be delighted if Microsoft Azure OpenAI were also offered as an LLM alongside OpenAI.
Do we have a chance of getting this here?
Thank you for your great work!
I have tried again on .9.3 and the issue remains. It fires the error just by using the service to turn on the water heater. I didn’t find anything in the log but I have posted the full text of the error. The two owners of the Hive integration have been silent on HA for nearly a year so I don’t think it is being maintained. I believe that how services are called has been changed in .9 so that is likely the issue. As I said - this is the perils of OSS.
Are you saying that hive doesn’t record anything at all even with logging turned right up? I find that hard to believe. What did you set your logging to? And what is the result of
It’s kind of irrelevant as someone used the method in an automation and posted the log with the same error I am seeing. So it’s not needed. The main issue is there is no reply whatsoever from the project owners of the Hive integration. There is no scheduled fix for this. the Hive integration as of 2024.9.x is dead.
Hello
I lost all my Home Assistant tabs after upgrading except the first one on left, so I restored back to last version. Do I need to do anything special after upgrading to view all my Home Assistant tabs or I just stick to the old version until remedy is found?
Hi, are you talking about the ones at the top, in the header, which are called views?
If so, I don’t think this is because of this update and I haven’t seen a report about it but maybe some one else knows more then me.
Were those just normal views?
Did you refresh the browser, tried a different one?
Don’t forget that it’s a browser app so in case of issues, it’s always a good idea to switch or clear your cache.
It’s been done - look at the initial report. Just not on this thread - it’s not really the place. The owners of the integration have done no updates for nearly a year and not acknowledged they will look at the issue. The Hive Integration isn’t maintained.
No problems with my z-wave network after update. If you want assistance, please provide more information (suggested in a new thread as the problem is most likely not related to this update) or are you just here to vent your frustration?
I’m not the only person reporting the issue and others have posted more information. Perhaps if anyone said they would be looking I’d do more - nobody is looking at it as far as I can see. Unless you are then I don’t have more to say to you about it/
Yale support should not be removed from the August integration until the new Yale integration supports US users. The US has not been moved to “Yale Home” app as we still use the “Yale Access” app. The login screen for the Yale integration just says “Wrong Username and password” with known good credentials.
