2024.9: Sections go BIG
Ok, does it mean, that after change of entity name, an integration which created it is still able to refer it by its original name? while the rest of the system (Energy dashboard) uses the new name?
Integrations don’t know entity_id’s, they create the object that HA stores in the state machine. So for all intents and purposes, nothing is changing.
If you’re asking about integrations where a user chooses a source entity, that still works because that system uses config entries first, then entity_id second. So if the entity has a config entry, you can rename things (entity_id) to your hearts content and all entities that use it as a source will be fine.
Is there any documentation on how to specify a device as the total home power consumption meter?
it’s the one(s) you specify under " Grid consumption" on the energy dashboard, no?
“Consumption” is generally not specified, it’s calculated. Energy dashboard allows you to define all the energy coming into your home (grid consumption, solar), and all the energy going out of your home (grid return).
Grid In + Solar - Grid Return = Total Home Consumption.
Or if you don’t have solar, than simply Grid In = Consumption
hey, does anybody have a clue why my tibber integration won’t work since this update? already tried reloading it, deactivated and activated it but it won’t work.
Thank you, but from the release notes I understood that if I have individual devices tracking grid consumption and in addition have a global grid consumption meter (e.g. the house meter), then the dashboard would now show how much grid consumption is not being individually monitored.
So with no solar and hence no return, all meters monitor consumption.
Or did I misunderstand the release notes?
We can’t all have energy tracking for every device, and if you have whole-home energy tracking (like a smart meter or something more DIY) the updated graph will calculate the difference and show your home’s untracked usage.
I think you are somewhat misunderstand the release notes alright…
A previous release allowed you specific individual devices that are consuming electricity…eg I use it for a Water Heater, others use for Washing Machines, Lights, Ovens, etc…and show these in a separate graph on the Energy Dasjboard
This release builds on that by showing the total consumption (already known from a properly setup Energy Dashboard) vs the individually tracked consumption (eg my Water Heater) and then displays the “difference” as untracked consumption…does that make sense now
PS - you can edit a post in these forums without having to delete and post again
I love the fact I can have my Map card the entire width of my screen and still have badges at the top. Thanks very much to all that contributed.
See my reply earlier in the thread
The total consumption cannot be known unless you have devices for all consumers. If that were the case, there would be no “difference”.
So to have a difference you need one device that actually tracks the mains. So one device like the energy meter that sees the consumption of your entire house and then compares it to the sum of all individual devices.
So that one device that sees all must somehow be identified to be that “main” device. Otherwise the dashboard would not know who is reporting the total to compare the individuals to.
It also says so in my previous quote
So, since the “whole-home tracker” tracks a consumption and all individual devices track a consumption, none of them would be registered as “return to grid”.
Essentially the new dashboard, accoding to the description, now knows who is the “whole-home tracker”. I would like to know how because I have been fake-assigning my “whole-home tracker” as return to grid so I can get a fake delta/difference.
P.S.: You can edit the response but you cannot “reply to post” after the fact and I was replying to a post (to keep the reference alive in large blog threads).
Yeah…I hear you…
AFAIK the original Energy Dashboard is based on us having a “full consumption” sensor or calc…so whether that’s direct import or solar vs battery vs export it doesn’t really matter…as long as HA can calc the house consumption it’s happy…
Think of the new feature in the Sept 24 release as a something leveraging off the already known house consumption…so you tell it what you already know is being consumed via individual sensors and it tells you the rest is unknown…it’s a “bells and whistles” type feature (nothing wrong with it but not really telling you anything you don’t know already)
PS…I see what you mean there :slight_smile:…you can tag someone in, but not reply…
So you think I need to continue to fake-return in order to see the difference between whole-house and individual devices?
(I can tag in, but I know that a lot of people, especially devs do not like to be tagged. Some consider it rude or pushy although it is not meant that way :slight_smile: )
I’m still kind of confused about what your setup is.
If you have whole house consumption sensor at your meter or electrical panel, that would go in the “Grid Consumption” section under Electricity Grid, this is your “main” sensor that you speak of.
Then you put the individual devices you monitor under individual devices.
Untracked is automatically calculated as the difference between the sum of the individual devices, and the total house consumption, which in your case is just grid consumption.
Beyond that I’m a little puzzled what you’re confused about, or why you have “fake-return”. Hope that helps?
Okay, since the addition of the Individual devices detail usage, my approach is less relevant.
I always wanted to see the individual devices and, in direct comparison, the total consumption. That way I can easily see from e.g. Energy distribution how much my total was and how much the tracked devices were.
(For that I had to set whole-home meter to grid return and individuals to grid consumption or vice versa).
With Individual devices detail usage I do not see the daily total difference but at least I see the hourly difference.
So, maybe a teeeeny tiny feature request:
In the Energy distribution’s little Grid bubble, could it read in brackets the sum of individual devices?
How do you permanently remove the untracked consumption from the individual devices graphs under Energy, I know you can temporally. disable it but it comes back on the next HA update
Loving the untracked energy feature. Took a little while to figure out which sensor I needed to use for consumption. Does a great job of highlighting how much additional monitoring I need to put in place. Thanks to the folks who worked on this, really appreciated!
You can do this kind of thing with the custom power flow card.
I can confirm the issues, my NS Panel Pro gets stuck in a loop whenever I open a dashboard that is set up as “sections”. Other dashboards seem to work normal. Maybe this was caused with release 2024.9? If I remember correctly, everything was working fine in 2024.8.
Anyone with any ideas regarding this issue?
Already reported and being fixed here
