Hi All,
Ive look around a bit and cant see much on this. Are there many/ any solutions to have a Pet water fountain in Home Assistant?
Hi All,
Tuya has one.
what model is good?
@Sir_Goodenough - which one did you try?
A friend ordered one, so don’t know.
I think they used something like Tuya Local for it.
Do you have a link?
Tuya Local is found on Github using the HACS loader.
That’s…not what I asked…
I would buy the dumbest water fountain I could find, then add a couple of things to make it smart myself.
The rest is a simple automation which only triggers when your pet is in the vicinity:
When: motion sensor state goes to detected
Then: Turn on smart plug for 5 minutes
This makes it easier to replace your fountain if it should ever fail, without having to change your automation.
Yes you asked if I had a link.
I have many links.
The one that seemed most relevant was a link to the only thing that was in the message you replied to.
Here’s another Link
Thank you for that link. It must have replied to the wrong one because I tried to reply as asking for the product.
Does it work reasonably well? I am interested in getting one for my dogs. However, it says that it is for “Ddog” not for “dog” like I have
It’s backwards compatible, meaning it will work for both the updated Ddog and the regular dog version like you have.
That is fantastic to hear that my Dogs aren’t obsolete yet!
