I cannot give an answer in which I have no solid answer for. That will set expectations that are already varied - I do not want to (nor will I) say something that may end up biting us in the ass.
I acknowledged this wouldn’t be enough for some but I’d rather give something than radio silence - and I will absolutely come back around to share what we have been working on. Sorry that isn’t gonna come faster for y’all - all I can ask is that you continue being patient with us while we finalize things.
Thank you again for taking the time to respond. I do appreciate that you’re in the uncomfortable position as the spokesperson who can’t say anything. You said the concerns here have been heard, and I believe you. I only reply in the hope that they’re not being misinterpreted. Without feedback, it’s hard to know.
I also got the message loud and clear that either these decisions haven’t been made yet, or maybe they have been made but the decision on how to break the bad news to the community hasn’t been made yet. I think you can understand how this can be unsettling.
I’ll try to be patient. We need to put this behind us.
1 & 2. Backups functionality was removed, the backup on update option was removed. So now by default the system doesn’t backup, previously I got a backup each update, which lets face it is by far the most critical time, especially if recent releases are anything to go by.
So I now have to go create my own strategy.
I cannot use the built-in backup feature for most of the 1000 reasons above state.
E.g. it’s encrypted, I can’t restore what I want from it.
My backups are too big for nabu casa etc etc
The whole ethos of home assistant for the last few years has been to move away from the scripting and move to the UI.
Now we are being told to move back to scripting because we don’t comply with a narrow set of rules which someone has naively thought up, e.g. a backup will never be more than 5gb, no one will want to extract just a yaml file.
That’s a far more accurate, and true, statement than what you claimed originally:
You removed their backups and have left users at risk
You can make unencrypted full or partial backups using hassio.backup_full and hassio.backup_partial, respectively. Those actions can be used directly in Developer Tools → Actions or in a script (that you must create).
For my convenience, I made an application that lets me select an Add-on by its name from a dropdown list, then click a button to make a backup of it. I shared it with everyone in the link found in nickrout’s post (see post above). It can be used prior to upgrading an Add-on.
I will say this much: I would not have posted if I had no confidence we were working on good solutions here. I very much believe we have proposed solutions that will be agreeable; I’m eager to share which is why I posted knowing it wasn’t a great follow up but wanted to make sure there was signal from our side that we continue to actively work on addressing y’all’s concerns.
It remains to be seen how the next version will address the issue (of allowing for a convenient partial backup before upgrading an Add-on).
Currently, the availability of that partial backup makes it easy and convenient to rollback from a buggy Add-on upgrade. Maybe they’ll invent a way to rollback an Add-on that doesn’t even need a backup (pure speculation; I don’t know their plans).
Of course change the entity_id to the update. entity of that specific add-on.
It will make the old partial back-up of the add-on that was present before they removed the button. And directly afterwards updates the add-on. I’m guessing this is the service call that was handling the feature for backup on update.
There are no options to give for the backup: true, and it is unencrypted by default.
The target for storage will be the default set inside the Backup settings. If you have no SMB/NFS share it will default to /backup , or whatever you have set there.
One of the reasons I’ve read that this type of backup is no longer offered in the interface is that this feature doesn’t actually make a full back-up of the add-on and it’s data. It is just the Add-on itself without the mapped folders.
And if you do a partial restore of just the add-on from last nights Full backup, nothing is actually lost, as that data is not stored in the Add-on itself. This might be different per type of add-on.
BTW, I seem to recall the information contained within a partial backup of an Add-on contains the Add-on’s version. When restoring, it pulls the Add-on container matching the version.
Or at least that’s how it appeared to have behaved when I rolled back the Tailscale Add-on. Its partial backup didn’t contain anything more than two configuration files. Maybe I need to do an experiment …
Yeah, which is what I found out when I was inspecting what was actually in all those backups I had before with the OneDrive Backup Add-on. All those add-on backups were really small, which should tell you something haha.
So partial restoring the add-on from any Full back-up in the past days will restore the exact same part. Which seems fine now that I think of it.
Only outlier for my Add-ons is PLEX which stores the whole database and metadata inside the Add-on backup it seems. But if I lose a days worth of metadata, that doesn’t really matter as it will be generated automatically again.
The partial back-up is mainly important for update.home_assistant_core_update as that has saved me quite some times when an integration was broken with an update and I could fix it within 5mins of booting the broken version.
I don’t see a way to restore just HA Core itself, without touching any of the history so to not lose any data. I don’t want to lose a whole day of data if I need to restore to a backup from last night.
[edit]
Only way I can find is through CLI:
ha core update –version HA_VERSION_YOU_WISH.
