Link still aimed at the rc.hom… site, doesn’t this happen every week release?
Woo, SmartThings is back! Awesome work @Joostlek!
Another great thing is the fix of stack cards, that bug bothered me for months
Do you mean the integration that starts the readme with this:
IMPORTANT NOTE!!
It is recommended you switch to the core version of this integration. Due to the time that the maintainers have, most time goes into supporting the core version of this integration as there are approximately 5 times as many users using that integration. There are multiple known issues with the custom component version of Roborock that are not planned to be fixed. If a user is so inclined - they can look at the fixes on the core component and carry them over here and we will approve PR. But otherwise, expect updates and fixes to this repository to be very limited at least for the time being.
Non interactive icons of tiles are still shown on a circle in Dark Mode
What was fixed?
inline option in tile cards was long time awaited ![]()
I only wish we could allocate more space for brightness bar, like 3/4 of the tile card size ![]()
__
Also
for small new animations
The change to automation/script variable scopes is so welcome! I can’t tell you how many helpers I’ve had to create to store values for the old, weird scoping behavior!
Keep up the great work!
How to disable clustering in maps by default? I can click on the icon, but I would like to unset this option in a map card without requiring that click.
You can’t right now, though maybe it makes sense to add that as a yaml option.
SmartThings?! That’s literally what drove me to Home Assistant. OMG was that a dark period of home automation in my life. I wrote a full Vantage lighting controller integration using their “Groovy” based API. Then began the constant stream of breaking changes and cloud outages. Local only!
Just updated, cant edit dashboard without browser crashing.
Both Mushroom Dash and Bubble card. Most are inside vertical stack cards.
Both Chrome and Firefox.
Huh, they changed that? It’s past bedtime here, but I went back over the notes and did not see it second time either. That’s great news!
Disappointed that the PI-Hole update did not make it in this update.
How to enable the streaming answer?
I use ollama on a 3090
Yeah, it was mentioned in Backwards Incompatible changes. Still the middle of the work day here so I haven’t had a chance to play with it, so I don’t know if there are exceptions/limitations, but it sounds very promising.
