Seriously, is this April Fool's Day? How can you say, "The nice thing is, nothing breaks. All your existing automations keep working, worry-free," while also saying my automations will definitely break?
Purpose-specific triggers and conditions
Several entity triggers and conditions, part of the new purpose-specific triggers and conditions, have been renamed so their keys are consistent across all domains. The old keys no longer work.
The following triggers changed:
battery.low is now battery.became_low
battery.not_low is now battery.no_longer_low
lawn_mower.docked is now lawn_mower.returned_to_dock
schedule.turned_off is now schedule.block_ended
schedule.turned_on is now schedule.block_started
timer.time_remaining is now timer.remaining_time_reached
update.update_became_available is now update.became_available
vacuum.docked is now vacuum.returned_to_dock
The following conditions changed:
climate.target_humidity is now climate.is_target_humidity
climate.target_temperature is now climate.is_target_temperature
If an automation or script uses one of these, it will stop working until updated. To fix it, open the affected automation or script, re-select the trigger or condition (it now appears under its new name), and save. If you edit in YAML, replace the old key with the new one from the list above.
The purpose specific triggers were experimental up to this release. Those have the explicit mention that when you enable them, you need to take into account the fact that experimental features may still change.
So taking into account the things you mentioned were hidden by default and not finalized, this was a risk you chose to accept by enabling the feature.
Nothing official was broken, what was unofficial and broken they warned for in advance and again in the release notes. That is high enough a standard for me.
Indeed, that’s the right approach. As long as something is preview, make sure you understand things can break or not use it at all until it gets released.
I think y'all are missing the point. The point is not that experimental things were broken, it's that they literally said "nothing breaks." They just need to be transparent and say that some things break. E.g. Instead of saying, "The nice thing is, nothing breaks." They could've said something like, "The nice thing is, no stable features break."
I won’t speak for OP on this part, but I personally am not stressed about the fact that they break things all the time. It’s annoying to always have to deal with breaking changes, but that’s the way this software is developed, and it’s not the first software I’ve used like this. But that is not the point of this thread. It’s not a thread about, “How to cope with inaccurate blog posts.” You’re trying to answer a question nobody asked.
It’s okay for someone to say, “Hey, this thing that they said isn’t true.” Without other folks needing to berate them for believing what was said.
I think y’all think that OP is mad that they broke something. But that’s not the message in the OP.
