Maybe try to use a different sdcard
8 month, 10 systems (2 of them with this HA, 4 in Linux, 4 with default Android OS), no instability. For me this is a big yes for this price.
I hate the support policies for supervised, but donât be surprised if you donât get any support.
Well done though, I like it.
in fact this doesnât really need support. HA integration on officialy supported board have been made with nearly same scripts.
Up to you, just pointing out the support policies for supervised.
I built the image according to the instructions and everything worked, thanks ![]()
Hi Fensoft,
Thanks for publishing and supporting this threadâŚ
I see the DQ08 with DDR3 4GB, but eMMC options 16/32/64GB;
What is the eMMC requirement for HA to run comfortably or does it matter ?
Thanks, Don
hi, internal emmc is not used at the moment
iâve made a better version here using emmc
Hi, whatâs the alternative for supervised now itâs no longer supported?
Docker container !
itâs still supported by armbian.
and, no, docker is not an alternative when you want a fully managed HA with addons and backups
I've created here a guide on how to run modern version of the HAOS, suprisingly it run mostly natively:
