I see…
220 v (or 220-240 v) is rare LED strips.
I suppose all you “need” is a controller that is compatible.
Since the mains supplied LED strips are so rare the community has not used them as much.
In theory… If you find a wifi based controller and you ask the manufacturer if it’s ESP based chip in it then you might be able to flash it and use it in ESPHome.
But off the shelf is not something I have seen.
