I have been trying to change the date/time to AM/PM format, but it doesn’t seem to work. I still get 24 hr format, The profile language and time is correct. Do I need to reset everything and start over since I am just beginning to get things set up? or isd there a quick fix?
So you have set this to 12hr?
Where particularly? Post a screenshot.
I still get this:
What is that?
A sensor?
Which integration?
Which card are you using to display it?
yes. time_date senor. The integration is the Time & Date intergration that asks which to choose
Time
Date
Time & Date
Time & Date (UTC)
Also, no card yet since the time and date it shows on the setting is the information that shows on a card. As mentioned, I’m just starting so resetting the server and starting over is an option and making sure the information is correction on initial setup.But if there is a Yaml code to fix this, I’ll try that first.
