Can someone give me their views on my situation. Additionally, I have posted my code at the bottom of this post (I don’t fully understand it all as it was a gift from a reddit post and does seem to be solid)-- but I do have a question about it and how stepper motors etc. work using esphome in general.
My question is: Is there anything in this code that I could change to get it (the blinds) to go further in the down direction. So what is going on is that when I click open (If we call 50% in the middle and fully open in terms of letting light into the house), the blinds are going to around 65%. And then when I click close, they are going to around 15% rather than fully closed.
Do you all see anything is this code that I can change to shift that whole range down that 15%? Am I thinking about this whole thing completely wrong? Is this showing that my stepper motor is not strong enough? Can I manually (with my hands physically) shove the blinds down to fully close from the 15% and then it will go from 0 to 50?
Sorry for all the questions, I’m just not fully following if I can fix this in the code below or if this is a physical hardware issue.
esphome:
platform: ESP32
board: nodemcu-32s
on_boot:
- priority: -200.0
then:
- stepper.report_position: # Set stepper to global variable
position: !lambda return id(stepper_motor_global);
- stepper.set_target: # Set stepper to global variable
target: !lambda return id(stepper_motor_global);
- if: # If blind is Closed
condition:
- lambda: 'return id(stepper_motor_global) == 0;'
then: # Publish state etc.
- cover.template.publish:
state: CLOSED
current_operation: IDLE
- if: # If blind is Open
condition:
- lambda: 'return id(stepper_motor_global) == id(endstop);'
state: OPEN
- if: # If blind is Neither
condition:
- lambda: 'return (id(stepper_motor_global) != 0) && (id(stepper_motor_global) != id(endstop));'
then: # # Publish state etc.
position: !lambda 'return (float(float(id(stepper_motor).current_position) / float(id(endstop))));'
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "NkblotNz0QL9TwPbE1tGMAcayC41bZqSRavwCtduSP4="
services:
- service: control_stepper
variables:
target: int
then:
target: !lambda 'return target;'
ota:
password: "1c32e35ea8e90d369b8feb7f8b204aef"
wifi:
ssid: !secret wifi_ssid
fast_connect: true
ap:
ssid: "DR-Blinds Fallback Hotspot"
password: "Fhm0gqd5qfc3"
captive_portal:
web_server:
port: 80
################################################################### STEPPER CHANGE (ENDSTOP)
globals:
- id: stepper_motor_global # Integer for storing the stepper position in case of reboot
type: int
restore_value: True
initial_value: '0'
- id: openclosed # Boolean to store OPEN/CLOSED state
type: bool
restore_value: True
initial_value: '0'
- id: endstop # Variable for storing ENDSTOP (how far to move stepper)
type: int
restore_value: True
initial_value: '750' # this is the max value # this is the max value
stepper:
- platform: a4988
step_pin: GPIO2
dir_pin:
number: GPIO4
inverted: true
sleep_pin:
number: GPIO5
inverted: true # inverted since using enable pin
max_speed: 250
################################################################### STEPPER CHANGE (TARGET)
cover:
name: Dining Room Blinds
open_action:
then:
- logger.log: "Opening"
target: 750
- while:
condition:
lambda: 'return id(stepper_motor).current_position < id(endstop);'
then:
current_operation: OPENING
- delay: 1000 ms
- globals.set: # Set global to current position
value: !lambda return id(stepper_motor).current_position;
- globals.set: # Set toggle to OPEN (No need for 'optimistic mode')
value: '1'
state: OPEN
close_action:
then:
- logger.log: "Closing"
- stepper.set_target: # Send stepper to 0
target: '0'
- while:
condition:
lambda: 'return id(stepper_motor).current_position > 0;'
then:
current_operation: CLOSING
- delay: 1000 ms
- globals.set: # Set toggle to CLOSED (No need for 'optimistic mode')
value: '0'
state: CLOSED
position_action:
then:
target: !lambda return int(id(endstop) * pos);
- while:
condition:
lambda: 'return id(stepper_motor).current_position != int(id(endstop) * pos);'
then:
- delay: 1000 ms
stop_action:
then:
target: !lambda return id(stepper_motor).current_position;
has_position: true
device_class: blind
switch:
name: Reset Dining Room Blinds
turn_on_action:
target: '1500'
- wait_until:
lambda: 'return id(stepper_motor).current_position == 1500;'
- delay: 1s
target: '0'
value: '0'
state: CLOSED
- switch.turn_off: reset
- platform: restart
name: "Dining Room Blinds Reboot"
# Text sensors with general information.
text_sensor:
# Expose WiFi information as sensors.
- platform: wifi_info
ip_address:
name: Dining Room Blinds IP
ssid:
name: Dining Room Blinds SSID
# Sensors with general information.
# WiFi Signal sensor.
- platform: wifi_signal
name: Dining Room Blinds WiFi Signal
update_interval: 60s
