I’m using ESPHome with a 28BYJ-47/ULN2003 for some motorized blinds. Two out of the six blinds I have installed are rotating the opposite direction. How do I fix this?
If the stepper is driving in the wrong direction, you can invert the dir_pin:
dir_pin:
number: D1
inverted: true
Isn’t that only for the a4988
driver?
reverse the order of the connections from the ESP to the ULN2003.
Or reverse the pin definitions in the ESPHome code.
As far as I can tell, both motors are wired the same. Though they turn in different directions. I’ve heard of certain components reversing polarity, and instead decided to create two different configurations.
blinds.yaml, and blinds_reversed.yaml depending on which way the motor was turning.
blinds.yaml
cover:
device_class: blind
# lambda: |-
# if (((id($stepper_id).current_position * id($stepper_id).current_position) / id($stepper_id).current_position) == id(open_position)) {
# return COVER_OPEN;
# } else {
# return COVER_CLOSED;
open_action:
- stepper.set_target:
target: "0"
- cover.template.publish:
position: "1"
- globals.set:
value: "0"
close_action:
target: !lambda "return -( $step_total / 2 );"
position: "0"
- globals.set:
value: !lambda "return -($step_total / 2);"
position_action:
then:
- logger.log:
format: "Current: %d | Target: %.2f | Steps: %d"
args: ["id($stepper_id).current_position", "pos", "( $step_total * pos ) - ( $step_total / 2 )"]
target: !lambda |-
return ( $step_total * pos ) - ( $step_total / 2 );
position: !lambda "return pos;"
- globals.set:
value: !lambda |-
stop_action:
target: !lambda return id($stepper_id).current_position;
- globals.set:
value: !lambda "return id($stepper_id).current_position;"
has_position: true
esphome:
on_boot:
priority: -200
then:
- stepper.report_position:
position: !lambda "return id(current_position);"
target: !lambda "return id(current_position);"
current_operation: IDLE
position: !lambda "return (id($stepper_id).current_position + ( $step_total / 2 )) / $step_total;"
esp8266:
board: nodemcuv2
globals:
- id: close_position
type: int
initial_value: "9250"
- id: open_position
type: int
initial_value: "0"
- id: current_position
type: int
initial_value: "0"
restore_value: true
# Enable logging
logger:
level: DEBUG
# Enable Home Assistant API
api:
services:
- service: set_target
variables:
target: int
then:
target: !lambda "return target;"
- service: report_position
variables:
position: int
then:
- logger.log:
format: "Reporting position to %d"
args: ["position"]
position: !lambda "return position;"
target: !lambda "return position;"
- globals.set:
value: !lambda "return position;"
ota:
password: "2515291ea63617d85b4bee51325fcd12"
wifi:
fast_connect: true
power_save_mode: none
ssid: !secret wifi_ssid
ap:
ssid: "Fallback Hotspot"
password: "X87rZCD9TMHF"
captive_portal:
# @todo: make pin assignment sequential
stepper:
- platform: uln2003
pin_a: D1
pin_b: D2
pin_c: D3
pin_d: D5
max_speed: 250 steps/s
sleep_when_done: true
# Optional:
acceleration: inf
deceleration: inf
substitutions:
cover_name: ""
device_id: ""
esphome_name: ""
step_total: "18500"
stepper_id: "my_stepper"
cover:
device_class: blind
# lambda: |-
# } else {
open_action:
target: "0"
position: "1"
- globals.set:
value: "0"
close_action:
target: !lambda "return $step_total / 2;"
position: "0"
- globals.set:
value: !lambda "return $step_total / 2;"
position_action:
then:
- logger.log:
target: !lambda |-
return -(( $step_total * pos ) - ( $step_total / 2 ));
- globals.set:
value: !lambda |-
stop_action:
- globals.set:
has_position: true
esphome:
on_boot:
priority: -200
then:
esp8266:
board: nodemcuv2
globals:
type: int
- id: open_position
type: int
initial_value: "0"
type: int
initial_value: "0"
restore_value: true
# Enable logging
logger:
level: DEBUG
api:
services:
variables:
target: int
then:
target: !lambda "return -(target);"
variables:
position: int
then:
- logger.log:
args: ["position"]
position: !lambda "return -(position);"
target: !lambda "return -(position);"
- globals.set:
value: !lambda "return -(position);"
ota:
wifi:
fast_connect: true
ap:
captive_portal:
stepper:
- platform: uln2003
pin_a: D1
pin_b: D2
pin_c: D3
pin_d: D5
# Optional:
acceleration: inf
deceleration: inf
substitutions:
cover_name: ""
device_id: ""
esphome_name: ""
step_total: "18500"
hanks for sharing the yaml. I was able to create with the same model of motor and driver using this.:
