Hello everyone,
so I have an issues with my winch garage door controller. The original winch controller has up/down push button and a capacitor in the remote for changing the direction of the motor. That is why there are 6 wires.
I have ESP8266 and 2 2channel relays.
I use 2 channel relay for opening, and 2 channel relay for closing garage doors, the issues is that sometimes relay starts letting current and randomly starts to open or close my garage doors. I have somewhat temporary fixed the issues by installing a smart plug with which the winch is powered. The winch only gets power when I press up or down button and turns off after the closing/opening is done.
Can someone give me some pointers for my code if I am doing something wrong or something? Because when the relay start letting current on by itself, it does not burn, after few hours of not having power it starts to work normally again.
I have included a picture and code I currently use.
The is
esphome:
friendly_name: garaza_mercedes
platform: ESP8266
board: nodemcu
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxx"
ota:
password: "xxx"
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.20.15
gateway: 192.168.20.1
subnet: 255.255.255.0
dns1: 1.1.1.1
dns2: 8.8.8.8
ap:
ssid: "Garaza Fallback Hotspot"
password: "01zaWI0BOiNF"
captive_portal:
- platform: ultrasonic
trigger_pin: D5
echo_pin: D6
update_interval: '0.1s'
on_value_range:
- above: 4
then:
- below: 0.22
then:
- switch.turn_on: open_switch
trigger_pin: D7
echo_pin: D8
timeout: 10m
on_value_range:
- above: 4 # You must have a below and an above part.
then:
- below: 0.22 # You must have a below and an above part.
then:
- switch.turn_on: close_switch
switch:
- platform: gpio
pin: D2
name: "Garage Door Open Switch"
restore_mode: ALWAYS_ON
- platform: gpio
pin: D1
name: "Garage Door Close Switch"
cover:
device_class: garage
has_position: true
lambda: |-
if(id(bottomSensor).state = 'unknown' ) {
return 0.5;
else if(id(bottomSensor).state < 0.25) {
return 0.0; //return COVER_CLOSED;
else if(id(topSensor).state < 0.25) {
return 1.0; //return COVER_OPEN;
else {
return 0.5;
open_action:
- homeassistant.service:
service: switch.turn_on
data: {entity_id: switch.chuangmi_hmi206_3708_switch}
- delay: 0.2s
- switch.turn_off: open_switch
- delay: 25s
service: switch.turn_off
close_action:
- delay: 0.2s
- switch.turn_off: close_switch
- delay: 25s
stop_action:
