2GIG Alarm Panel Integration?
Shot in the dark here, I’ve seen several posts in the past that saying you can’t communicate directly to a 2GIG alarm panel and instead have to use an online service (alarm.com) with a monthly subscription and I wanted to check and make sure no one has found the silver bullet that lets you directly communicate to these panels.
So far, from what I can see, nothing on the security panel is actually exposed to zwave and in fact it’s configured with no security on the zwave side of things anyways.
I have several devices connected to this panel that communicate on the RF 345 band that would be a pain to replace. Does anyone know of a drop in replacement that I could put in place of the 2GIG panel that does directly integrate with HA if no one has ever figured out how to get communication setup with the panel?
A Resideo panel may work. It’s a very similar panel to the 2 gig, they just have connectivity to home assistant through their app Total Connect. I work for a low voltage co, and it appears most panels take a lot of work, if even working at all.
The other route would be an SDR Radio to sniff out the sensors, which I went down a rabbit hole on, and gave up.
I have looked at converting my system to use Konnected Alarm panel that’s based on ESP32 & ESP8266 and ESPHome firmware.
I just completely rebuilt my HA and once I get my basics restored I think that will be one of the next things I pull the trigger on.
Hope this helps; let me know if you beat me to it and how it goes.
Darc
MY OWN UPDATE / REPLY:
I just poked a little further down the rabbit trail and found that Konnected has a HA integration:
