Hello collective brains,
I have been trying to add a VLAN solely for my alarm.
I am running HA in Proxmox on a Dell I5 laptop. I have a Ubiquiti USG with the HA integration for the controller.
So far I have (Hopefully correctly)
Added a new NIC to my Proxmox hassos VM.
Added a new VLAN (192.168.2.1-254)in my Ubiquiti controller.
Checked in NMCLI that the second connection is connected, it was
In HA, went to system and IP address. Set a static IP in the second connection.
Went to my alarm integration and set the new IP, also set in alarm GUI as well.
Used IP scanner to scan 192.168.2.1-254 and I can see all IP’s
Now the issue I have is I cant figure out if HA can actually see my alarm, I have tried to ping from the terminal in HA but it just seems to lock up and I have to restart the terminal integration.
In my logs it shows that HA can not see my alarm.
I have a feeling that its something to do with the connection between networks in proxmox but I am no network or code expert and rapidly getting out of my depth.
Hi, Thanks for your input.
I was wondering about a rule in the controller but I read and heard (on TheHookup) that you didnt have to link lans in Ubiquiti, they were by default and if you wanted them blocked then you add a rule.
But anyway I will give it a go, as I am no expert.
What part of the firewall rules did you enter the last part? Lan Local?
I am no expert. 2 just wing and do a restore if i f it up.
mine in the LAN IN bit
yes the Hookup is right BUT only if you copy use the exact same setup
and that with all those type of videos
I watch his and also watch a number of others
this guys one had nice step to watch and do
and this one
next bit is getting runing on HA tryed about 6 months ago and the HA version would adopt the bloody thing
BUT i see the HA is running the Latest version now so once we out of lockdown (wife not working form home i be JUMPING in with all feet
