2nd Xiaomi Gateway Strange Problems
Hi, I have added another Gateway to my setup, due the increased number of sensors, I have added the gateway and the sensors running from the gateway have been found and seem to be working, however i have noticed the following strange behavior
  1. ) The light doesnt work when turned on and off, however If i do it from the Xiaomi App you can see it turn on, and I can see the colors change within HASS from the Xiaomi app, but no control within HASS.
  2. )I have notices the WiFi switches work but do not update in HASS, but will turn lights off and On.
I get the following Error
2017-11-10 18:51:13 ERROR (Thread-3) [PyXiaomiGateway] Got error element in data {“error”:“Invalid key”}
2017-11-10 18:51:21 ERROR (Thread-6) [homeassistant.components.light.xiaomi_aqara] Light RGB data error. Must be 8 characters. Received: ff9e
Any ideas ?
definitely a key problem. is it possible that you mixed the keys and the respective IP addresses?
Thanks please excuse my idiot status… right now, I checked it and still managed to not see the error when I typed the key.
Thanks alot
All good! Can you please mark the topic as solved?
