I’m looking for a relay that has 2x 230v input to switch 2 dry contact (NO).
For some reason the cables running to the curtains are 5x1 and 2 of those wires carry 230V for the Forest Curtain motor. The problem is that while powered the interference that gets picked up (floating volatge) is enough for the input contact to see a connection (They require dry contacts which are in the power cabinet). So they are moving on their own whenever i plug the RJ45 in which is connected to the 3 other wires in the same cable.
Since the cable is already carrying 230v i thought that using 2 tiny 230v relays or a module that has 2 inbuilt should work better, tested it with DIN relays and that works like a charm.
Been looking but cannot seem to find what i want in the forest of relays on google.
Anyone else has experience with this? And yes, next time seperate cables for power and control
