2x TuYa TS0001_switch_module and 1x TS0002_switch_module switching as group?
this is my first step deeper into HA. Up to now I have only sensors and TRVs, without any automations. Bear with me. :slight_smile:
I have 3 independent lights with their switches in my hallway. I want all of the lights to be switched with all available switches. To solve this, I have mounted two TuYa TS0001_switch_module and one TuYa TS0002_switch_module, where the l1 endpoint is used for one light. All of them are set to toggle mode.
I now can switch all the lights independed as before, and have the possibility to switch them over zigbee2mqtt exposed state.
Now I tried to create a zigbee group and add the swich modules (and the endpoint l1).
devices.yaml:
'0xa4c138b5d21d492d':
  friendly_name: switch_module.uf_hallway_light
'0xa4c13857541e99e6':
  friendly_name: switch_module.gf_hallway_light_kitchen-door
'0xa4c13852c4de7fca':
  friendly_name: switch_module.gf_kitchen_light
groups.yaml:
'11':
  friendly_name: switch_module_group_hallway
  devices:
    - 'switch_module.uf_hallway_light'
    - 'switch_module.gf_hallway_light_balcony-door'
    - 'switch_module.gf_hallway_light_kitchen-door/l1'
I restarted Z2M, but this didn’t change anything. At least I didn’t observe any change.
Did I misunderstand ZigBee groups?
What I did, but didn’t bring my to a working solutions had been to convert the switches to lights and group them. Now I can switch them in Lovelace, but when I use the hardware light switches it also only switches the connected light. Which is expected I guess…
I also read something about ZigBee binding. Is this what I need?
Or do I need to set up automations for every switch to switch the other two?
Thanks for your help!
Edit: The finally workin solution.
I can’t remember what my first approach had been, but I successfully built a strobe light effect! :smiley:
The solution below now works since weeks without any issues.
Next steps for the light will be some motion sensors with time conditions or maybe presence detection in the bed, as we sleep with open bedroom door…
groups.yaml
'1':
  friendly_name: switch_module_hallway_goup
  devices:
    - 0xa4c138537ef57481/1
    - 0xa4c13857541e99e6/1
    - 0xa4c138b5d21d492d/1
automations.yaml:
# tell the other two switch_modules to toggle as well
- id: "1646665464616"
  alias: Hallway Lights - GF Balcony switch on
  description: Switch on the other two switch_modules
    - platform: device
      type: turned_on
      device_id: eb285a117aee84f4ce78b682b1ea50a2
      entity_id: switch.switch_module_gf_hallway_light_balcony_door
      domain: switch
  condition: []
    - type: turn_on
      device_id: 63baf1b9ed1cfa33183de48b5bb61958
      entity_id: switch.switch_module_hallway_goup
      domain: switch
  mode: single
- id: "1646666015962"
  alias: Hallway Lights - GF Balcony switch off
  description: Switch off the other two switch_modules
    - platform: device
      type: turned_off
      domain: switch
  condition: []
    - type: turn_off
      domain: switch
  mode: single
- id: "1646666197508"
  alias: Hallway Lights - GF Kitchen switch on
    - platform: device
      type: turned_on
      device_id: 364a825756c954a0eeb71c9ff032da45
      entity_id: switch.switch_module_gf_hallway_light_kitchen_door_l1
      domain: switch
  condition: []
    - type: turn_on
      domain: switch
  mode: single
- id: "1646666197509"
  alias: Hallway Lights - GF Kitchen switch off
    - platform: device
      type: turned_off
      domain: switch
  condition: []
    - type: turn_off
      domain: switch
  mode: single
- id: "1646666197510"
  alias: Hallway Lights - UF Office switch on
    - platform: device
      type: turned_on
      device_id: ed0b587cdb3a6d13100a730fc5bfd9d0
      entity_id: switch.switch_module_uf_hallway_light
      domain: switch
  condition: []
    - type: turn_on
      domain: switch
  mode: single
- id: "164666619711"
  alias: Hallway Lights - UF Office switch off
    - platform: device
      type: turned_off
      domain: switch
  condition: []
    - type: turn_off
      domain: switch
  mode: single
# now integrate the four zigbee switches
- id: "1647513866787"
  alias: Hallway Lights - UF Living Room Button Turn On
  description: ""
    - platform: mqtt
      topic: zigbee2mqtt/push_button.uf_hw_living-room/action
    - platform: mqtt
      topic: zigbee2mqtt/push_button.uf_hw_bedroom/action
    - platform: mqtt
      topic: zigbee2mqtt/push_button.gf_hw_bath/action
    - platform: mqtt
      topic: zigbee2mqtt/push_button.gf_hw_guest-room/action
  condition:
    - condition: device
      type: is_off
      domain: switch
    - type: turn_on
      domain: switch
  mode: single
- id: "1647513866788"
  alias: Hallway Lights - UF Living Room Button Turn Off
  description: ""
    - platform: mqtt
    - platform: mqtt
    - platform: mqtt
    - platform: mqtt
  condition:
    - condition: device
      type: is_on
      domain: switch
    - type: turn_off
      domain: switch
  mode: single
I made my groups via the frontend and it doesn’t use the friendly name for the devices but the address and endpoint as per below.
'3':
  friendly_name: Kitchen Lights
  devices:
    - 0x00124b00106de757/1
    - 0x00124b00320ded03/1
Both is legit. I also deleted it again and created again via the frontend. It’s the same.
In meantime I figured out, I misunderstood the purpose of ZigBee groups. It’s not possible to have all the other devices to do the same thing as the one getting a command, as I expected. It’s the group I have the command to be sent.
When I changed my automations to set the state at the group, everything worked fine.
Regarding ZigBee binding: I sadly figured out it’s just not supported by the devices I use. I updated it int the device description documentation.
How did you configure the switch to toggle mode? Mine work as toggle mode by default but I can’t find any option to change this behavior.
Every time I physical toggle the switch the light toggle.
Edit: Forget everything written before, in case you had been fast enough to see it.
Obviously the switch doesn’t have the toggle option. I guess I mixed that up with the Tuya switch_modules I also have…
