does anyone have this option installed? are you using two uart ld2410 sensors on one esp32?
can you please show your yaml?
I need to know exactly how to make it work. Ideally with the possibility to edit the parameters of both ld2410.
Thank you very much
Use different pins.
And remember that ESP32- S3 might only have 2 hardware UARTs, where ESP32-S2 have 3.
One is used for the logger, so if you do not disable the logger, then one of your extra UARTs might be a software one, which is prone to data loss at high speed connections.
But I need to see the yaml. that I have to use other pins is perhaps clear
Post your YAML of your first UART setup.
esphome:
friendly_name: esp32 senzore kupelna
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
level: DEBUG
# Enable Home Assistant API
api:
encryption:
key: "xfL2UtWhRsGnXDLLRuNDLsoMjXfidy8j6zpDcvKmiHY="
ota:
password: "c8f85f0ab8019c82b31cc00efe2e2a29"
wifi:
ssid: !secret wifi_ssid
captive_portal:
i2c:
sda: GPIO22
scl: GPIO21
scan: true
- platform: bme280_i2c
temperature:
oversampling: 1x
pressure:
filters:
- calibrate_linear:
# Map 0.0 (from sensor) to 0.0 (true value)
- 0.0 -> 0.0
- 972.4 -> 1017.4
humidity:
address: 0x76
update_interval: 1s
- platform: ld2410
still_distance:
name: "Still Distance (cm)"
still_energy:
name: "Still Energy (%)"
uart:
tx_pin: GPIO16
rx_pin: GPIO17
baud_rate: 256000
parity: NONE
stop_bits: 1
ld2410:
uart_id: ld2410_uart
throttle: 1500ms
select:
- platform: ld2410
distance_resolution:
name: distance resolution
baud_rate:
light_function:
button:
- platform: ld2410
factory_reset:
- platform: restart
number:
- platform: ld2410
timeout:
max_move_distance_gate:
name: max move distance gate
max_still_distance_gate:
name: max still distance gate
g0:
move_threshold:
name: g0 move threshold
still_threshold:
name: g0 still threshold
g1:
move_threshold:
name: g1 move threshold
still_threshold:
name: g1 still threshold
g2:
move_threshold:
name: g2 move threshold
still_threshold:
name: g2 still threshold
g3:
move_threshold:
name: g3 move threshold
still_threshold:
name: g3 still threshold
g4:
move_threshold:
name: g4 move threshold
still_threshold:
name: g4 still threshold
g5:
move_threshold:
name: g5 move threshold
still_threshold:
name: g5 still threshold
g6:
move_threshold:
name: g6 move threshold
still_threshold:
name: g6 still threshold
g7:
move_threshold:
name: g7 move threshold
still_threshold:
name: g7 still threshold
g8:
move_threshold:
name: g8 move threshold
still_threshold:
name: g8 still threshold
light_threshold:
name: light threshold
switch:
- platform: ld2410
engineering_mode:
bluetooth:
name: control Bluetooth
binary_sensor:
- platform: ld2410
has_target:
has_still_target:
First you need to research your board a bit.
A pinout description and picture is a good thing, because that will tell you what pins are available to use.
If you can find a description with what pins are floating or have weird behavior at boot, then it would be great too, like this one: ESP32 Pinout Reference: Which GPIO pins should you use? | Random Nerd Tutorials
Once you have that, then you need to select RX and TX pins for the extra LD2410.
When those are selected then you need to state ids in the different sections, so ESPHome knows which one to use.
uart:
- id: ld2410_uart
tx_pin: GPIO16
rx_pin: GPIO17
baud_rate: 256000
parity: NONE
stop_bits: 1
- id: ld2410_uart_2
tx_pin: GPIO14
rx_pin: GPIO15
baud_rate: 256000
parity: NONE
stop_bits: 1
ld2410:
- id: ld2410_comp
throttle: 1500ms
- id: ld2410_comp_2
uart_id: ld2410_uart_2
throttle: 1500ms
select:
- platform: ld2410
ld2410_id: ld2410_comp
baud_rate:
light_function:
- platform: ld2410
ld2410_id: ld2410_comp_2
baud_rate:
light_function:
Here the uart, ld2410 and a select section have been set up. You need to add the ld2410_id entry to all your other references to the ld2410 and then doublicate it and rename that ld2410_id entry for one of them to get your double.
BEWARE! The pins I set for uart_2 is just some random ones. I do not know if they work, so do the search on the net for your board.
this is exactly what I needed to know. Thank you for your help. I’ll try it and see if it works
