CheRowley
(Che rowley)
1
Hi!
Can anyone recommend some 3 gang 2 way switch modules to sit behind standard uk light switches please?
I have neutral in the boxes, boxes are max 35mm depth though and all solid walls!
Moes do 3/4 gany 2 way but use that tuya stuff, looking for easy HA integrationā¦(had no joy getting an account setup on tuya dev web sute
Thanks!
CheRowley
(Che rowley)
2
No one have any suggestions?
if youāre fine with adding spacer, those relay module could still fit behind the switch
as for the moes, you can replace the firmware with openbeken/esphome so you donāt have to deal with tuya dev.
CheRowley
(Che rowley)
4
Ah thanks Shaq, thought the moes needed a smt chip swapping to an esp - way beyond my soldering skills lol
yeah, those are gonna be hard to do unless itās a separate chip on the pcb.
