3 hangs in past week - not sure how to figure out what is wrong (HA OS 7.4/Core-2022.2.9/Supervisor-2022.01.1)
I’ve had HA hang three times in the past week.
First while on vacation and thought it was slow connection but realized the HA had hung without access via NabuCasa or, at home, to the Configuration - Add-ons, Backups & Supervisor page (blank). Tried going to Configuration-Settings but it was blank so pulled out USB-C power from rPi4b and it was fine. For a day…
Same thing happened again. I noticed because some of my dashboard items had greyed out. Certain Z-wave ones like The Smartest House outlet plugs. This time I could access the Settings page but when I tried to restart I got a pop up in bottom left corner saying something to the effect of it couldn’t load or enact the restart.
Same happened not even 12 hours later (overnight) and again just did a hard power cycle.
Happy to post anything that might be of help but not sure what to share (and what to black out when I do).
Thanks!
E
Log files would help.
Are you using an SD card or SSD? I used to get similar issues all the time until I switched to an external SSD.
Thanks for the quick replies
Switched to SSD few months back
home-assistant.log:
2022-03-01 07:26:02 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration trakt which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-03-01 07:26:02 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-03-01 07:26:02 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration sonarr_upcoming_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-03-01 07:26:02 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration meross_cloud which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-03-01 07:26:02 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration tesla_custom which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-03-01 07:26:03 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration dewpoint which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-03-01 07:26:03 ERROR (SyncWorker_1) [homeassistant.loader] The custom integration 'dewpoint' does not have a version key in the manifest file and was blocked from loading. See https://developers.home-assistant.io/blog/2021/01/29/custom-integration-changes#versions for more details
2022-03-01 07:26:03 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration emporia_vue which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-03-01 07:26:04 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2022-03-01 07:26:04 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=33 from 2022-03-01 03:35:30.539050)
2022-03-01 07:26:09 ERROR (SyncWorker_4) [schluter.authenticator] Token has expired.
2022-03-01 07:26:16 INFO (MainThread) [backoff] Backing off async_request(...) for 0.2s (tesla_wall_connector.exceptions.WallConnectorConnectionTimeoutError: Timeout while connecting to Wall Connector at 192.168.1.198)
2022-03-01 07:26:16 WARNING (MainThread) [custom_components.meross_cloud] Skip MQTT cert validation option set to: True
2022-03-01 07:26:21 INFO (MainThread) [backoff] Backing off async_request(...) for 0.5s (tesla_wall_connector.exceptions.WallConnectorConnectionTimeoutError: Timeout while connecting to Wall Connector at 192.168.1.198)
2022-03-01 07:26:23 WARNING (MainThread) [custom_components.meross_cloud]
Meross Cloud Custom component
Developed by Alberto Geniola
Low level library version: 0.4.4.4
This custom component is under development and not yet ready for production use.
In case of errors/misbehave, please report it here:
https://github.com/albertogeniola/meross-homeassistant/issues
If you like this extension and you want to support it, please consider donating.
List of devices reported by HTTP API:
2022-03-01 07:26:24 ERROR (MainThread) [backoff] Giving up async_request(...) after 3 tries (tesla_wall_connector.exceptions.WallConnectorConnectionTimeoutError: Timeout while connecting to Wall Connector at 192.168.1.198)
2022-03-01 07:26:24 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Tesla Wall Connector' for tesla_wall_connector integration not ready yet: Timeout while connecting to Wall Connector at 192.168.1.198; Retrying in background
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.main_123_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_subpanel_123_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_dryer_1_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_air_handler_2_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_washer_3_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_bath_heat_4_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_bath_lights_5_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_bath_outlets_6_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_floor_heat_7_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_balance_balance_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.den_and_living_room_2_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.sump_pump_3_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.first_fl_bath_and_hall_4_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.kitchen_lights_5_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.kids_bath_outlets_6_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.garbage_and_dishwasher_7_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.tesla_8_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.furnace_9_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.master_asher_dining_10_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.basement_lights_11_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.refrigerator_12_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.living_room_13_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.crawl_space_14_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.family_room_15_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.main_16_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.main_balance_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.main_123_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_subpanel_123_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_dryer_1_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_air_handler_2_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_washer_3_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_bath_heat_4_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_bath_lights_5_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_bath_outlets_6_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_floor_heat_7_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_balance_balance_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.den_and_living_room_2_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.sump_pump_3_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.first_fl_bath_and_hall_4_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.kitchen_lights_5_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.kids_bath_outlets_6_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.garbage_and_dishwasher_7_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.tesla_8_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.furnace_9_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.master_asher_dining_10_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.basement_lights_11_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.refrigerator_12_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.living_room_13_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.crawl_space_14_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.family_room_15_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.main_16_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.main_balance_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-03-01 07:26:25 ERROR (MainThread) [homeassistant.components.zwave_js] Discovery for value Value(value_id='17-50-0-value-1114625') on device 'Crawlspace Dehumidifier' (Node(node_id=17)) will be skipped: Value Value(value_id='17-50-0-value-1114625') has unknown data in the following location: metadata.cc_specific.meterType. A reinterview of node Node(node_id=17) may correct this issue, but if it doesn't, please report this issue as it may be caused by either an upstream issue with the driver or missing support for this data in the library
2022-03-01 07:26:25 ERROR (MainThread) [homeassistant.components.zwave_js] Discovery for value Value(value_id='19-50-0-value-590337') on device 'Attic Dehumidifier' (Node(node_id=19)) will be skipped: Value Value(value_id='19-50-0-value-590337') has unknown data in the following location: metadata.cc_specific.meterType. A reinterview of node Node(node_id=19) may correct this issue, but if it doesn't, please report this issue as it may be caused by either an upstream issue with the driver or missing support for this data in the library
2022-03-01 07:26:26 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.tesla_inside_temp (<class 'homeassistant.components.mqtt.sensor.MqttSensor'>) with device_class None reports a temperature in °C which will be converted to °F. Temperature conversion for entities without correct device_class is deprecated and will be removed from Home Assistant Core 2022.3. Please update your configuration if device_class is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
2022-03-01 07:26:26 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.tesla_outside_temp (<class 'homeassistant.components.mqtt.sensor.MqttSensor'>) with device_class None reports a temperature in °C which will be converted to °F. Temperature conversion for entities without correct device_class is deprecated and will be removed from Home Assistant Core 2022.3. Please update your configuration if device_class is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
2022-03-01 07:26:34 WARNING (MainThread) [homeassistant.components.automation.update_tesla_location_as_mqtt_location_updates] MQTT - Update Tesla location as MQTT location updates: Already running
2022-03-01 07:26:42 INFO (MainThread) [backoff] Backing off async_request(...) for 0.4s (tesla_wall_connector.exceptions.WallConnectorConnectionTimeoutError: Timeout while connecting to Wall Connector at 192.168.1.198)
2022-03-01 07:30:25 ERROR (MainThread) [custom_components.emporia_vue] Error communicating with Emporia API: 500 Server Error: Internal Server Error for url: https://api.emporiaenergy.com/AppAPI?apiMethod=getDeviceListUsages&deviceGids=29000+81164&instant=2022-03-01T12:30:25.015076Z&scale=1MIN&energyUnit=KilowattHours
2022-03-01 07:30:25 ERROR (MainThread) [custom_components.emporia_vue] Error fetching sensor data: Error communicating with Emporia API: 500 Server Error: Internal Server Error for url: https://api.emporiaenergy.com/AppAPI?apiMethod=getDeviceListUsages&deviceGids=29000+81164&instant=2022-03-01T12:30:25.015076Z&scale=1MIN&energyUnit=KilowattHours
2022-03-01 07:35:08 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.1.41: Connection timed out for hub 11071595
2022-03-01 08:00:10 WARNING (Recorder) [homeassistant.components.sensor.recorder] Entity sensor.main_balance_1d from integration emporia_vue has state class total_increasing, but its state is not strictly increasing. Triggered by state 2.215 (2.217) with last_updated set to 2022-03-01T12:57:25.213616+00:00. Please report it to the custom component author.
home-assistant.log.1
2022-02-28 22:35:29 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration trakt which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-02-28 22:35:29 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration sonarr_upcoming_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-02-28 22:35:29 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-02-28 22:35:29 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration meross_cloud which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-02-28 22:35:29 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration dewpoint which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-02-28 22:35:29 ERROR (SyncWorker_0) [homeassistant.loader] The custom integration 'dewpoint' does not have a version key in the manifest file and was blocked from loading. See https://developers.home-assistant.io/blog/2021/01/29/custom-integration-changes#versions for more details
2022-02-28 22:35:29 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration tesla_custom which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-02-28 22:35:29 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration emporia_vue which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-02-28 22:35:30 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2022-02-28 22:35:30 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=32 from 2022-02-27 13:33:44.101109)
2022-02-28 22:35:34 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [548421958144] Received invalid command: mobile_app/push_notification_channel
2022-02-28 22:35:35 ERROR (SyncWorker_5) [schluter.authenticator] Token has expired.
2022-02-28 22:35:40 INFO (MainThread) [backoff] Backing off async_request(...) for 0.0s (tesla_wall_connector.exceptions.WallConnectorConnectionTimeoutError: Timeout while connecting to Wall Connector at 192.168.1.198)
2022-02-28 22:35:41 WARNING (MainThread) [custom_components.meross_cloud] Skip MQTT cert validation option set to: True
2022-02-28 22:35:42 ERROR (MainThread) [snitun.client.client_peer] Challenge/Response error with SniTun server (0 bytes read on a total of 32 expected bytes)
2022-02-28 22:35:42 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-02-28 22:35:46 INFO (MainThread) [backoff] Backing off async_request(...) for 0.9s (tesla_wall_connector.exceptions.WallConnectorConnectionTimeoutError: Timeout while connecting to Wall Connector at 192.168.1.198)
2022-02-28 22:35:48 WARNING (MainThread) [custom_components.meross_cloud]
2022-02-28 22:35:48 ERROR (MainThread) [snitun.client.client_peer] Challenge/Response error with SniTun server (0 bytes read on a total of 32 expected bytes)
2022-02-28 22:35:48 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-02-28 22:35:49 WARNING (MainThread) [homeassistant.components.switch.reproduce_state] Unable to find entity switch.heathers_switch_on_off
2022-02-28 22:35:49 ERROR (MainThread) [backoff] Giving up async_request(...) after 3 tries (tesla_wall_connector.exceptions.WallConnectorConnectionTimeoutError: Timeout while connecting to Wall Connector at 192.168.1.198)
2022-02-28 22:35:49 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Tesla Wall Connector' for tesla_wall_connector integration not ready yet: Timeout while connecting to Wall Connector at 192.168.1.198; Retrying in background
2022-02-28 22:35:50 ERROR (MainThread) [homeassistant.components.zwave_js] Discovery for value Value(value_id='17-50-0-value-1114625') on device 'Crawlspace Dehumidifier' (Node(node_id=17)) will be skipped: Value Value(value_id='17-50-0-value-1114625') has unknown data in the following location: metadata.cc_specific.meterType. A reinterview of node Node(node_id=17) may correct this issue, but if it doesn't, please report this issue as it may be caused by either an upstream issue with the driver or missing support for this data in the library
2022-02-28 22:35:50 ERROR (MainThread) [homeassistant.components.zwave_js] Discovery for value Value(value_id='19-50-0-value-590337') on device 'Attic Dehumidifier' (Node(node_id=19)) will be skipped: Value Value(value_id='19-50-0-value-590337') has unknown data in the following location: metadata.cc_specific.meterType. A reinterview of node Node(node_id=19) may correct this issue, but if it doesn't, please report this issue as it may be caused by either an upstream issue with the driver or missing support for this data in the library
2022-02-28 22:35:50 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.main_123_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:50 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_subpanel_123_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:50 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_dryer_1_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:50 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_air_handler_2_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:50 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_washer_3_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:50 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_bath_heat_4_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:50 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_bath_lights_5_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:50 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_bath_outlets_6_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:50 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_floor_heat_7_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:50 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_balance_balance_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:50 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.den_and_living_room_2_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:50 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.sump_pump_3_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:50 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.first_fl_bath_and_hall_4_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:50 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.kitchen_lights_5_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:50 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.kids_bath_outlets_6_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:50 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.garbage_and_dishwasher_7_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:50 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.tesla_8_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.furnace_9_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.master_asher_dining_10_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.basement_lights_11_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.refrigerator_12_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.living_room_13_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.crawl_space_14_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.family_room_15_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.main_16_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.main_balance_1mon (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.main_123_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_subpanel_123_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_dryer_1_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_air_handler_2_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_washer_3_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_bath_heat_4_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_bath_lights_5_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_bath_outlets_6_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_floor_heat_7_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.power_balance_balance_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.den_and_living_room_2_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.sump_pump_3_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.first_fl_bath_and_hall_4_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.kitchen_lights_5_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.kids_bath_outlets_6_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.garbage_and_dishwasher_7_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.tesla_8_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.furnace_9_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.master_asher_dining_10_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.basement_lights_11_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.refrigerator_12_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.living_room_13_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.crawl_space_14_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.family_room_15_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.main_16_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.main_balance_1d (<class 'custom_components.emporia_vue.sensor.CurrentVuePowerSensor'>) with state_class total_increasing has set last_reset. Setting last_reset for entities with state_class other than 'total' is not supported. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
ran out of text space so continued next
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.tesla_inside_temp (<class 'homeassistant.components.mqtt.sensor.MqttSensor'>) with device_class None reports a temperature in °C which will be converted to °F. Temperature conversion for entities without correct device_class is deprecated and will be removed from Home Assistant Core 2022.3. Please update your configuration if device_class is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
2022-02-28 22:35:51 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.tesla_outside_temp (<class 'homeassistant.components.mqtt.sensor.MqttSensor'>) with device_class None reports a temperature in °C which will be converted to °F. Temperature conversion for entities without correct device_class is deprecated and will be removed from Home Assistant Core 2022.3. Please update your configuration if device_class is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
2022-02-28 22:35:59 WARNING (MainThread) [homeassistant.components.automation.update_tesla_location_as_mqtt_location_updates] MQTT - Update Tesla location as MQTT location updates: Already running
2022-02-28 22:36:05 INFO (MainThread) [backoff] Backing off async_request(...) for 0.7s (tesla_wall_connector.exceptions.WallConnectorConnectionTimeoutError: Timeout while connecting to Wall Connector at 192.168.1.198)
2022-02-28 22:36:10 INFO (MainThread) [backoff] Backing off async_request(...) for 1.7s (tesla_wall_connector.exceptions.WallConnectorConnectionTimeoutError: Timeout while connecting to Wall Connector at 192.168.1.198)
2022-02-28 22:37:52 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x6517:1:0x0001]: async_initialize: all attempts have failed: [DeliveryError('[0x6517:1:0x0001]: Message send failure'), DeliveryError('[0x6517:1:0x0001]: Message send failure'), DeliveryError('[0x6517:1:0x0001]: Message send failure'), DeliveryError('[0x6517:1:0x0001]: Message send failure')]
2022-02-28 22:37:52 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x6517:1:0x0402]: async_initialize: all attempts have failed: [DeliveryError('[0x6517:1:0x0402]: Message send failure'), DeliveryError('[0x6517:1:0x0402]: Message send failure'), DeliveryError('[0x6517:1:0x0402]: Message send failure'), DeliveryError('[0x6517:1:0x0402]: Message send failure')]
2022-02-28 23:49:58 ERROR (Thread-6) [plexapi] http://192.168.1.40:32400: Client not found at http://192.168.1.40:32400
2022-02-28 23:49:58 ERROR (Thread-5) [plexapi] https://192-168-1-40.eaf75b971d8f401897a8787c2726e069.plex.direct:32400: Client not found at https://192-168-1-40.eaf75b971d8f401897a8787c2726e069.plex.direct:32400
2022-02-28 23:50:01 ERROR (Thread-8) [plexapi] http://[homeIP]:32400: HTTPConnectionPool(host='[homeIP]', port=32400): Max retries exceeded with url: /resources (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7fa6aed1c0>, 'Connection to [homeIP] timed out. (connect timeout=3)'))
2022-02-28 23:50:02 ERROR (Thread-7) [plexapi] https://[homeIP].eaf75b971d8f401897a8787c2726e069.plex.direct:32400: HTTPSConnectionPool(host='[homeIP].eaf75b971d8f401897a8787c2726e069.plex.direct', port=32400): Max retries exceeded with url: /resources (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f9c2a7b20>, 'Connection to [homeIP].eaf75b971d8f401897a8787c2726e069.plex.direct timed out. (connect timeout=3)'))
2022-02-28 23:50:02 ERROR (SyncWorker_1) [homeassistant.components.plex.server] Resource connection failed to plex.tv: Leilas-MacBook-Air.local
2022-02-28 23:53:21 ERROR (Thread-10) [plexapi] http://192.168.1.40:32400: Client not found at http://192.168.1.40:32400
2022-02-28 23:53:21 ERROR (Thread-9) [plexapi] https://192-168-1-40.eaf75b971d8f401897a8787c2726e069.plex.direct:32400: Client not found at https://192-168-1-40.eaf75b971d8f401897a8787c2726e069.plex.direct:32400
2022-02-28 23:53:24 ERROR (Thread-12) [plexapi] http://[homeIP]:32400: HTTPConnectionPool(host='[homeIP]', port=32400): Max retries exceeded with url: /resources (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7f9b27af70>, 'Connection to [homeIP] timed out. (connect timeout=3)'))
2022-02-28 23:53:24 ERROR (Thread-11) [plexapi] https://[homeIP].eaf75b971d8f401897a8787c2726e069.plex.direct:32400: HTTPSConnectionPool(host='[homeIP].eaf75b971d8f401897a8787c2726e069.plex.direct', port=32400): Max retries exceeded with url: /resources (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f9b27a820>, 'Connection to [homeIP].eaf75b971d8f401897a8787c2726e069.plex.direct timed out. (connect timeout=3)'))
2022-02-28 23:53:24 ERROR (SyncWorker_2) [homeassistant.components.plex.server] Resource connection failed to plex.tv: Leilas-MacBook-Air.local
2022-02-28 23:55:10 WARNING (Recorder) [homeassistant.components.sensor.recorder] Entity sensor.main_123_1d from integration emporia_vue has state class total_increasing, but its state is not strictly increasing. Triggered by state 53.704 (53.719) with last_updated set to 2022-03-01T04:51:51.490636+00:00. Please report it to the custom component author.
2022-03-01 00:40:10 WARNING (Recorder) [homeassistant.components.sensor.recorder] Entity sensor.power_subpanel_123_1d from integration emporia_vue has state class total_increasing, but its state is not strictly increasing. Triggered by state 0.032 (0.033) with last_updated set to 2022-03-01T05:38:51.387531+00:00. Please report it to the custom component author.
2022-03-01 00:40:10 WARNING (Recorder) [homeassistant.components.sensor.recorder] Entity sensor.living_room_13_1d from integration emporia_vue has state class total_increasing, but its state is not strictly increasing. Triggered by state 0.03 (0.031) with last_updated set to 2022-03-01T05:38:51.389264+00:00. Please report it to the custom component author.
2022-03-01 01:40:10 WARNING (Recorder) [homeassistant.components.sensor.recorder] Entity sensor.sump_pump_3_1d from integration emporia_vue has state class total_increasing, but its state is not strictly increasing. Triggered by state 0.068 (0.069) with last_updated set to 2022-03-01T06:38:51.381648+00:00. Please report it to the custom component author.
2022-03-01 01:40:10 WARNING (Recorder) [homeassistant.components.sensor.recorder] Entity sensor.tesla_8_1d from integration emporia_vue has state class total_increasing, but its state is not strictly increasing. Triggered by state 0.198 (0.2) with last_updated set to 2022-03-01T06:38:51.382058+00:00. Please report it to the custom component author.
2022-03-01 02:10:10 WARNING (Recorder) [homeassistant.components.sensor.recorder] Entity sensor.kids_bath_outlets_6_1d from integration emporia_vue has state class total_increasing, but its state is not strictly increasing. Triggered by state 0.061 (0.062) with last_updated set to 2022-03-01T07:09:51.732859+00:00. Please report it to the custom component author.
2022-03-01 02:24:57 ERROR (MainThread) [custom_components.emporia_vue] Error communicating with Emporia API: 500 Server Error: Internal Server Error for url: https://api.emporiaenergy.com/AppAPI?apiMethod=getDeviceListUsages&deviceGids=29000+81164&instant=2022-03-01T07:24:57.001928Z&scale=1MIN&energyUnit=KilowattHours
2022-03-01 02:24:57 ERROR (MainThread) [custom_components.emporia_vue] Error fetching sensor data: Error communicating with Emporia API: 500 Server Error: Internal Server Error for url: https://api.emporiaenergy.com/AppAPI?apiMethod=getDeviceListUsages&deviceGids=29000+81164&instant=2022-03-01T07:24:57.001928Z&scale=1MIN&energyUnit=KilowattHours
2022-03-01 03:00:10 WARNING (Recorder) [homeassistant.components.sensor.recorder] Entity sensor.power_balance_balance_1d from integration emporia_vue has state class total_increasing, but its state is not strictly increasing. Triggered by state 0.187 (0.189) with last_updated set to 2022-03-01T07:56:51.435447+00:00. Please report it to the custom component author.
2022-03-01 03:00:29 ERROR (Thread-14) [plexapi] http://192.168.1.40:32400: Client not found at http://192.168.1.40:32400
2022-03-01 03:00:29 ERROR (Thread-13) [plexapi] https://192-168-1-40.eaf75b971d8f401897a8787c2726e069.plex.direct:32400: Client not found at https://192-168-1-40.eaf75b971d8f401897a8787c2726e069.plex.direct:32400
2022-03-01 03:00:32 ERROR (Thread-16) [plexapi] http://[homeIP]:32400: HTTPConnectionPool(host='[homeIP]', port=32400): Max retries exceeded with url: /resources (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7f9829e4c0>, 'Connection to [homeIP] timed out. (connect timeout=3)'))
2022-03-01 03:00:32 ERROR (Thread-15) [plexapi] https://[homeIP].eaf75b971d8f401897a8787c2726e069.plex.direct:32400: HTTPSConnectionPool(host='[homeIP].eaf75b971d8f401897a8787c2726e069.plex.direct', port=32400): Max retries exceeded with url: /resources (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f98d18100>, 'Connection to [homeIP].eaf75b971d8f401897a8787c2726e069.plex.direct timed out. (connect timeout=3)'))
2022-03-01 03:00:32 ERROR (SyncWorker_3) [homeassistant.components.plex.server] Resource connection failed to plex.tv: Leilas-MacBook-Air.local
2022-03-01 03:03:51 ERROR (Thread-18) [plexapi] http://192.168.1.40:32400: Client not found at http://192.168.1.40:32400
2022-03-01 03:03:51 ERROR (Thread-17) [plexapi] https://192-168-1-40.eaf75b971d8f401897a8787c2726e069.plex.direct:32400: Client not found at https://192-168-1-40.eaf75b971d8f401897a8787c2726e069.plex.direct:32400
2022-03-01 03:03:54 ERROR (Thread-20) [plexapi] http://[homeIP]:32400: HTTPConnectionPool(host='[homeIP]', port=32400): Max retries exceeded with url: /resources (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7f98d0dc70>, 'Connection to [homeIP] timed out. (connect timeout=3)'))
2022-03-01 03:03:54 ERROR (Thread-19) [plexapi] https://[homeIP].eaf75b971d8f401897a8787c2726e069.plex.direct:32400: HTTPSConnectionPool(host='[homeIP].eaf75b971d8f401897a8787c2726e069.plex.direct', port=32400): Max retries exceeded with url: /resources (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f98d0d550>, 'Connection to [homeIP].eaf75b971d8f401897a8787c2726e069.plex.direct timed out. (connect timeout=3)'))
2022-03-01 03:03:54 ERROR (SyncWorker_6) [homeassistant.components.plex.server] Resource connection failed to plex.tv: Leilas-MacBook-Air.local
home-assistant.log.fault is there but 0kb and empty
Only removed external IP form above log files.
Most errors seem to be related to HACS items but none appear to me to be culprit. I use these HACS integrations:
Sensor.Sonarr Upcoming Media
Emporia Vue
Meross Integration
Trakt
Home Assistant Dewpoint
Tesla
All up to date
Thanks!
You have a large number of errors and warnings that need fixing. None of them are due to HACS, they are due to third party integrations you have installed with HACS.
As you are experiencing stability issues, I suggest you follow this advice:
I’d start with this one:
And this one:
Thanks - I disabled all the HACS integrations throwing up errors but woke up to an alert that my leak sensor was unavailable and multiple Z-Wave devices greyed out. Trying to access Add Ons, Backups, Supervisor gives me a spinning wheel on the page.
Can’t access HA via SMB. Here are logs from within HA:
Error while processing event EventTask(event=<Event time_changed[L]: now=2022-03-02T06:36:29.000857-05:00>): 'NoneType' object has no attribute 'dialect'
6:37:00 AM – (ERROR) Recorder - message first occurred at 3:04:24 AM and shows up 1277 times
Error while processing event EventTask(event=<Event time_changed[L]: now=2022-03-02T06:36:13.001763-05:00>): 'NoneType' object is not callable
6:36:59 AM – (ERROR) Recorder - message first occurred at 3:04:24 AM and shows up 1084 times
SQLAlchemyError error processing task EventTask(event=<Event time_changed[L]: now=2022-03-02T06:36:11.002047-05:00>): This Session's transaction has been rolled back due to a previous exception during flush. To begin a new transaction with this Session, first issue Session.rollback(). Original exception was: 'NoneType' object has no attribute 'dialect' (Background on this error at: https://sqlalche.me/e/14/7s2a)
6:36:59 AM – (ERROR) Recorder - message first occurred at 3:04:24 AM and shows up 843 times
Failed to get the Z-Wave JS add-on info:
6:36:48 AM – (ERROR) Z-Wave JS - message first occurred at 3:06:08 AM and shows up 162 times
/addons/core_zwave_js/info return code 500
6:36:48 AM – (ERROR) Home Assistant Supervisor - message first occurred at 3:06:08 AM and shows up 249 times
Error doing job: Task exception was never retrieved
6:36:22 AM – (ERROR) helpers/storage.py - message first occurred at 3:05:07 AM and shows up 41 times
Error handling request
6:36:21 AM – (ERROR) components/recorder/util.py - message first occurred at 6:31:36 AM and shows up 3 times
6:36:21 AM – (ERROR) components/http/static.py - message first occurred at 6:31:36 AM and shows up 3 times
SQLAlchemyError error processing task EventTask(event=<Event time_changed[L]: now=2022-03-02T06:31:13.002112-05:00>): This Session's transaction has been rolled back due to a previous exception during flush. To begin a new transaction with this Session, first issue Session.rollback(). Original exception was: 'NoneType' object has no attribute 'dialect' (Background on this error at: https://sqlalche.me/e/14/7s2a)
6:36:13 AM – (ERROR) Recorder - message first occurred at 3:04:24 AM and shows up 241 times
Error while processing event StatisticsTask(start=datetime.datetime(2022, 3, 2, 11, 10, tzinfo=datetime.timezone.utc)): 'NoneType' object is not callable
6:35:10 AM – (ERROR) Recorder - message first occurred at 3:05:10 AM and shows up 43 times
No watchdog response
6:34:59 AM – (WARNING) /usr/local/lib/python3.9/site-packages/zigpy_deconz/zigbee/application.py - message first occurred at 3:04:59 AM and shows up 29 times
Can't read Supervisor data:
6:33:56 AM – (WARNING) Home Assistant Supervisor - message first occurred at 3:08:54 AM and shows up 42 times
Failed to to call /supervisor/info -
6:32:07 AM – (ERROR) Home Assistant Supervisor - message first occurred at 6:32:07 AM and shows up 3 times
HacsTask<update_downloaded_repositories> failed: [Errno 5] I/O error: '/config/.storage/hacs.hacs'
5:49:52 AM – (ERROR) HACS (custom integration) - message first occurred at 3:49:52 AM and shows up 4 times
JSON file reading failed: /config/.storage/hacs.hacs
5:49:52 AM – (ERROR) util/json.py - message first occurred at 3:49:52 AM and shows up 4 times
Error while processing event PurgeTask(purge_before=datetime.datetime(2022, 2, 20, 9, 12, 0, 886, tzinfo=datetime.timezone.utc), repack=False, apply_filter=False): 'NoneType' object is not callable
4:12:00 AM – (ERROR) Recorder
Error fetching 6711182624282664206 data: Error communicating with flume API: Expecting value: line 2 column 1 (char 1)
3:36:57 AM – (ERROR) Flume
Config entry 'Z-Wave JS' for zwave_js integration not ready yet: Failed to get the Z-Wave JS add-on info: ; Retrying in background
3:06:08 AM – (WARNING) config_entries.py
Error while processing event EventTask(event=<Event time_changed[L]: now=2022-03-02T03:00:22.001183-05:00>): [Errno 30] Read-only file system: '//config/home-assistant_v2.db' -> '//config/home-assistant_v2.db.corrupt.2022-03-02T08:04:24.122366+00:00'
3:04:24 AM – (ERROR) Recorder
The system will rename the corrupt database file //config/home-assistant_v2.db to //config/home-assistant_v2.db.corrupt.2022-03-02T08:04:24.122366+00:00 in order to allow startup to proceed
Unrecoverable sqlite3 database corruption detected: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: ('state_changed', '{}', 'LOCAL', '2022-03-02 08:00:21.392768', '2022-03-02 08:00:21.392768', '15a27eebec9a996dfaeef87372c9cf08', None, None)] (Background on this error at: https://sqlalche.me/e/14/4xp6)
Serial '/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2191790-if00' connection lost unexpectedly: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
3:04:23 AM – (WARNING) /usr/local/lib/python3.9/site-packages/zigpy_deconz/api.py
Lost serial connection: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
3:04:23 AM – (ERROR) /usr/local/lib/python3.9/site-packages/zigpy_deconz/uart.py
Timeout connecting to snitun server
12:28:36 AM – (ERROR) /usr/local/lib/python3.9/site-packages/hass_nabucasa/remote.py
Ping fails, no response from peer
12:28:04 AM – (ERROR) /usr/local/lib/python3.9/site-packages/snitun/multiplexer/core.py
March 1, 2022, 10:37:29 PM – (ERROR) /usr/local/lib/python3.9/site-packages/aioharmony/hubconnector_websocket.py - message first occurred at March 1, 2022, 6:32:46 PM and shows up 6 times
Unable to find referenced entities light.outside
March 1, 2022, 9:30:00 PM – (WARNING) helpers/service.py
Error fetching tesla-wallconnector data: Could not fetch data from Tesla WallConnector at 192.168.1.198: Timeout
March 1, 2022, 9:00:36 PM – (ERROR) Tesla Wall Connector
March 1, 2022, 9:00:36 PM – (ERROR) /usr/local/lib/python3.9/site-packages/backoff/_common.py
Error evaluating condition in 'Flume - Flash lights after 15 and 20 minutes': In 'condition': In 'state': In 'state' condition: unknown entity switch.kids_bathroom_main_lights
March 1, 2022, 8:37:55 PM – (WARNING) Automation
:0:0 Script error.
March 1, 2022, 6:29:03 PM – (ERROR) components/system_log/__init__.py - message first occurred at March 1, 2022, 6:28:52 PM and shows up 2 times
March 1, 2022, 5:50:09 PM – (WARNING) Automation
March 1, 2022, 5:49:58 PM – (WARNING) Sensor - message first occurred at March 1, 2022, 5:49:58 PM and shows up 2 times
March 1, 2022, 5:49:57 PM – (ERROR) Z-Wave JS - message first occurred at March 1, 2022, 5:49:57 PM and shows up 2 times
Also if I try to restart from Server Controls, I get:
Failed to call service home assistant/restart. [Errno 5] I/O error
Your recorder is corrupt.
With this many unrelated errors I suspect your SD card may be faulty.
Thanks and…crap…
It’s actually an SSD drive if that matters.
Guess I’m off to buy a new SsD then. Would I be best off doing a clean install as I did originally and then is it safe to restore a recent backup I hope?
It does matter. That is much less likely to be faulty. What sized power supply are you using?
The pi4 has a recommended 5v 3A supply, but your SSD could require up to an extra 1.5A.
Official Raspberry Pi P3620 KSA-15E-051300HU which provides 3.0A/5.1V
Also using good quality SATA to USB cable as recommended somewhere online for use with HA installs
So you have the recommended power for the pi, but not for the pi + ssd.
Good point though I will add that I have had this combo running since Xmas and this is only the second period of time I have had any hangs. Not sure if borderline power supply would be the answer but open to getting new supply or running SSD by way of powered USB hub.
Update:
Connected SSD to an old USB 2.0 powered hub I found in basement then to the Pi
Made it through the night without finding HA hanging in AM so maybe it was all down to power
I’ll add back some of the HACS integrations next and see
Out of curiosity - should I see a difference in responsiveness (slight) by running the SSD via USB 2.0 back to Pi vs directly to the 3.1 input? Not sure if it’s just me imagining it now but things are just a slight bit slower
I have a similar issue, with similar hardware.
How has your system run since you gave the SSD its own supply?
MUCH better
I assume you have incorporated a powered USB hub of some sort? If not how?
Several I’ve looked at have reviews saying they had problems with a SSD connecting to a RPi.
Could I ask what hub you have found to work?
TIA
