Heating control based on PV grid feed-in.
I have an instantaneous water heater with three heaters of 1kw each.
These should be switched on by the ESP depending on the PV grid feed-in.
In addition, the heating elements that have the shortest operating time should be used when switching on
and off in reverse order.
Pv feed > 1200 w for 2 minutes → switch on the heating element with the lowest operating hours.
wait 10 s and check again whether another heating element can be switched on.
what is the best way to go about it?
my code until now:
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "fdf1873cf33913c147f6761493bee47c"
# Enable Web server.
web_server:
port: 80
wifi:
# use_address: oel-fuellstand-sensor
networks:
- ssid: !secret wlan_ssid
password: !secret wlan_password
ap:
ssid: "Elektroheizung Fallback Hotspot"
password: "W5ywu1mCj6ta"
captive_portal:
switch:
- platform: restart
- platform: gpio
pin: 25
restore_mode: ALWAYS_OFF
on_turn_on:
while:
condition:
switch.is_on: heizstab_1
then:
- globals.set:
value: !lambda |-
return id(global_Betriebsstunden_Heizung_1) +1;
- delay: 60s
- platform: gpio
pin: 26
on_turn_on:
while:
condition:
switch.is_on: heizstab_2
then:
- globals.set:
value: !lambda |-
return id(global_Betriebsstunden_Heizung_2) +1;
- delay: 60s
- platform: gpio
pin: 33
on_turn_on:
while:
condition:
switch.is_on: heizstab_3
then:
- globals.set:
value: !lambda |-
return id(global_Betriebsstunden_Heizung_1) +3;
- delay: 60s
- platform: gpio
pin: 32
on_turn_on:
while:
condition:
switch.is_on: pumpe
then:
- globals.set:
value: !lambda |-
return id(global_Betriebsstunden_Pumpe) +1;
- delay: 60s
#Globale Variablen
globals:
- id: temp_freigabe
type: bool
restore_value: yes
initial_value: '0'
- id: global_Betriebsstunden_Heizung_1
type: int
initial_value: '0'
restore_value: yes
- id: global_Betriebsstunden_Heizung_2
type: int
initial_value: '0'
restore_value: yes
- id: global_Betriebsstunden_Heizung_3
type: int
initial_value: '0'
restore_value: yes
- id: global_Betriebsstunden_Pumpe
type: int
initial_value: '0'
restore_value: yes
- platform: uptime
update_interval: 60s
#Betriebsstundenzähler
name: "Betriebsstunden Heizung 1"
unit_of_measurement: min
accuracy_decimals: 0
lambda: |-
return id(global_Betriebsstunden_Heizung_1);
name: "Betriebsstunden Heizung 2"
lambda: |-
return id(global_Betriebsstunden_Heizung_2);
name: "Betriebsstunden Heizung 3"
lambda: |-
return id(global_Betriebsstunden_Heizung_3);
lambda: |-
return id(global_Betriebsstunden_Pumpe);
#PV Überschuss von Homeassistant
- platform: homeassistant
name: "PV Überschuss"
entity_id: sensor.grid_power_supplied
unit_of_measurement: W
