I have a 3-way standard switch setup where the load comes “before” the first switch. The diagram here is basically my setup:
I can’t use a standard Z-wave GE dimmer switch pair (main and secondary), because there’s no real neutral. I could run one neutral into the “furthest” box, and use the spare conductor connecting the first box, as the second Z-wave switch only needs the traveler and the neutral. I’d extend the neutral back to the first box on this spare conductor.
Now, I guess, this is the question: If I get a legit neutral into both boxes, will the fact that the “line” side of the main Z-wave switch will not get 120V cause me an issue? This would be because the “hot” wire from the breaker panel is connected to the lamp, and then a conductor is run to the first box. So there will be a voltage drop there.
The light fixture is for a regular 65 watt bulb, but I could use a LED one with 10 watts or less. So the voltage drop to the first Z-Wave (main) switch shouldn’t be bad.
Any suggestions would be appreciated.
Regards,
Ambi
